Help reading temperatur with the G_1396 ntc thermistor
I need to read and display temperature from a G_1396 Thermistor http://www.specsensors.com/pdfs/ntc_radial_glass.pdf
I'm not sure where to start, the temperature range is non-linear so not sure how to calculate the temp based on the voltage dropped across it.
Any help would be greatly appreciated. THANKS!!!
There is a formula for characterizing a thermistor. You use the voltage across the thermistor to calculate the resistance and the formulas to calculate the temperature from the resistance.
http://www.daycounter.com/Calculators/Steinhart-Hart-Thermistor-Calculator.phtml
Thanks! that helped.
Your post led me to this, http://www.arduino.cc/playground/ComponentLib/Thermistor2 http://www.arduino.cc/playground/ComponentLib/Thermistor4
Think I have enough now to at least set something on fire. ]:D Thanks again!
EDIT And here is a good tutorial http://web.cecs.pdx.edu/~gerry/class/EAS199B/howto/thermistorArduino/thermistorArduino.pdf
