As the subject states, I would like to read UART without using interrupts.
Within my program, I’m essentially polling the UART message by using Serial.available() each main loop iteration. I also know how big the UART messages are (2 bytes).
Is there any way to directly access the message in the UART_RHR? And are there any flags I need to be aware of resetting/setting once I’ve read the UART message?
In there you can see how it sets up the serial port and how the interrupt works. Basically copy this stuff into your sketch and do what the interrupt handler does.
But, to more directly answer your question:
read UART_SR to a variable to reset the status flags
Then if UART_SR_RXRDY is set you read from UART_RHR
There’s your byte.
You probably need to #include “UARTClass.h” in your sketch to make sure you’ve got access to all the register definitions. And, you’ll have to go searching to find a way to snag the proper pointer to the Serial hardware so you can do pUart->UART_RHR and all that. You won’t normally have access to the _pUart pointer in your sketch so you’ll have to recreate it.
AdderD:
Reading UART_SR will NOT reset the status flags. The bit RXRDY in UART_SR is automatically cleared in UART_SR when the receive holding register UART_RHR is read.
ard_newbie:
Thanks. I was wondering if I would have to manually clear any bits when I read.
To me that hints that UART_RHR is FIFO. Is my assumption correct?
I’ve also read this in the data sheet…
"When a complete character is received, it is transferred to the UART_RHR and the RXRDY status bit in UART_SR
(Status Register) is set. The bit RXRDY is automatically cleared when the receive holding register UART_RHR is
read.
If UART_RHR has not been read by the software (or the Peripheral Data Controller or DMA Controller) since the
last transfer, the RXRDY bit is still set and a new character is received, the OVRE status bit in UART_SR is set.
OVRE is cleared when the software writes the control register UART_CR with the bit RSTSTA (Reset Status) at 1."
Because my message is 2 bytes, I might also have to worry about the OVRE status bit depending on the performance of my program. What happens to the second byte in this case? Does it also get transferred into the RHR?
PS. I might be overthinking this, but I do like learning exactly how this works.
No.
Yes, apparently. Overwriting the first character
This is actually somewhat unusual. Many UARTs that I’ve used will not transfer data to the RHR when it is “full”, giving you essentially a two-byte buffer. The AVR has a two byte FIFO for the RHR, AND doesn’t transfer from the RSR to the RHR if there is no room. I’m not sure whether the SAM3X UART is especially stupid, or whether this was a design choice that makes working with DMA easier…
Here’s a little test program. It disables ALL interrupts and waits while you send data to it, so the data buffering (if any) is only what is done in the hardware. If you send “ABCDE” to an Arduino Uno, you get “ABE” out. If you do that on a Due, you just get “E”…
int c;
Serial.println("Waiting for input"); Serial.flush();
noInterrupts();
for (volatile int32_t i = 0; i < F_CPU; i++) ; // delay for about 10s
interrupts();
Serial.println("Woke up. Queued on Serial Port:");
while ((c = Serial.read()) > 0)
Serial.println((char)c);
Ooof, Yes. I'm having lots of problems with this code. It reads information, but there's a lot of weird behavior.
char charArray[2] = {0,0};
while(1) {
if ((UART_SR_RXRDY==1) && (i == 0)) {
charArray[i] = UART->UART_RHR; //read byte
i++;
else if ((UART_SR_RXRDY==1) && (i == 1)) {
i = 0;
UART->UART_CR = UART_CR_RSTSTA; //clears errors
When I run the program, it enters the if/else statement even when there's no incoming message. This makes me think that UART_SR_RXRDY flag remains set even after UART_RHR is read.
The 1 byte long message is sometimes read at the wrong frame.
Sending 0100 0001 can potentially be read as 0000 0101 or 0100 0001 or 0101 0000.
When sending a 2 byte long message, one of the bytes gets overwritten or ignored. I'll only get the first byte or the second byte loaded into charArray*.*
Thank you so much! That fixes the majority of the problems! May I ask what the meaning of this line of code is?
while((UART->UART_SR & UART_SR_RXRDY) == 0);
I'm still occasionally getting this problem, though.
anonymousUser:
3. When sending a 2 byte long message, one of the bytes gets overwritten or ignored. I'll only get the first byte or the second byte loaded into charArray*.* [/quote] This is what I'm sending to RX0. * * Serial.write('A'); Serial.write('1'); delay(3000);* * This is what the Due is reading. * *A111A1AA1A1* * It sometimes reads the entire UART message and relays the information correctly, but the majority of the time, it reads only one byte and ignores the other.
