can someone show me an example of this..have have tried many examples only ones that work are for posting data not reading it.
I have butchered this code together with no luck...thanks for any help/mocking
#include <ESP8266WiFi.h>
extern "C" {
#include "user_interface.h"
const char* ssid = "x";
const char* password = "";
const char* host = "api.thingspeak.com";
delay(100);
// We start by connecting to a WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
delay(10000);
Serial.print("connecting to ");
Serial.println(host);
// Use WiFiClient class to create TCP connections
WiFiClient client;
const int httpPort = 80;
if (!client.connect(host, httpPort)) {
Serial.println("connection failed");
delay(10);
return;
String url = "/channels/21652/fields/3/last";
Serial.print("Requesting URL: ");
// This will send the request to the server
client.print(String("GET ") + url + " HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
// Read all the lines of the reply from server and print them to Serial
while(client.available()){
String line = client.readStringUntil('\r');
Serial.print(line);
delay(10000);
Connecting to x
WiFi connected
IP address:
192.168.35.42
connecting to api.thingspeak.com
Requesting URL: HTTP/1.1 200 OK
Server: nginx/1.7.5
Date: Mon, 03 Aug 2015 20:54:27 GMT
Content-Type: text/html; charset=utf-8
Transfer-Encoding: chunked
Connection: close
Vary: Accept-Encoding
Status: 200 OK
X-Frame-Options: ALLOWALL
Access-Control-Allow-Origin: *
Access-Control-Allow-Methods: GET, POST, PUT, OPTIONS, DELETE, PATCH
Access-Control-Allow-Headers: origin, content-type, X-Requested-With
Access-Control-Max-Age: 1800
ETag: "f3def39a50359c67b3990421011fc09e"
Cache-Control: max-age=0, private, must-revalidate
X-Request-Id: 3715f229-a899-4b32-8772-b53bf0d79b0b
4
19.4
0
Ok thanks I read the post..added the "Code" to my code..I also added some delays to my program and it is actually pulling data... I posted my serial output I had no clue it would look like this in a web browser it will just return 19.4 not. I guess now I have a new..more difficult problem to solve to parse this number out.
Connecting to x
WiFi connected
IP address:
192.168.35.42
Server: nginx/1.7.5
Connection: close
Status: 200 OK
4
19.4
0
That blank line there is a clue. Nothing before it matters. What is after it might. The blank line is . So, look for in the stream. When you find it, the length of the record is important. Zero means that you have found the end of the header crap, and can start reading data.
Below is what is returned by the bottom client test code. You will need to parse out the 16.4 from what is returned. The below TextFinder application might be of use.
//zoomkat 11-04-13
//simple client test
//for use with IDE 1.0.1
//with DNS, DHCP, and Host
//open serial monitor and send an e to test client GET
//for use with W5100 based ethernet shields
//remove SD card if inserted
//data from myIP server captured in readString
#include <SPI.h>
#include <Ethernet.h>
String readString;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
char serverName[] = "api.thingspeak.com"; // myIP server test web page server
EthernetClient client;
void setup(){
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// no point in carrying on, so do nothing forevermore:
while(true);
Serial.println("client readString test 11/04/13"); // so I can keep track of what is loaded
Serial.println("Send an e in serial monitor to test"); // what to do to test
void loop(){
// check for serial input
if (Serial.available() > 0) //if something in serial buffer
byte inChar; // sets inChar as a byte
inChar = Serial.read(); //gets byte from buffer
if(inChar == 'e') // checks to see byte is an e
sendGET(); // call sendGET function below when byte is an e
void sendGET() //client function to send/receive GET request data.
if (client.connect(serverName, 80)) { //starts client connection, checks for connection
Serial.println("connected");
client.println("GET /channels/21652/fields/3/last HTTP/1.1"); //download text
client.println("Host: api.thingspeak.com");
client.println("Connection: close"); //close 1.1 persistent connection
client.println(); //end of get request
else {
Serial.println("connection failed"); //error message if no client connect
while(client.connected() && !client.available()) delay(1); //waits for data
while (client.connected() || client.available()) { //connected or data available
char c = client.read(); //gets byte from ethernet buffer
readString += c; //places captured byte in readString
//Serial.println();
client.stop(); //stop client
Serial.println("client disconnected.");
Serial.println("Data from server captured in readString:");
Serial.print(readString); //prints readString to serial monitor
Serial.println("End of readString");
Serial.println("==================");
readString=""; //clear readString variable
Still trying to work my way through this don't know if the above mentioned Textfinder would work in my case as I'm using an esp8266/esp201..I'm trying to parse out this data which is my outdoor temperature, as Pauls suggested..using the ....two hours down..getting nowhere fast...would string substring work...thats what I'm wasting my time with reading about now.
You can ignore almost all of it . The only bits that matter to you are:
An HTTP response has a response line, several header lines (terminated with a \r), and a blank line, and a body.
The body can be anything - any series of bytes. The number of bytes in the body is given by the Content-Length header. If there is no header, then the only way to find out how long the body is is for the server to transmit the data and then close the pipe.
maxfli:
I just looked at his module in a short youtube video and it appears to be a nice wireless replacement for the w5100 ethernet shield (and the price is good). If you cave control over what thingspeak sends, then put a unique byte marker before and after the value being sent, like !16.4? that can be easily located in what is received. A crude method I've used in the past is to count carriage returns or line feeds.
will do (almost) exactly the same thing, in a much easier to read format (the difference being that it WILL get the carriage returns and line feeds in the correct order and quantity of each).
Serial.print(line);
//Serial.print(ind1)
delay(2000);
Someday, you'll come
to appreciate
code that
lines up nicely.
Ok...made suggested changes to code...and it still works..thanks.fixed spacing as well...with my new serial output..The request to thingspeak is changed..what will the easiest way to get field 3 data out of the reply..all I want is the number 18.8..to be stored as a float..I really appreciate all the help..Thanks
extern "C" {
delay(100);
Serial.println(); // We start by connecting to a WiFi network
Serial.print(".");
Serial.println("");
delay(10000);
WiFiClient client; // Use WiFiClient class to create TCP connections
delay(10);
return;
String url = "/channels/21652/feeds/last.json";
client.print("GET ");
client.print(url);
client.println(" HTTP/1.1");
client.print("Host: ");
client.println(host);
client.println();
while(client.available()){ // Read all the lines of the reply from server and print them to Serial
Serial.print(line);
delay(10000);
onnecting to x
WiFi connected
IP address:
192.168.35.42
Server: nginx/1.7.5
Date: Tue, 04 Aug 2015 17:28:23 GMT
Content-Type: application/json; charset=utf-8
Connection: close
Status: 200 OK
ETag: "2f611421f8c057bfbdb1461464fcdb56"
X-Request-Id: 7747de26-6ace-4e87-8c48-5633b435a5a3
75
{"created_at":"2015-08-04T17:28:03Z","entry_id":562810,"field1":"79.7","field2":"80.0","field3":"18.8","field4":null}
0
You have a String object. Use the indexOf() method to see if field3 exists in the string. If it does, find the : that follows the field3 entry. Then find the comma that follows that.
Create a substring starting after the colon, ending before the comma. Trim white space and then get rid of the start and end quotes.
Spent about 3 hours could not figure it out...I added this to my original and it works...But I don't think it's up to Pauls type standard....or even mine for that matter...Still a work in progress...Think I need a liitle spoon feeding on this one. If I told you what my day job was you would understand. Tried the indexof could not figure it out..will not give up..still working on it.
Serial.print(line);
readString += line; //makes the string readString
if (readString.length() >0) {
Serial.println(readString); //see what was received
field2 = readString.substring(652, 656); //get the first four characters
field3 = readString.substring(668, 672); //get the next four characters
Serial.println(field2); //print to serial monitor to see parsed results
Serial.println(field3);
int n1 = field2.toInt();
int n2 = field3.toInt();
