So, I have been able to follow the instructions and get the lux and luminosity values read through the com port. What I would like to do instead is read out the voltage values that correspond to the lux and luminosity values seen on the serial monitor.
I have tried using the DAC on the Arduino to analog write out the data, but I am not getting the return I expected. The TSL2591 SDA is connected to the A4 pin on the Arduino, and the DAC0 is on A0/D14.
I expected I would be able to read the input on A4 and map it to A0, then write it out from A0 to the serial monitor.
Any suggestions to help me? I can post some code if it would help.
Thank you!
Mark
