So I am doing a project which is tested using the Arduino Mega 2560. However, I cannot explicitly just use the Arduino for the final product. I have to create a PCB from scratch so my approach is to use easyeda.com to create a PCB that will have all of the components of this Arduino Mega 2560 basically imported and soldered directly to the board. The issue is, the provided schematic/PCB footprint already created has components on it which I don't know what exactly some of the components are. I would also like to remove the components and connections that deal with the USB capability for the Arduino Mega 2560 because I will be using strictly the Serial.
The recreated schematic and PCB model I am currently using is:
Would anyone be able to direct me to a model I could use for a PCB creation that already has all of the PCB footprints or at least the exact parts with the part numbers already there?
shows the minimal setup needed to build an UNO on a breadboard with the bare chip. The concept will be exactly the same for doing the Mega except the pin numbers will be different and there will be a lot more of them. The basic components needed will be the same. Look at the datasheet for the 2560 to see which pins to use for everything.
Find a way to import those into your chosen PCB design software and delete the parts of the schematic you don't want to bother with (or just leave them unpopulated).
I did my own Mega board, because I needed some Mega2560 pins which are not available on the Arduino Mega.
If you know eagle, then the link from johnwasser is excellent advice. There is a free, limited version of eagle.
I recreated the PCB in KiCad. I used all the parts as specified in
Some things to be aware of:
The atmega2560 chip is only available as SMD. So you will have to solder SMD, or get it done at some PCB manufacturing place. I use elecrow. (No advertisement intended, just my good experience with them)
follow the advice in the atmega datasheet about connecting all the Vcc and Gnd Pins, and the blocking capacitors, and positioning of the crystal.
your microcontroller will not have a bootloader. Include a ISP header on your PCB for burning the bootloader. You can use any arduino to build a bootloader.
if you plan to use one of the USB-serial adaptors, don't forget the capacitor in the reset line.
your first version of the PCB WILL have errors. Design the PCB in such a way as to facilitate troubleshooting: Expose test points, be generous with headers, don't pick the smallest SMD parts, think about the 5V power supply, include test LEDs, etc.
