am trying to make an obstacle avoiding robot. my sensing range is small. i tried to build using ir led transmitter and photodiode. but none of the circuits i tried out is working. the following are the few which i tried.
Which one are you using? The low range or high range one? You are going to want to use the high range one, if you aren’t already. If you are using this circuit, are you using the same values of components (outside of the op-amp; which based on the spec sheets I found, seem to be identical, just one has 4 op-amps in the package, whereas the other has only 2)? If not, can you post a schematic of what you are using with the values filled in?
Finally, can you post the schematic showing how you connected the system to the Arduino, as well as you code?
Pwoahh, they like to do it in a complicated way don’t they. I would just use an infa red LED with a resistor on a digital output and an IR sensor on an analog input. No extra crap necessary and for most things it would do you fine
