im a fresher in arduino. i need a loop stop code.. if input HIGH.. Attached for your ref pls help me
const int sensorIn = A0;
const int sensor2In = A1;
int mVperAmp = 100;
int LED =9;
int Relay = 12;
int IP = 7;
int IPState = 0;
double Voltage = 0;
double VRMS = 0;
double AmpsRMS = 0;
void setup(){
pinMode (LED,OUTPUT);
pinMode (IP,INPUT_PULLUP);
pinMode(Relay,OUTPUT);
void loop(){
IPState = digitalRead(IP);
if(IPState == HIGH) // i need a loop stop code in this place .. (if IPstate == low) run the loop after 10 seconds.
loop should start after 10 sec delay if IPstate ==low... if input HIGH loop should stop until input get low
Voltage = getVPP();
VRMS = (Voltage/2.0) *0.707;
AmpsRMS = (VRMS * 1000)/mVperAmp;
Serial.print(AmpsRMS);
Serial.println(" Amps RMS");
float getVPP()
float result;
int readValue;
int maxValue = 0;
int minValue = 1024;
uint32_t start_time = millis();
while((millis()-start_time) < 1000)
readValue = analogRead(sensorIn);
if (readValue > maxValue)
maxValue = readValue;
if (readValue < minValue)
minValue = readValue;
result = ((maxValue - minValue) * 5.0)/1024.0;
Serial.println(result);
if (result>1.0){
digitalWrite (LED,HIGH);
delay(100);
digitalWrite (Relay,HIGH);
delay (100);
digitalWrite(LED,LOW);
delay(100);
digitalWrite(Relay,LOW);
delay(100);
float result2;
int readValue2;
int maxValue2 = 0;
int minValue2 = 1024;
uint32_t start_time1 = millis();
while((millis()-start_time1) < 1000)
readValue2 = analogRead(sensor2In);
if (readValue2 > maxValue2)
maxValue2 = readValue2;
if (readValue2 < minValue2)
minValue2 = readValue2;
result2 = ((maxValue2 - minValue2) * 5.0)/1024.0;
Serial.println(result2);
if (result2>0.5 ){
delay(100);
digitalWrite(Relay,HIGH);
delay(100);
delay(100);
delay(100);
return result;
