Hi people,
I am thinking of establishing communication between two bots using bluetooth. Ive seen to transfer data via bluetooth, bluetooth module should be present in both the robots. It seems bluetooth with usb is cheap than serial. So is it possible to send data using this usb based bluetooth. If so, how?
Also if you go with xbees make sure which series you choose. series 1 should be cheaper and easier but series 2.5 you might need to do some research on.
