Help Regarding LED 11'inch TV interfacing with arduino and xbee for wireless com
Respected all,
I have a LED 11' inch TV . i want to use TV as a advertising display board using arduino uno and i want to interface xbee for wireless communication so i won't help regarding connectivity of TVout library and xbee library . for LED tv tvout library will work or not?? and is it possible to combine both TVout and xbee library.
Thanks & Regards
Nidhay S. Sheth
What sort of inputs has your TV got?
RCA plug input
Arduino three pin : sync , video and ground
RCA two pin : vin , ground
The RCA plug uses what is known as composite video where the sync and the video are mixed into one signal. The circuits to combine these two can be simple google for some choices.
ok thanks but i want to know about communication between xbee library and tvout library.is it possible to communicate between this two communication????
What do you want to communicate? The TV out uses a lot of resources of the processor so there is not much time for anything else. Do you know the output you get from TV out is very crude? Not much resoloution.
