Help regarding strange uart0 behavior
Hi all,
I have built a RPi hat with some temperature sensors on it which communicates with the RPi via uart0. And I get some weird behavior from the serialport.
I'm using an ATMEGA328P-AU clocked at 8 MHz. This causes me to having to double the baudrate in the Serial.begin() function compared to what the actual rate will be. Why is this and how can I change it? The fuses are set correctly.
In my main loop, I listen for incoming serial data as the first thing in each loop. I listen by if(Serial.available() > 0). For some reason I seem to get serialdata when I should not.
I am debugging the hat unconnected to the RPi, so there is no chance of the Pi being the issue.
I am entering HandleSerialComms() even when no serial data is sent. Is the an obvious reason for this that I am not seeing?
I am also not not able to read an ascii character correct most times I try to send a character.
Output is written just fine, so I don't think that timing is the issue either?
SYSTEM_STATE is just a state variable that can represent one of several states. 0= STOPPED.
  if(Serial.available()>0)
    HandleSerialComms();
  if(millis() - lastTime >= updateInterval)
    lastTime = millis();
    if( SYSTEM_STATE )
      runMeasurements();
zenseidk:
Have you configured the Arduino IDE for an 8Mhz device ?
I have not. How do I do this?
I found that the serial bug may actually be a hardware issue. Probably a bad soldering somewhere.
I have a second board that does not give me the same problem.
All right, both problems solved. Thank :slight_smile:
