Help regarding ThingsBoard and ESP8266 With Raspbery pi
Hello everyone,
I'm working on a project involving the ESP8266 Arduino Mega Wi-Fi board from Wemos, coupled with ThingsBoard for data management. My setup employs a Raspberry Pi Model 4 to serve as the ThingsBoard server. Initially, I successfully utilized a code to send temperature data from the ESP8266/Wemos Mega Wi-Fi board to the Raspberry Pi, which effectively received the data.
This board combines an Arduino Mega and an ESP8266 microcontroller. In the beginning, I established a ThingsBoard server on my Raspberry Pi, following a guide that I've linked here. This guide assisted me in configuring the Raspberry Pi 4 as a dedicated ThingsBoard server. Subsequently, I embarked in a different direction to enable the DHT11 sensor data to be displayed on a ThingsBoard dashboard. This process rendered the device active and operational.
Unfortunately, I misplaced the initial code, leading me to follow another guide to control the GPIO pins of the ESP8266. I successfully created a comprehensive dashboard, utilizing the provided JSON files and modifying them in line with instructions from the guide (linked here).
https://thingsboard.io/docs/samples/esp8266/gpio/
I adjusted the JSON files, imported the dashboard into ThingsBoard, and adapted the provided code by incorporating the necessary keys. However, upon uploading and executing the code, I encountered an error message indicating a failure to connect the NodeMCU to ThingsBoard.
This is the Example code
#include <ArduinoJson.h>
#include <PubSubClient.h>
#include <ESP8266WiFi.h>
#define WIFI_AP "YOUR_WIFI_AP"
#define WIFI_PASSWORD "YOUR_WIFI_PASSWORD"
#define TOKEN "ESP8266_DEMO_TOKEN"
#define GPIO0 0
#define GPIO2 2
#define GPIO0_PIN 3
#define GPIO2_PIN 5
char thingsboardServer[] = "demo.thingsboard.io";
WiFiClient wifiClient;
PubSubClient client(wifiClient);
int status = WL_IDLE_STATUS;
// We assume that all GPIOs are LOW
boolean gpioState[] = {false, false};
  // Set output mode for all GPIO pins
  pinMode(GPIO0, OUTPUT);
  pinMode(GPIO2, OUTPUT);
  delay(10);
  InitWiFi();
  client.setServer( thingsboardServer, 1883 );
  client.setCallback(on_message);
  if ( !client.connected() ) {
    reconnect();
  client.loop();
// The callback for when a PUBLISH message is received from the server.
void on_message(const char* topic, byte* payload, unsigned int length) {
  Serial.println("On message");
  char json[length + 1];
  strncpy (json, (char*)payload, length);
  json[length] = '\0';
  Serial.print("Topic: ");
  Serial.println(topic);
  Serial.print("Message: ");
  Serial.println(json);
  // Decode JSON request
  StaticJsonBuffer<200> jsonBuffer;
  JsonObject& data = jsonBuffer.parseObject((char*)json);
  if (!data.success())
    Serial.println("parseObject() failed");
    return;
  // Check request method
  String methodName = String((const char*)data["method"]);
  if (methodName.equals("getGpioStatus")) {
    // Reply with GPIO status
    String responseTopic = String(topic);
    responseTopic.replace("request", "response");
    client.publish(responseTopic.c_str(), get_gpio_status().c_str());
  } else if (methodName.equals("setGpioStatus")) {
    // Update GPIO status and reply
    set_gpio_status(data["params"]["pin"], data["params"]["enabled"]);
    client.publish("v1/devices/me/attributes", get_gpio_status().c_str());
String get_gpio_status() {
  // Prepare gpios JSON payload string
  JsonObject& data = jsonBuffer.createObject();
  data[String(GPIO0_PIN)] = gpioState[0] ? true : false;
  data[String(GPIO2_PIN)] = gpioState[1] ? true : false;
  char payload[256];
  data.printTo(payload, sizeof(payload));
  String strPayload = String(payload);
  Serial.print("Get gpio status: ");
  Serial.println(strPayload);
  return strPayload;
void set_gpio_status(int pin, boolean enabled) {
  if (pin == GPIO0_PIN) {
    // Output GPIOs state
    digitalWrite(GPIO0, enabled ? HIGH : LOW);
    // Update GPIOs state
    gpioState[0] = enabled;
  } else if (pin == GPIO2_PIN) {
    digitalWrite(GPIO2, enabled ? HIGH : LOW);
    gpioState[1] = enabled;
void InitWiFi() {
  Serial.println("Connecting to AP ...");
  // attempt to connect to WiFi network
  WiFi.begin(WIFI_AP, WIFI_PASSWORD);
    Serial.print(".");
  Serial.println("Connected to AP");
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    status = WiFi.status();
    if ( status != WL_CONNECTED) {
        Serial.print(".");
    Serial.print("Connecting to ThingsBoard node ...");
    // Attempt to connect (clientId, username, password)
    if ( client.connect("ESP8266 Device", TOKEN, NULL) ) {
      Serial.println( "[DONE]" );
      // Subscribing to receive RPC requests
      client.subscribe("v1/devices/me/rpc/request/+");
      // Sending current GPIO status
      Serial.println("Sending current GPIO status ...");
      Serial.print( "[FAILED] [ rc = " );
      Serial.print( client.state() );
      Serial.println( " : retrying in 5 seconds]" );
      // Wait 5 seconds before retrying
      delay( 5000 );
This is the error I am presented with
I'm reaching out to the community in hopes of receiving assistance regarding this issue. Specifically, I'm seeking guidance on the process of GPIO pin control through ThingsBoard using a Raspberry Pi as the dedicated server. Additionally, I'm curious about the comparative advantages of using a Raspberry Pi as the server versus utilizing the ThingsBoard demo server. It would be great if someone helped me set this up.....
My goal is to make a dashboard for an electric vehicle which can be accessed from anywhere so I am starting with GPIO Pin Controlling and finding my way through...
I am ready to start the code and dashboards from the basics.
Your insights and support would be greatly appreciated. Thank you in advance for your assistance.
