Help Regarding ultrasonic sensor
hello
i have seen the interfacing of ping ultrasonic sensor (From Parallax) with arduino . In India where can i get the ping sensor if there is any vendor available in India please post the contact details .
I have choosen the ultrasonic sensor from sunrom.com
link : Sunrom Electronics
is both the sensors control is same can i interface with the same code as given for the ping sensor in arduino tutorial on the following link http://arduino.cc/en/Tutorial/Ping?from=Tutorial.UltrasoundSensor
if the sensor is bought from sunrom
Thanks in Advance
The device you linked does not appear to have the same interface as the Ping sensor
http://www.sunrom.com/files/1166-datasheet.pdf
It looks like it just continuously outputs ASCII distances in centimetres.
There's example code there that doesn't look too much trouble to port to the Arduino.
Unless you have some way of turning these off or otherwise controlling the device, it looks like this sensor would not be a good choice in a system with multiple similar sensors; they could easily interfere with each other.
The datasheet says that the sensor needs +5V and 15mA. Power it from a digital pin. Set the pin high to turn the sensor on; set the pin low to turn it off.
I'd guess that the 15mA is an average; I wouldn't be surprised (Heck, I'd expect it) if this was higher during a Tx pulse.
