I'd like to know how to control a relay on a schedule, at some specific time, for example: starts at 7:55:00 and ends at 7:59:23.
I'm using Arduino Yun and process is used to get the date online.
Any help is welcome.
Thanks in advance.
Thanks in advance.
Set a flag to tell you whether your relay was set on or off.
Run a loop. Test for time and if it is greater than start time && less than stop time and relay is off, turn it on and set the flag to on. If it is after start time, and the less than finish time && the relay is on you don't need to do anything.
If it is after finish time && the relay is on, turn it off, and set the flag to off.
You set the relay on or off by writing to a digital pin. The flag in effect stores the value you wrote to the pin.
Thank you!!
I understand, but I need an example, please.
Thanks again.
Look at the many things at once example at the top of the programming forum.
Check this one
http://www.joestechblog.com/2011/11/13/chicken-light-relay-timer/
However, DS1307 can be replaced by DS3231 for higher accuracy. However, this example doesn't uses yun. But you can get the concept
Thanks a lot!
