Help Replacing Button Calls with Adafruit Commands - 16x2 lcd shield
Hi all,
I am trying to make a menu for a project, and have been losing my mind the last couple days trying everything.
I am using an Adafruit 16x2 rgb LCD shield, that uses the I2C pins, A4 & A5, (link provided at end)
I found an example of basically what I want, but the buttons are unresponsive.
The author states " the Adafruit library reads buttons with lcd.readButtons() while the shield I used needs to measure analog voltage drop across the buttons. You'll have to go through the code and replace my button calls with the Adafruit commands. "
I just have no idea how or where to do this. He talks slightly about it in step 3, but I am completely lost. Everything I try to do does not work.
Any help would be very extremely greatly life saving!
Link to Menu Example -
Link of RGB LCD used
(Couldn't copy code due to length, is attached.)
AdafruitRGBLCD_Menu_Program.ino (15 KB)
