Help request for using & understanding FADE control
So I’m having fun using the IR remote making different patterns for Christmas lights.
I found some code for creating a fading effect although the actual link calls it breathing.
When I added this function, the time lag has become excessively long.
Could someone help with explaining what might be causing such a long wait time ?
When I push the remote buttons for JUMP3 or JUMP7, they both work well and switch nicely but after pushing FADE3, I might as well power down and restart.
any and all comments welcomed
#include "IRremote.h"
#define PIN 6
Adafruit_NeoPixel strip = Adafruit_NeoPixel(150, PIN, NEO_GRB + NEO_KHZ800);
int a = 3;
int c = 0;
int d = 5;
int m = 0;
int receiver = 3;
const unsigned long RedLEDinterval = 700;
const unsigned long OrangeLEDinterval = 700;
unsigned long RedLEDtimer;
unsigned long OrangeLEDtimer;
unsigned long GreenLEDtimer;
unsigned long BlueLEDtimer;
IRrecv irrecv(receiver);
decode_results results;
  irrecv.enableIRIn();
  RedLEDtimer = millis ();
  OrangeLEDtimer = millis ();
  Serial.println("IR Receiver Raw Data + Button Decode Test");
  if (irrecv.decode(&results))
    irrecv.resume();
  switch(results.value)
  case 0xFF20DF:
    Serial.println("JUMP 3");
    JUMP3();
  case 0xFFA05F:
    Serial.println("JUMP 7");
    JUMP7();
  case 0xFF609F:
    Serial.println("FADE 3");
    FADE3 ();
  default:
    Serial.println("Waiting");
  delay(d*50);
void JUMP3()
  if ( (millis () - RedLEDtimer) >= RedLEDinterval)
    toggleRedLED ();
void JUMP7()
  if ( (millis () - OrangeLEDtimer) >= OrangeLEDinterval)
    toggleOrangeLED ();
void toggleRedLED ()
  strip.begin();
  strip.show();
  int a = 3;
  for (int c = 1; c < 150; c = c + a)
    strip.setPixelColor(c, 0, 100, 0);
  strip.show();
  GreenLEDtimer = millis ();
  delay(d*10);
  for (int c = 2; c < 150; c = c + a)
    strip.setPixelColor(c, 0, 0, 100);
  strip.show();
  BlueLEDtimer = millis ();
  delay(d*10);
    strip.setPixelColor(c, 100, 0, 0);
  strip.show();
  delay(d*10);
  strip.show();
  delay(d*10);
  for (int c = 0; c < 150; c = c + a)
  strip.show();
  delay(d*10);
  strip.show();
  delay(d*10);
  strip.show();
  delay(d*10);
  strip.show();
  delay(d*10);
void FADE3 ()
  int TOTAL_LEDS = 150;
  float MaximumBrightness = 150;
  float SpeedFactor = 0.10;
  for (int m = 0; m < 100; m++)
    float intensity = MaximumBrightness /2.0 * (1.0 + sin(SpeedFactor * m));
    strip.setBrightness(intensity);
    for (int ledNumber=0; ledNumber<TOTAL_LEDS; ledNumber++)
      strip.begin();
    strip.show();
    int a = 3;
    strip.show();
    delay(d*10);
    strip.show();
    delay(d*10);
    strip.show();
    delay(d*10);
    strip.show();
    delay(d*10);
    strip.show();
    delay(d*10);
    strip.show();
    delay(d*10);
    strip.show();
    delay(d*10);
    strip.show();
    delay(d*10);
http://forums.adafruit.com/viewtopic.php?f=47&t=41143#p249333
Re: NEOPIXEL brightness control
by justinw3115 on Fri Feb 07, 2014 3:19 pm
I am fairly new to programming, arduino, and neopixels. I wanted a similar effect. I have a good friend, who is a programmer help me out. This is the code he wrote, and here is a video of what it did. http://www.youtube.com/watch?v=BYrzIdlkVjc
//Written by: Jason Yandell
int TOTAL_LEDS = 60;
float MaximumBrightness = 255;
float SpeedFactor = 0.008; // I don't actually know what would look good
float StepDelay = 5; // ms for a step delay on the lights
// Make the lights breathe
for (int i = 0; i < 65535; i++) {
// Intensity will go from 10 - MaximumBrightness in a "breathing" manner
float intensity = MaximumBrightness /2.0 * (1.0 + sin(SpeedFactor * i));
// Now set every LED to that color
for (int ledNumber=0; ledNumber<TOTAL_LEDS; ledNumber++) {
strip.setPixelColor(ledNumber, 0, 0, 255);
strip.show();
//Wait a bit before continuing to breathe
delay(StepDelay);
It's pointless to try to debug code that uses millis() and delay(). Pick ONE method and stick with it.
sin() takes a value in radians. One would expect this loop to iterate such that the argument to sin() ranged from 0 to pi or 0 to 2pi. Iterating so that the values range from 0 to 10 doesn't make sense.
