Help requested; NANO vs UNO; same code does not play the same in both modules
Requesting help in understanding programming differences, web page suggests very similar but when I load the code in the NANO module, DIY2 and DIY5 functions fail to stay active, acts like a button was pushed. Loaded same code into UNO module and the function stays active until I select something else. I swapped DIY2 with DIY3 , did the same for DIY5 and DIY6 but changing locations on remote did not solve problem--both DIY's still stop with programming the NANO module.
Open to suggestions and comments
// Binary sketch size: 14,514 bytes (of a 30,720 byte maximum) for loading into NANO
// Binary sketch size: 14,514 bytes (of a 32,256 byte maximum) for loading UNO
#include "IRremote.h"
#define PIN 6
Adafruit_NeoPixel strip = Adafruit_NeoPixel(150, PIN, NEO_GRB + NEO_KHZ800);
int a = 3;
int c = 0;
int d = 5;
int TOTAL_LEDS = 150;
int r =0;
int x = 0;
int b = 0;
int z = 0;
int y = 0;
int pos = 0, dir = 1;
int j = 0;
int direction=1;
int receiver = 3;
const unsigned long RedLEDinterval2 = 700;
const unsigned long OrangeLEDinterval = 700;
unsigned long RedLEDtimer2;
unsigned long OrangeLEDtimer;
IRrecv irrecv(receiver);
decode_results results;
  irrecv.enableIRIn();
  RedLEDtimer2 = millis ();
  OrangeLEDtimer = millis ();
  Serial.println("IR Receiver Raw Data + Button Decode Test");
  if (irrecv.decode(&results))
    irrecv.resume();
  Serial.println(results.value, HEX);
  switch(results.value)
  case 0xFF30CF:
    Serial.println("DIY 1");
    DIY1();
  case 0xFFB04F:
    Serial.println("DIY 2");
    DIY2();
  case 0xFF708F:
    Serial.println("DIY 3");
    DIY3();
  case 0xFF10EF:
    Serial.println("DIY 4");
    DIY4();
  case 0xFF906F:
    Serial.println("DIY 5");
    DIY5();
  case 0xFF50AF:
    Serial.println("DIY 6");
    DIY6();
  default:
    Serial.println("Who Are You?");
    Serial.println(results.value,HEX);
  delay(d*50); // d = 5
void DIY1(){
  int b = 75;
  strip.begin();
  strip.show();
  strip.setBrightness(100);
  for (int z = 74, y = 75; z<x, y>r; z++, y--)
    strip.setPixelColor(z, 150, 150, 150);
    strip.setPixelColor(z+1, 150, 150, 150);
    strip.setPixelColor(y, 150, 150, 150);
    strip.setPixelColor(y-1, 150, 150, 150);
    strip.show();
    delay(d*10);
    strip.setPixelColor(b, 0, 0, 150);
    strip.setPixelColor(z, 0, 0, 0);
    b++;
    strip.setPixelColor(y, 0, 0, 0);
    strip.show();
  strip.setPixelColor(r, 150, 0, 0);
  strip.setPixelColor(x, 0, 0, 150);
  strip.show();
  x--;
  r++;
  if (x<74)
    x=75;
  if (r>76)
    r=0;
  delay(d*10);
void DIY2(){
  if ( (millis () - RedLEDtimer2) >= RedLEDinterval2)
    RedWhiteBlue();
void DIY3 (){
  strip.begin();
  strip.show();
  strip.setPixelColor(pos - 6, 0x110000);
  strip.setPixelColor(pos - 5, 0x880000);
  strip.setPixelColor(pos - 4, 0xFF0000);
  strip.setPixelColor(pos - 3, 0xFF0000);
  strip.setPixelColor(pos - 2, 0XFFFFFF);
  strip.setPixelColor(pos - 1, 0XFFFFFF);
  strip.setPixelColor(pos    , 0xFFFFFF);
  strip.setPixelColor(pos + 1, 0xFFFFFF);
  strip.setPixelColor(pos + 2, 0xFFFFFF);
  strip.setPixelColor(pos + 3, 0x0000FF);
  strip.setPixelColor(pos + 4, 0x0000FF);
  strip.setPixelColor(pos + 5, 0x000088);
  strip.setPixelColor(pos + 6, 0x000011);
  strip.show();
  for(j=-2; j<= 2; j++)
    strip.setPixelColor(pos+j, 0);
  pos += dir;
  if(pos < 0) {
    pos = 1;
    dir = -dir;
  else if(pos >= strip.numPixels())
    pos = strip.numPixels() - 2;
    dir = -dir;
void DIY4(){
  b = 75;
  strip.setBrightness(140);
  strip.begin();
  strip.show();
  for (z = 74, y = 75; z<x, y>r; z++, y--)
    strip.setPixelColor(z, 160, 42, 11);
    strip.setPixelColor(z+1, 160, 42, 11);
    strip.setPixelColor(y, 160, 42, 11);
    strip.setPixelColor(y-1, 160, 42, 11);
    strip.show();
    delay(d*5);
    strip.setPixelColor(b, 30, 5, 0);
    b++;
    strip.show();
  strip.setPixelColor(r, 30, 5, 0);
  strip.setPixelColor(x, 30, 5, 0);
  strip.show();
  x--;
  r++;
  if (x<74)
    x=75;
  if (r>75)
    r=0;
  delay(d*5);
void DIY5(){
  float MaximumBrightness = 200;
  float SpeedFactor = 0.12;
  float StepDelay = 7;
  for (int m = 0; m < 100; m++)
    float intensity = MaximumBrightness /2.0 * (1.0 + sin(SpeedFactor * m));
    strip.setBrightness(intensity);
    for (int ledNumber=0; ledNumber<TOTAL_LEDS; ledNumber++)
      strip.setPixelColor(ledNumber, 50, 14, 2);
    strip.show();
    delay(StepDelay);
void DIY6(){
  strip.begin();
  strip.show();
  strip.setPixelColor(pos - 5, 25, 5, 0);
  strip.setPixelColor(pos - 4, 25, 5, 0);
  strip.setPixelColor(pos - 3, 25, 5, 0);
  strip.setPixelColor(pos - 2, 110, 22, 5);
  strip.setPixelColor(pos - 1, 110, 22, 5);
  strip.setPixelColor(pos    , 110, 22, 5);
  strip.setPixelColor(pos + 1, 110, 22, 5);
  strip.setPixelColor(pos + 2, 110, 22, 5);
  strip.setPixelColor(pos + 3, 25, 5, 0);
  strip.setPixelColor(pos + 4, 25, 5, 0);
  strip.setPixelColor(pos + 5, 25, 5, 0);
  strip.show();
  for(j=-2; j<= 2; j++) strip.setPixelColor(pos+j, 0);
  pos += dir;
  if(pos < 0)
    pos = 1;
    dir = -dir;
    dir = -dir;
void RedWhiteBlue(){
// int a = 3
  strip.begin();
  strip.show();
  int SlugDelay = 250;
  for (int c = 0; c < TOTAL_LEDS; c = c + a)
    strip.setPixelColor(c, 100, 0, 0);
  strip.show();
  delay(SlugDelay);
    strip.setPixelColor(c, 0, 0, 0);
  strip.show();
  delay(SlugDelay);
  for (int c = 1; c < TOTAL_LEDS; c = c + a)
    strip.setPixelColor(c, 100, 100, 100);
  strip.show();
  delay(SlugDelay);
  strip.show();
  delay(SlugDelay);
  for (int c = 2; c < TOTAL_LEDS; c = c + a)
    strip.setPixelColor(c, 0, 0, 100);
  strip.show();
  delay(SlugDelay);
  strip.show();
  delay(SlugDelay);
I'd start by moving constant strings into flash where possible, then try reducing the size of constants and variables where sensible and possible.
    irrecv.resume();
See if you received anything from the IR. If so, reset to get the next value. Then, regardless of whether or not anything was received, use the received value. That doesn't make sense to me.
DIY1() is a piss-poor name for a function. Can you see how difficult programming the Arduino would be if digitalRead() was called FUN12()? Do you see that your names make no more sense?
Thank you for responding to my question; the names DIY were derived from the buttons on the remote--I will agree not the best names but at this early stage of understanding how to work the IR remote and the code, I thought it would be easier for my association of the buttons and functions, will be more creative next time around.
The serial monitor reports "Who Are You?" indicating that the receiver is no longer receiving any response from the remote. When I press DIY2, then "FFB04F" is shown along with DIY 2 only for perhaps 6 cycles. By cycles, I am referring to the listing of DIY 2 which then it drops off the monitor and followed by FFFFFF and who Are You.
This only happens when using the NANO and does not happen with the UNO
"I'd start by moving constant strings into flash where possible, then try reducing the size of constants and variables where sensible and possible."
I will try your suggestion although how does that differ between the NANO and the UNO ?
techIV:
In the event you have a Nano prior to v3.0, they were packaged with Atmega168 chips. These have half the RAM and Flash of the 328 chips packaged with modern Unos.
Running out of RAM can cause all sorts of unpredictable and random problems. When you pass strings to functions like that, they're packaged up in RAM and consume a lot of it. It's generally good practise to store strings in flash if you can so as to save the much more limited RAM.
Hope this helps.
