Help required regarding Impovement in torque of MyActuator RMD X-15-400
I am currently working on a foot robot and using RMD X15-400 motor from my actuator using arduino mega. The motor uses CAN communication , and has a VESC driver. the thing is while I was testing the motor via VESC tool , the torque outputs I received were really good , especially its static torque , I tried my best to push down using a moment arm but was unable to do so, however, I am trying to apply the same thing using arduino mega now using the motors' Force-position hybrid mode , but there is way too much damping and not enough torque , regardless of whatever changes I make to the KP and KD , I tried including feedforward torque in the code too , but that just overshoots the position , its really confusing and concerning, please someone help me out, I am sharing my code below:
#include <SPI.h>
#include <mcp_can.h>
// Value Limits for Parameters
#define P_MIN -12.5f
#define P_MAX 12.5f
#define V_MIN -18.0f
#define V_MAX 18.0f
#define KP_MIN 0.0f
#define KP_MAX 500.0f
#define KD_MIN 0.0f
#define KD_MAX 5.0f
#define T_MIN -150.0f
#define T_MAX 150.0f
float kp_in =  250.0f;
float kd_in = 3.75f;
float v_in = 0.0f;
float t_ff = 0.0f;
// CS Pin for MCP2515
const int spiCSPin = 49;
MCP_CAN CAN(spiCSPin);
// CAN ID
const long CAN_ID = 0x02; // Motor ID
// Global variable to remember last commanded position
float lastPosition = 0.0f;
  if (CAN.begin(MCP_ANY, CAN_1000KBPS, MCP_8MHZ) == CAN_OK) {
    Serial.println("MCP2515 Initialized Successfully!");
    Serial.println("Error Initializing MCP2515...");
    while (1);
  CAN.setMode(MCP_NORMAL);
  Serial.println("CAN Module set to NORMAL mode.");
  // Always check and print CAN feedback continuously
  if (CAN_MSGAVAIL == CAN.checkReceive()) {
    unpack_reply();
  printFeedback();
  if (Serial.available() > 0) {
    char command = Serial.read();
    if (command == 'e') {
      // "e": Ramp to 0 slowly, wait 2 s, then ramp to 90° (1.5708 rad) and hold
      delay(1500);
      if (rampToPosition(lastPosition, 0.0f)) {
        delay(1500); // 2-second delay at 0 rad
        if (rampToPosition(0.0f, 0.19198621f)) {
          holdPosition(0.19198621f);
    else if (command == 'g') {
      // "g": Ramp to 0 slowly and hold there
        holdPosition(0.0f);
    else if (command == 'f') {
      // "f": Immediately stop the motor
      stopMotor();
// Helper: Ramp the motor from startPos to targetPos slowly.
// Returns false if aborted because 'f' was pressed.
bool rampToPosition(float startPos, float targetPos) {
  const int steps = 25;        // number of incremental steps
  float stepSize = (targetPos - startPos) / steps;
  for (int i = 1; i <= steps; i++) {
    // immediate stop even during ramping:
      char newCommand = Serial.read();
      if (newCommand == 'f') {
        stopMotor();
        return false; // abort ramping
    float pos = startPos + i * stepSize;
    sendCmd(CAN_ID, pos, v_in, 12.0, 0.5, t_ff);
    lastPosition = pos;
    delay(100);
    printFeedback();
  return true;
// Helper: Hold the motor at the specified position until a new command (f, e, or g) is received.
void holdPosition(float pos) {
  lastPosition = pos;
  while (true) {
    // Check if a new command has been pressed:
        stopMotor();
        return;
      else if (newCommand == 'g') {
        // If "g" is pressed while holding, ramp to 0 and then hold at 0.
          holdPosition(0.0f);
        return;
      else if (newCommand == 'e') {
        // If "e" is pressed while holding, restart the e sequence.
          delay(2000);
        return;
    // Continually command the current holding position:
    sendCmd(CAN_ID, pos, v_in, kp_in, kd_in, t_ff);
    delay(100);
    printFeedback();
// Stop the motor immediately.
void stopMotor() {
  sendCmd(CAN_ID, 0.0f, 0.0f, 0.0f, 0.0f, 0.0f);
  Serial.println("Motor stopped.");
// Function to send motor command via CAN
void sendCmd(long canId, float pos, float vel, float kp, float kd, float torque) {
  byte buf[8];
  unsigned int p_int = float_to_uint(pos, P_MIN, P_MAX, 16);
  unsigned int v_int = float_to_uint(vel, V_MIN, V_MAX, 12);
  unsigned int kp_int = float_to_uint(kp, KP_MIN, KP_MAX, 12);
  unsigned int kd_int = float_to_uint(kd, KD_MIN, KD_MAX, 9);
  unsigned int t_int = float_to_uint(torque, T_MIN, T_MAX, 12);
  buf[0] = 0x00 | (kp_int >> 7);
  buf[1] = ((kp_int & 0x7F) << 1) | ((kd_int & 0x100) >> 8);
  buf[2] = kd_int & 0xFF;
  buf[3] = p_int >> 8;
  buf[4] = p_int & 0xFF;
  buf[5] = v_int >> 4;
  buf[6] = ((v_int & 0x0F) << 4) | (t_int >> 8);
  buf[7] = t_int & 0xFF;
  CAN.sendMsgBuf(canId, 0, 8, buf);
// Function to unpack and process feedback from CAN bus
void unpack_reply() {
  long unsigned int rxId;
  byte len = 0;
  byte buf[8];
  CAN.readMsgBuf(&rxId, &len, buf);
  // Extract data from buffer
  uint8_t message_type = (buf[0] >> 5) & 0x07; // First 3 bits of buf[0]
  uint8_t error_msg = buf[0] & 0x1F;           // Last 5 bits of buf[0]
  unsigned int output_pos = (buf[1] << 8) | buf[2]; // Motor output position (16 bits)
  unsigned int output_speed = ((buf[3] << 4) | (buf[4] >> 4)) & 0x0FFF; // Motor output speed (12 bits)
  unsigned int phase_curr = ((buf[4] & 0x0F) << 8) | buf[5]; // Motor phase current (12 bits)
  uint8_t motor_temp = buf[6];          // Motor temperature (8 bits)
  uint8_t mos_temp = buf[7];            // MOS temperature (8 bits)
  // Convert motor temperature and MOS temperature to actual values
  float actual_motor_temp = (motor_temp - 50.0) / 2.0;
  float actual_mos_temp = (mos_temp - 50.0) / 2.0;
  // Convert unsigned ints to float values for position and speed
  float actual_position = uint_to_float(output_pos, P_MIN, P_MAX, 16);
  float actual_speed = uint_to_float(output_speed, V_MIN, V_MAX, 12);
  float actual_phase_current = uint_to_float(phase_curr, -200.0f, 200.0f, 12);
  float torque = (actual_phase_current * 2.32 ); //for torque
  Serial.print("Message Type: ");
  Serial.print(message_type);
  Serial.print(", Error Message: ");
  Serial.print(error_msg);
  Serial.print(" Output Position: ");
  Serial.print(actual_position, 16);
  Serial.print(" rad, Speed: ");
  Serial.print(actual_speed, 2);
  Serial.print(" rad/s, Current= ");
  Serial.print(actual_phase_current, 2);
  Serial.print(" A, Torque: ");
  Serial.print(torque, 2);
  Serial.print(" Nm/A, Motor Temp: ");
  Serial.print(actual_motor_temp, 1);
  Serial.print(" °C, MOS Temp: ");
  Serial.print(actual_mos_temp, 1);
  Serial.println(" °C");
// Helper function to print motor feedback
void printFeedback() {
    unpack_reply();
// Conversion from float to uint
unsigned int float_to_uint(float x, float x_min, float x_max, int bits) {
  float span = x_max - x_min;
  unsigned int result = 0;
  if (bits == 9) {
    result = (unsigned int)((x - x_min) * 511.0 / span);
  } else if (bits == 12) {
    result = (unsigned int)((x - x_min) * 4095.0 / span);
  } else if (bits == 16) {
    result = (unsigned int)((x - x_min) * 65535.0 / span);
  return result;
// Conversion from uint to float
float uint_to_float(unsigned int x_int, float x_min, float x_max, int bits) {
  float result = 0;
  if (bits == 9) {
    result = ((float)x_int) * span / 511.0 + x_min;
    result = ((float)x_int) * span / 4095.0 + x_min;
    result = ((float)x_int) * span / 65535.0 + x_min;
  return result;
