HELP - Rest API Server on ESP32
Hello
I'm studying and testing ways I can create a REST Api server on ESP32.
I understood how it works and locally it works very well. However, how could I get third parties to use this server. How could I make him not local?
I'm quite new to this Web Server issue in Arduino IDE and I can't find any similar examples.
Could anyone tell me how I could do this?
#include "Arduino.h"
#include <WiFi.h>
#include <WiFiClient.h>
#include <WebServer.h>
#include <ESPmDNS.h>
#include <ArduinoJson.h>
const char* ssid = "wifiTest";
const char* password = "k3yc0d3";
WebServer server(80);
void getHelloWord() {
  server.send(200, "text/json", "{\"name\": \"Hello world\"}");
// Define routing
void restServerRouting() {
  server.on("/", HTTP_GET, []() {
    server.send(200, F("text/html"),
                F("Welcome to the REST Web Server"));
  server.on(F("/helloWorld"), HTTP_GET, getHelloWord);
// Manage not found URL
void handleNotFound() {
  String message = "File Not Found\n\n";
  message += "URI: ";
  message += server.uri();
  message += "\nMethod: ";
  message += (server.method() == HTTP_GET) ? "GET" : "POST";
  message += "\nArguments: ";
  message += server.args();
  message += "\n";
  for (uint8_t i = 0; i < server.args(); i++) {
    message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
  server.send(404, "text/plain", message);
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  Serial.println("");
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected to ");
  Serial.println(ssid);
  Serial.print("IP address: ");
  if (MDNS.begin("esp32Test")) {
    Serial.println("MDNS responder started");
  // Set server routing
  restServerRouting();
  // Set not found response
  server.onNotFound(handleNotFound);
  // Start server
  server.begin();
  Serial.println("HTTP server started");
  server.handleClient();
Thank you!
The posted code is a very limited web server (which is ignoring standards BTW) and not a REST API server.
Define "third parties"!
That's a network problem and isn't related to Arduino. That solution to that is routing and probably port forwarding but it depends solely on the network equipment you're using.
