Ive spent hours trying to figure this out and I give up. Any help would be more than greatly appreciated.
I have this sequence for a relay. It opens and closes for a sequence it needs to run. I have a sonar sensor and I need it to restart the sequence when an object is detected less than 70 cm away. As a begginer, ive spent at least 8 hours trying to figure this out but I give up. Your solution is my last hope!
Ive labeled where exactly im having trouble. Thank you so much for your help.
//Begin
#define echoPin 10
#define trigPin 12
long duration;
long distance;
void(*resetFunc)(void) = 0;
pinMode(echoPin, INPUT);
pinMode(trigPin, OUTPUT);
pinMode(3, OUTPUT);
Serial.print("Restart");
// Tap Sequence
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = duration/58.2;
Serial.print(distance);
delay(50);
[b]//this is the code I need to inturupt and start again if the sonar senses something
[/b]
//start
if (distance < 70) resetFunc();
digitalWrite(3, LOW);
delay(4400);
digitalWrite(3, HIGH);
delay(3500);
delay(2800);
delay(2000);
while (1) {};
//end
distance = duration / 58.2;
delay(50);
My latest attempt was putting
in between every change of LOW or HIGH of the relay but the value read from the sensor freezes and doesnt update after the relay code has started.
