HELP!! RFID with Arduino
Hello all,
I have the RFID readers RC255 and Im trying to have 4 sensors and cards for a puzzle game i am making. I have a code that gets 1 rfid reader to make pin 3 go high but I need it to only do that when all 4 cards are sensed. How would I continue the code?
#include <SPI.h>
#include <RFID.h>
#define SS_PIN 10
#define RST_PIN 9
RFID rfid(SS_PIN,RST_PIN);
int power = 7;   // pin not used
int led = 3;       // pin output to relay #1
int serNum[5];
* This integer should be the code of Your Mifare card / tag
int cards[][5] = {{208,231,107,27,71}};
bool access = false;
void setup(){
    SPI.begin();
    rfid.init();
* define VMA100 (UNO) pins 7 & 8 as outputs and put them LOW
    pinMode(led, OUTPUT);
    pinMode (power,OUTPUT);
    digitalWrite(led, LOW);
    digitalWrite (power,LOW);
void loop(){
    if(rfid.isCard()){
        if(rfid.readCardSerial()){
            Serial.print(rfid.serNum[0]);
            Serial.print(" ");
            Serial.print(rfid.serNum[1]);
            Serial.print(" ");
            Serial.print(rfid.serNum[2]);
            Serial.print(" ");
            Serial.print(rfid.serNum[3]);
            Serial.print(" ");
            Serial.print(rfid.serNum[4]);
            Serial.println("");
            for(int x = 0; x < sizeof(cards); x++){
              for(int i = 0; i < sizeof(rfid.serNum); i++ ){
                  if(rfid.serNum[i] != cards[x][i]) {
                      access = false;
                      access = true;
              if(access) break;
       if(access){
           Serial.println("Welcome Robert ");
* Valid card : Switch ON the LED for 1000 ms (1 second)
           digitalWrite(led, HIGH);
* Valid card : Switch ON the POWER PIN for 2000 ms (2 seconds)), the POWER PIN can activate for example a relais, controlling a doorlock)
           digitalWrite(power, HIGH);
           delay(2000);
           digitalWrite(power, LOW);
           access = false;
* NON-Valid card : switch ON and OFF the LED twice for 0,5 seconds
           Serial.println("FUCK YOU!");
    rfid.halt();
RFID.ino (2.31 KB)
