HELP - RTC DS1302 e um RELE - desligar às 8:00 até 19:00 horas.
Preciso de uma rotina de sketch para desligar um rele às 8:00 até 19:00 horas, que se adapte ao sketch abaixo. Agradeço antecipadamente a ajuda.
// VCC5 +GND / RST=5 / DAT=6 / CLK=7 (PINS 5, 6 E 7)
// Example sketch for interfacing with the DS1302 timekeeping chip.
// Copyright (c) 2009, Matt Sparks
// All rights reserved.
// http://quadpoint.org/projects/arduino-ds1302
#include <stdio.h>
#include <DS1302.h>
namespace {
// Set the appropriate digital I/O pin connections. These are the pin
// assignments for the Arduino as well for as the DS1302 chip. See the DS1302
// datasheet:
//   http://datasheets.maximintegrated.com/en/ds/DS1302.pdf
const int kCePin   = 5;  // Chip Enable
const int kIoPin   = 6;  // Input/Output
const int kSclkPin = 7;  // Serial Clock
// Create a DS1302 object.
DS1302 rtc(kCePin, kIoPin, kSclkPin);
String dayAsString(const Time::Day day) {
 switch (day) {
   case Time::kSunday: return "Sunday";
   case Time::kMonday: return "Monday";
   case Time::kTuesday: return "Tuesday";
   case Time::kWednesday: return "Wednesday";
   case Time::kThursday: return "Thursday";
   case Time::kFriday: return "Friday";
   case Time::kSaturday: return "Saturday";
 return "(unknown day)";
void printTime() {
 // Get the current time and date from the chip.
 Time t = rtc.time();
 // Name the day of the week.
 const String day = dayAsString(t.day);
 // Format the time and date and insert into the temporary buffer.
 char buf[50];
 snprintf(buf, sizeof(buf), "%s %04d-%02d-%02d %02d:%02d:%02d",
          day.c_str(),
          t.yr, t.mon, t.date,
          t.hr, t.min, t.sec);
 // Print the formatted string to serial so we can see the time.
 Serial.println(buf);
}  // namespace
 // Initialize a new chip by turning off write protection and clearing the
 // clock halt flag. These methods needn't always be called. See the DS1302
 // datasheet for details.
  rtc.writeProtect(false);
  rtc.halt(false);
 // Make a new time object to set the date and time.
 // Sunday, September 22, 2013 at 01:38:50.
  //Time t(2018, 7, 2, 12, 42, 50, Time::kMonday);
 // Set the time and date on the chip.
  //rtc.time(t);
// Loop and print the time every second.
 printTime();
 printt.hr();
Sinceramente, tentaste resolver isto por ti próprio?
Uma pesquisa no fórum dará mais do que um (eu arriscaria 10) resultado completo para esta aplicação... se procurares online então deves ter bastantes mais exemplos.
Coloca aqui uma tentative, por muito vaga que seja e alguém te indicará o caminho.
