I am currently building something, and it works fine as I am testing the device.
Basically the project would scan student RFID cards, then record another set of RFID cards to their accounts(in the SD card).
All is going well, but until I add more “Student Accounts”, the data that was stored before cannot be read anymore, but as i test the card, the data is there, but it just doesn’t seem to be read when the new code is flashed.
Here’s a copy of the code:
#include <SoftwareSerial.h>
#include <SD.h>
SoftwareSerial RFID(2, 3);
int i;
int c;
int pi;
String pie;
String readID;
String readB;
String cID;
String cB;
String bookS;
String BB;
int R = 6;
int B = 5;
int Re = 7;
RFID.begin(9600);
pinMode(R, INPUT);
pinMode(B, INPUT);
pinMode(Re, INPUT);
while (!Serial)
Serial.print("Initializing SD card...");
pinMode(10, OUTPUT);
if (!SD.begin(4)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
void scan()
if (RFID.available() > 0)
i = RFID.read();
c = c + 1;
pie += i;
if (c == 14)
c = 0;
pi = 0;
readID = pie;
pie = "";
int Rx = digitalRead(R);
int Bx = digitalRead(B);
int Rex = digitalRead(Re);
if ((Rx == 1))
readS();
Rx = 0;
if ((Rx == 0))
if ((Bx == 1))
borrow();
Bx = 0;
if ((Bx == 0))
if ((Rex == 1))
returnBooks();
Rex = 0;
if ((Rex == 0))
void readS()
scan();
if ((readID == "24848484848565555565270663"))
Serial.println("Oginne Lapuz");
cID = readID;
File oginneFile = SD.open("oginne.txt");
if (oginneFile) {
while (oginneFile.available())
Serial.write(oginneFile.read());
oginneFile.close();
Serial.println("No Borrowed books");
readID = "";
i = 0;
bookS = "";
if ((readID == "24848484848566556576851683"))
Serial.println("Darryl Cacho");
cID = readID;
File darrylFile = SD.open("darryl.txt");
if (darrylFile) {
while (darrylFile.available())
Serial.write(darrylFile.read());
darrylFile.close();
readID = "";
i = 0;
bookS = "";
if ((readID == "24865484856575348665354543"))
Serial.println("Mayee Perdon");
cID = readID;
File mayeeFile = SD.open("mayee.txt");
if (mayeeFile) {
while (mayeeFile.available())
Serial.write(mayeeFile.read());
mayeeFile.close();
readID = "";
i = 0;
bookS = "";
if ((readID == "24865484856576966556849533"))
Serial.println("Fae");
cID = readID;
File faeFile = SD.open("fae.txt");
if (faeFile) {
while (faeFile.available())
Serial.write(faeFile.read());
faeFile.close();
readID = "";
i = 0;
bookS = "";
void borrow()
scan();
if ((cID == "24848484848565555565270663") && (i == 3))
books();
File oginneFile = SD.open("oginne.txt", FILE_WRITE);
Serial.println(bookS);
oginneFile.println(bookS);
oginneFile.close();
i = 0;
if ((cID == "24865484856575348665354543") && (i == 3))
books();
File mayeeFile = SD.open("mayee.txt", FILE_WRITE);
mayeeFile.println(bookS);
mayeeFile.close();
i = 0;
if ((cID == "24848484848566556576851683") && (i == 3))
books();
File darrylFile = SD.open("darryl.txt", FILE_WRITE);
darrylFile.println(bookS);
darrylFile.close();
i = 0;
if ((cID == "24865484856576966556849533") && (i == 3))
books();
File faeFile = SD.open("fae.txt", FILE_WRITE);
faeFile.println(bookS);
faeFile.close();
i = 0;
void books()
if ((readID == "24857484849556570685654573"))
bookS = "Book of cheese";
readID = "";
if ((readID == "24857484849557066516968663"))
bookS = "Book of math";
readID = "";
if ((readID == "24857484849556570515156503"))
bookS = "Engineering Electromagnetics";
readID = "";
if ((readID == "24857484849564851555754663"))
bookS = "Engineering Communications";
readID = "";
void returnBooks()
if ((cID == "24848484848565555565270663"))
SD.remove("oginne.txt");
Serial.println("Books are cleared for Oginne Lapuz");
if ((cID == "24848484848566556576851683"))
SD.remove("mayee.txt");
Serial.println("Books are cleared for Mayee Perdon");
if ((cID == "24865484856575348665354543"))
SD.remove("darryl.txt");
Serial.println("Books are cleared for Darryl Cacho");
Thanks for any input!
