I have 3 temp sensors on Arduino with the following code
#include <OneWire.h>
#include <DallasTemperature.h>
#include <Wire.h>
#include <SPI.h>
#include <nRF24L01.h>
#include <printf.h>
#include <RF24.h>
#include <RF24Network.h>
// Data wire is plugged into digital pin 9 on the Arduino
#define ONE_WIRE_BUS 9
// Setup a oneWire instance to communicate with any OneWire device
OneWire oneWire(ONE_WIRE_BUS);
// Pass oneWire reference to DallasTemperature library
DallasTemperature sensors(&oneWire);
// Addresses of 3 DS18B20s
uint8_t sensor1[8] = { 0x28, 0xAA, 0xD8, 0x06, 0x48, 0x14, 0x01, 0x79 };
uint8_t sensor2[8] = { 0x28, 0xAA, 0xCA, 0x14, 0x48, 0x14, 0x01, 0xB9 };
uint8_t sensor3[8] = { 0x28, 0xAA, 0x97, 0x1D, 0x48, 0x14, 0x01, 0x53 };
int deviceCount = 3;
float Pool;
float Heater;
float Outside;
// nRF24L01(+) radio attached (CE, CSN)
RF24 radio(7,8);
// Network uses that radio
RF24Network network(radio);
// Channel of our node
const uint16_t channel = 90;
// Address of our node
const uint16_t this_node = 1;
// Address of the other node
const uint16_t other_node = 0;
// How many packets have we sent already
unsigned long packets_sent;
// Structure of our payload, limited to 32 bytes
struct payload_t // 32 bytes max
unsigned long counter; // 4 bytes
char Pool; // 4 bytes
char Heater; // 4 bytes
char Outside; // 4 bytes
void setup(void)
sensors.begin(); // Start up the library
SPI.begin();
radio.begin();
radio.setPALevel(RF24_PA_MAX);
network.begin(channel, this_node);
// Power down the radio. Note that the radio will get powered back up on the next write() call.
radio.powerDown();
delay(2000);
void loop(void)
sensors.requestTemperatures();
Serial.print("Pool: ");
printTemperature(sensor1);
delay(5000);
Serial.print("Heater: ");
printTemperature(sensor2);
delay(5000);
Serial.print("Outside: ");
printTemperature(sensor3);
delay(5000);
void printTemperature(DeviceAddress deviceAddress)
float tempC = sensors.getTempC(deviceAddress);
Serial.print(tempC);
Serial.println(" C");
and i need to send the serial output to another Arduino using the NRF24LO1
my serial output from the tranmitter is
07:29:39.069 -> Pool: 16.75 C
07:29:44.075 -> Heater: 16.56 C
07:29:49.099 -> Outside: 15.94 C
and i need to send that data to the other Arduino with the rf receiver
i have tried all sorts of examples but not getting the right results
