Help sending PUT Request with HTTPClient
Hi, I am trying to send and "ON"/"OFF" signal from my client ESP32 to a server ESP32 which then updates an ASYNC web page.
Client Code:
void httpPUTRequest(const char* serverName, bool boolPayload, const char* endpoint) {
  HTTPClient http;
  char url[100];
  snprintf(url, sizeof(url), "%s%s", serverName, endpoint);
  http.begin(url);
  http.addHeader("Content-Type", "text/plain");
  String strPayload = boolPayload ? "ON" : "OFF";
  Serial.println("Sending PUT request to: " + String(url));
  Serial.println("Payload: " + strPayload);
  int httpResponseCode = http.PUT(strPayload);
  if (httpResponseCode > 0) {
     Serial.print("\n\nHTTP Response Code: ");
     Serial.println(httpResponseCode);
  else {
    Serial.print("\n\nError code: ");
    Serial.println(http.errorToString(httpResponseCode).c_str());
  Serial.println(String(http.headers()));
  http.end();
Here is how I call the function:
httpPUTRequest(serverName, ledState, "/update-value");
This is my Serial output:
Sending PUT request to: http://11.1.1.111/update-value
Payload: ON
HTTP Response Code: 400
0
Led Status: ON
Does anyone know how to Serial output the HTTP Request data?
You could try a service that will echo your request
    HTTPClient http;
    http.begin("http://httpbin.org/anything/update-value");
    String strPayload = "ON";
      String payload = http.getString();
      Serial.print(payload);
prints
200
  "args": {},
  "data": "ON",
  "files": {},
  "form": {},
  "headers": {
    "Accept-Encoding": "identity;q=1,chunked;q=0.1,*;q=0",
    "Content-Length": "2",
    "Content-Type": "text/plain",
    "Host": "httpbin.org",
    "User-Agent": "ESP32HTTPClient",
    "X-Amzn-Trace-Id": "Root=1-66982672-07908b536efc3190737a5a47"
  "json": null,
  "method": "PUT",
  "origin": "50.31.197.73",
  "url": "http://httpbin.org/anything/update-value"
At first glance, the request is simple enough, and you're getting 400; so apparently the server doesn't like it for some reason. You should get and print the payload as above; it might say why the request is invalid.
http.headers() returns zero because you need to call collectHeaders first, before the PUT, to enumerate the ones you are interested in.
