Help. Serial communication of HEX
I want to control a linear actuator which uses I/O (TTL) signal to control the load output and position.
From the manual, I got communication protocol (the commands are hexadecimal format) and checked the commands using my computer.
But I got in trouble when I tried to send the data with the Arduino.
So, would you check my very simple code and tell me the problem?
// command based on communication protocol byte servoset[] = {0x80, 0xEA, 0x01, 0x00, 0x00}; byte servopush[] = {0x80, 0x01, 0x00, 0x03, 0xDE}; byte servopull[] = {0x80, 0x01, 0x00, 0x00, 0xF0};
// I want to operate the actuator once void setup() {
Serial.begin(38400);
Serial.write(servoset, sizeof(servoset));
Serial.write(servopush, sizeof(servopush));
delay(3000);
Serial.write(servopull, sizeof(servopull));
Have you tried Google? Something similar to this was discussed not too long ago but I don't think that the site search feature is working too well at the moment.
I searched about 10 hours.
And the coding is the result.
Which linear actuator?
How do you have it wired up?
Would you please refer this attachment?
I cannot explain what it is in my words.
My circuit is also very simple.
Arduino as well as the actuator are parallelly powered by 7.4 V and both have common ground. Arduino's pin 1(TX) is connected to the RX of actuator. But I reduced the 5 V (TX) to 3.3 V (RX) because the actuator is suited for 3.3 V. I used voltage divider to lower the voltage. TX (5V) --- 1.8k ohm----3.3k ohm---GND l_ _ _ _RX
Bemong: Would you please refer this attachment?
Can you post a link to the website where you got that document. Hopefully there is also a wiring diagram.
From reading it I suspect you can control the Actuator as a regular servo using the Arduino servo library.
...R
The spec sheet image certainly says PWM, and the timings are consistent with the Servo library. In fact, I can't see from that where the serial is even connected
I checked this actuator can be controlled by serial communication without PWM.
With my computer and USB-to-UART, I sent the HEX data to the actuator and operated it.
In fact, I tried PWM control using the arduino library. But I failed.
I think that focusing on serial communication is the easy way to solve my problem which is simply move the actuator.
Bemong: I checked this actuator can be controlled by serial communication without PWM.
You have not posted a link to the datasheet (as I requested earlier) so how can I help?
...R
…R
[/quote]
Oh, that is my mistake!
This attachments are all I can have from the manufacturer.
The site do not provide English, but I put the link here.
http://www.potenit.com/page.php?LinkPage=view_product2&Code=20130325180056
You might want to consider using a level-shifter instead of the voltage divider.
https://learn.sparkfun.com/tutorials/bi-directional-logic-level-converter-hookup-guide
http://playground.arduino.cc/Main/I2CBi-directionalLevelShifter
Bemong: This attachments are all I can have from the manufacturer.
OK - we will have to try to work with that.
It almost seems to me that the two pages are for different devices. In the first case it looks like a servo signal on the white wire would control the device - have you tried that? If so maybe you would post the test code and a diagram of how you actually connected everything. If this works it would be by far the simplest solution so I would certainly try hard to get it to work.
In the other page it seems that you need to send 5 byte messages to the device at 38,400 baud. From your original post it seems that you have tried the examples the same way I would have.
Can you post a drawing (photo of a pencil drawing will be fine) showing how everything is connected.
...R
Robin2:
Bemong:
…R
borland:
Bi-Directional Logic Level Converter Hookup Guide - learn.sparkfun.com
Thank you Robin2 and borland. Owing to your help, I solved the problem.
I attached the picture of my circuit.
The problem was my poor analog voltage divider between the TX and RX.
The linear actuator is suited for 3.3 V so I tried to decrease the 5 V from TX by using the wrong voltage divider.
From the borland’s post, I guessed that my voltage divider would be the problem and I removed it.
Then it worked even though the linear actuator requires 3.3 V to be sufficient condition.
I am really touched by your voluntary helps. Thank you so much.
My last question, do any body know why my analog voltage divider caused the problem?
