[help] serial communication: vvvv > Arduino > APA102 LEDs
Dearest ninjas,
We are working on an interactive installation project where we are using LED strips inside transparent human sculptures to highlight 7 chakras through different light changes. At the moment, we are having some difficulties to make vvvv (RS232 node) “fluently” communicate through serial port (via Arduino) with LEDs APA102 (“DotStar”).
We tried many things with the patch, code and different Arduino pins, but still didn't manage to properly send packets of values from vvvv > Arduino Code (buffer) > Array of 360 LEDs (6 strips, 60 LEDs each, serially connected with 4 wires GND, DATA, CLOCK & 5V).
DATA wire is currently connected to A9 (analog) pin and CLOCK to A10 (analog) pin on Arduino Mega 2560.
Screenshot of vvvv patch:
Arduino code, version 1:
// Awakening Circle ~ Interactive Visionary Installation
// vulkai studio
// https://github.com/sivinjski/AwakeningCircle
// This Arduino code should understand packets of values from vvvv serial port and send them
// via Arduino Mega 2560 board, DATA Pin A9 (analog), CLOCK Pin A10 (analog)
// to an array of 360 [APA102] LEDs, 6 strips x 60 pixels.
#include <FastLED.h>
#define NUM_LEDS 360
#define DATA_PIN A9    // Analog 9
#define CLOCK_PIN A10  // Analog 10
CRGB leds[NUM_LEDS];   // Array for RGB LEDs
int LEDValues[NUM_LEDS][3]; // 2D array (360,3) to store RGB values for every LED
char packetBuffer[1080]; // Buffer to store incoming string from vvvv
  FastLED.addLeds<APA102, DATA_PIN, CLOCK_PIN>(leds, NUM_LEDS); // initiate RGB LED strip
  Serial.begin(9600); // start Serial Communication
  if (Serial.available() > 0) // Check if data is coming in through serial
    Serial.readBytes(packetBuffer,1080);// 1080 is the packetsize = 1080 values + '<' and '>'
    if( packetBuffer[0]=='<' && packetBuffer[1080-1]=='>') // if first and last chars of string are '<' and '>' we know the whole package has arrived
      unsigned char CleanBuffer [1080-2]; // new Array to store string without starting and closing tag
      memcpy(CleanBuffer,packetBuffer+1,1080-2); // copies the content from packetBuffer to CleanBuffer excluding the first and last element
      int index=0; // helper to point to a specific data point
      for(int i=0; i<NUM_LEDS; i++) // nested for loop to run through two dimensional array
        for(int j=0; j<3; j++)
          LEDValues[i][j] = CleanBuffer[index]; // store values of CleanBuffer in 2D Array
          index++; // increase index to get next data point in next run through the loop
  for(int i=0; i<NUM_LEDS; i++) // for loop to push values to LEDs
    leds[i] = CRGB(LEDValues[i][0],LEDValues[i][1],LEDValues[i][2]);
  FastLED.show(); // updated RGB LED strip
  delay(5);
Arduino code, version 2 (still needs 'some' work):
// vulkai studio
// In this second version (SendSerial2Arduno_v2) there could be some mess between
// FastLED.h and Adafrit_DotStar.h libraries: such as NUM_LEDS vs. NUMPIXELS, etc. etc.
#include <SPI.h>
#include <Adafruit_DotStar.h> // Library for APA102, labeled by Adafruit as DotStar
                              // https://github.com/adafruit/Adafruit_DotStar
//FastLED// #define DATA_PIN A9
//FastLED// #define CLOCK_PIN A10
#define NUMPIXELS 360
#define DATAPIN  A9
#define CLOCKPIN A10
  Adafruit_DotStar strip = Adafruit_DotStar(NUM_LEDS, DATAPIN, CLOCKPIN, DOTSTAR_BRG);
  //// FastLED.addLeds<DOTSTAR, DATA_PIN, CLOCK_PIN>(leds, NUM_LEDS); // initiate RGB LED strip
  delay(5);
There is probably something wrong with the Arduino code or the vvvv patch. Maybe we are sending wrong values from vvvv or they are correct but the Arudino code doesn't understand them.
Does anybody have experience with this and is willing to have a quick look at our patch and the code? Any help will be greatly appreciated. Thank you very very much.
If anything is unclear about the hardware or software don't hesitate to ask.
vvvv patch and two versions of Arudino code are attached in this post and are also available here GitHub - sivinjski/AwakeningCircle: Interactive Visionary Installation
AwakeningCircle.zip (743 KB)
SendSerial2Arduino_v1.ino (2 KB)
SendSerial2Arduino_v2.ino (2.49 KB)
I thought the chakras would answer everyone's problems :slight_smile: But maybe you have to light them up first.
What do you mean by "vvvvv" If this is an item of hardware or software please post a link to its datasheet.
You may find the examples in serial input basics useful. They are simple, reliable and non-blocking.
If you want to show us your code please post it directly in a Post or as an attached .ino file. I hope it is not 743.05 kB in size.
...R
I hope you don't expect me to learn VVVV so I can teach it to you ?
Perhaps the VVVV people have their own Forum where you can ask questions ?
I wonder if you have suddenly come to the point where you find it may really have been easier just to develop it with C++ in the first place.
...R
