[HELP] Set the speed of 2 DC motors with H-Bridge
Hey, I have a problem. I want to set the two motors to different speed. I'm using an H-Bridge. Here's my sketch:
#define STATE_IDLE      0
#define STATE_INIT      1
#define STATE_RUNNING           2
#define STATE_EXITING           3
const int in1Pin = 5;  // H-Brücken-Eingangspins
const int in2Pin = 4;
const int in3Pin = 3;  // H-Brücken-Eingangspins
const int in4Pin = 2;
const int en1Pin = 6;
const int en2Pin = 7;
const int buttonPin = 8;
int buttonState = 0;
int Zustand;
  Zustand = STATE_IDLE;
  pinMode(buttonPin, INPUT);
  pinMode(in1Pin, OUTPUT);
  pinMode(in2Pin, OUTPUT);
  pinMode(in3Pin, OUTPUT);
  pinMode(in4Pin, OUTPUT);
  switch( Zustand )
    case STATE_IDLE: Idle();
    case STATE_INIT: Init();
    case STATE_RUNNING: Run();
    case STATE_EXITING: Exiting();
void Idle()
  buttonState = digitalRead(buttonPin);
  if (buttonState == HIGH) {
    Zustand = STATE_INIT;
void Init()
  Zustand = STATE_RUNNING;
void Run()
  analogWrite(en1Pin,70);
  analogWrite(en2Pin,100);
  digitalWrite(in1Pin,LOW);
  digitalWrite(in2Pin,HIGH);
  delay(1500);
  digitalWrite(in2Pin,LOW);
  digitalWrite(in3Pin,HIGH);
  digitalWrite(in4Pin,LOW);
  delay(5000);
  digitalWrite(in3Pin,LOW);
  digitalWrite(in1Pin,HIGH);
  delay(1500);
  Zustand = STATE_EXITING;
void Exiting()
But when I press the button, just one motor runs in the speed, given with 'en1Pin'. Without trying to set the speed, the motors run correctly.
Hope you can help and sorry for my bad English. Greets, Mathis
Your code looks OK
  analogWrite(en1Pin,70);    //speed A
  analogWrite(en2Pin,100);    //speed B
  digitalWrite(in1Pin,LOW);  //1-2 run at speed A
  delay(1500);
  digitalWrite(in1Pin,LOW);  //1-2 stop
  digitalWrite(in3Pin,HIGH); //3-4 run at speed B
  delay(5000);
  digitalWrite(in3Pin,LOW);  //3-4 stop
  digitalWrite(in2Pin,LOW);  //1-2 run at speed A
  delay(1500);
I have annotated it to help me understand what I think you are trying to do Can you confirm that the names you have given the pins correspond to the actual inputs on the H bridges ?
Do you have two H bridges, or are you somehow trying to use one ?
First, thanks for your replies.
I've connected the en1Pin to the ENB and the en2Pin to the ENA, the INPUT pins are correctly connected. And yes I try to use one H-Bridge. And without trying to regular the speed, it works well.
What H bridge are you using ? Can you provide a link to what you are using ? If it has ENA and ENB inputs then it is almost certainly 2 H bridges, even if they are in 1 chip, possibly an L293 or similar.
Yes its an L293.
Did you build the circuit yourself or buy it ready made ? If you built it yourself what is the circuit ? If ready made is there a link to the product ?
I buyed it, here's a link: http://my.safaribooksonline.com/getfile?item=ODMvZDlpY3B0L20vZ2VzOTg4Mzk5NjI1c2FzcjdhaWxjZW90dC9odHBvdG9tcmxjdW1zeW9yb2Vyc2VhZ2VwZTNlaWx5Z3JpYW55bXMzNjcwMTIuZ24ubGFtanBn Evrything the same, except that I connected the ENB to Pin6 and added a second motor.
for this kind of h bridge i would like to use functions actually
void Motor(boolean Dir, int Speed)
  int Stop;
  if (Dir ==Stop)
    digitalWrite(Pin1,LOW);
    digitalWrite(Pin2,LOW);
    digitalWrite(Pin1,Dir);
    digitalWrite(Pin2,!Dir);
    analogWrite(EnPin,Speed);
for dir you could specify HIGH and LOW,
  int Stop;
  if (Dir ==Stop)
Really bad idea. Please rethink.
your write AWOL, Its should be and int instead of a Boolean
But where can I set the speed there?
I am all in favour of using functions but unless the inline code works when the inputs to the H bridge are set correctly then a function is not going to help.
To make things even easier to understand I have written a small class to control a motor attached to an H bridge but that does depend on the basic code working, of course.
No, think again. What is the value of "Stop"?
ok How about this
void Motor1(boolean Pin1, boolean Pin2, int Speed)
  digitalWrite(in1Pin,Pin1);
  digitalWrite(in2Pin,Pin2);
  analogWrite(en1Pin,Speed);
void Motor2(boolean Pin1, boolean Pin2, int Speed)
  digitalWrite(in3Pin,Pin1);
  digitalWrite(in4Pin,Pin2);
  analogWrite(en2Pin,Speed);
Mats2006: I buyed it, here's a link: http://my.safaribooksonline.com/getfile?item=ODMvZDlpY3B0L20vZ2VzOTg4Mzk5NjI1c2FzcjdhaWxjZW90dC9odHBvdG9tcmxjdW1zeW9yb2Vyc2VhZ2VwZTNlaWx5Z3JpYW55bXMzNjcwMTIuZ24ubGFtanBn Evrything the same, except that I connected the ENB to Pin6 and added a second motor.
That link does not work for me.
Does each motor work as expected when it is the only one being controlled ?
A thought. Have you got anything using interrupts, such as a sensor using timer 2, attached to the Arduino ? I had problems with motor control when I added a ping sensor to my buggy. (Arduino Uno) It stopped PWM working on pins 3 and 11 because its library uses timer 2 which is also used for PWM on those pins. I had to switch the enable pin of one motor from pin 3 to pin 10.
OK, the picture is in the attach.
Yes, you can control one motor, but then the other one does nothing.
And no, I don’t use any sensor, just a button and a few LED’s :slight_smile:
try moving the enable switch to another free PWM pin. that should give you the speed control you need
What do you mean 'PWM pin'?
http://arduino.cc/en/Reference/AnalogWrite
