Help setting up fast PWM by registers (solved)
I've been trying to set up my own PWM code for better timings and to learn about the hardware under Arduino but i can't seem to get it to work. I've read the section of the manual about timers and PWM so many times i could probably recite it from memory and have all the timers are working fine but PWM output just refuses to work. I'm trying to set up fast PWM and (for now) dim the LED on pin 13 (timer0) though I would rather it have it on timer2. I've been staring at the code for three days now and tried every combination of bits i could think of but nothing i try works, so i believe I'm missing something vital somewhere.
If someone could please look at my code and point out what I'm doing wrong i would be grateful. You would probably prevent me from going prematurely bald as well.
// includes
  #include <avr/io.h>
  #include <avr/interrupt.h>
// constants
  #define PWM_OUT  OCR0A
  #define pin_out  13
// global variables
  // hold current value of PWM_OUT
  byte DUTY = 0;
// arduino setup
    // setup interupt/pwm code
      // enable pwm pin
      pinMode(pin_out, OUTPUT);
      // set fast pwm mode, clear on match
      //TCCR0A = 0b10000011;
      //TCCR0B = 0b00001100;
      TCCR0A = _BV(COM0A1) | _BV(WGM01) | _BV(WGM00);
      TCCR0B = _BV(WGM02);
      // set timer0 prescaler to 64
      // 1/ (16000000 / 64) = 1/250000
      TCCR0B |= _BV(CS02);
      // Timer0 match A Interrupt Enable
      TIMSK0 = _BV(OCIE0A);
      // turn on global interupts
      sei();
      // set initial value of OCR0A(TOP)
      DUTY = 50;
      PWM_OUT = DUTY;
    // setup testing
// arduino main loop
  void loop(){
    //PWM_OUT = DUTY;
    //delay(100);
    //DUTY++;
// interupt code
  ISR(TIMER0_COMPA_vect) {
    Serial.println("hi");
Do you have an ATmega328 or ATmega168 based board?
Timer 0 is already set to Fast PWM. Pin 13 is not capable of PWM.
I'm have an older Arduino mega running a 1280.
For the mega you can run PWM on pin 13(its mapped to pin 26 on the atmega). It describes it in the documentation and I tested it with an analogWrite. I should be able to run PWM on pins 2-13.
Just in case I moved everything to timer2(pin 10) and it still doesn't work. Testing it with a voltmeter it reads the same voltage for a duty of 0 and 255.
// enable pwm pin
TCCR0B = 0; // Start with mode 3. Mode 7 is not orthogonal.
// set timer0 prescaler to 64 256
// 1/ (16000000 / 64 256) = 1/250000
TIMSK0 = 0; // Once you have a PWM output then add interrupts to the mix.
// sei(); // This line of code is useless. Remove it.
DUTY = 50;
PWM_OUT = DUTY;
// setup testing
Thank you, I have something to build on that actually works now. By far better than a cobbled together script from who knows how many tutorials I read and a semi incomprehensible manual.
loggerin:
Thank you
You are welcome. And welcome to the forum.
