I’m trying to use this code with a Lm35
#define BLYNK_PRINT Serial // Comment this out to disable prints and save space
#include <SPI.h>
#include <Ethernet.h>
#include <BlynkSimpleEthernet.h>
#include <SimpleTimer.h>
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "xxxxxxxxx";
float temp;
int tempPin = 1; //analog pin 1
SimpleTimer timer;
Serial.begin(9600); // See the connection status in Serial Monitor
Blynk.begin(auth);
// Setup a function to be called every second
timer.setInterval(1000L, sendUptime);
// that you define how often to send data to Blynk App.
void sendUptime()
// shows the value temp on virtual pin 10
Blynk.virtualWrite(10, temp);
Blynk.run(); // Initiates Blynk
timer.run(); // Initiates SimpleTimer
temp = analogRead(tempPin);
temp = temp * 0.48828125;
I keep getting this error "void setup()’:
door_reconstruct2:76:28: error: ‘sendUptime’ was not declared in this scope
timer.setInterval(1000L, sendUptime); ^
exit status 1
I’m sure I have properly integrated the library simpletimer
help?
