GOOD DAY TO ALL OF YOU ARDUINO USER...
NEED HELP GUYS COZ I TRIED MANY TIMES TO FIND A GUIDE AND
SOLUTION HOW TO MAKE IT WORK BY ONLY USING
ARDUINO
3 DIGIT 7 SEGMENT
MICRO SWITCH CONTROLLER
DOES ANY ONE HAVE A GOOD HEART HELP ME A CODE
TO RUN IN ARDUINO WITH 3 DIGIT 7 SEGMENT?
THANK YOU IN ADVANCE . . . . :o
I CHECK THIS CODE BUT I DONT KNOW IF THIS ONE CAN WORK IN 7 SEGMENT AND HOW ABOUT THE SCHEMATICS FOR 7 SEGMENT AND ARDUINO?
#include <SoftwareSerial.h>
#include <Servo.h>// Name (or label) servo.
Servo ballReturn;// Declare serial displays.
SoftwareSerial scoreDisp(A0,12);
SoftwareSerial ballDisp(A1,13);// Pin declarations
int sensors[8] = {9,8,7,6,5,4,3,2}; // create an array of sensors
int resetButton = 10;
int servPin = 11;// General declarations
int score = 0;
int balls = 9;
int n = 0;
int result;
int s;// Buffer Declarations
char ballTemp[10];
char scoreTemp[10];// Debounce delays
int sensDelay = 500;
int resetDelay = 500;// Servo Declarations
int open = 90;
int close = 180;void setup() {
// Decided to try using a for loop to designate each input pin as an INPUT. Works.
for (int eachSensor = 0; eachSensor <= 7; eachSensor++) {
pinMode(sensors[eachSensor], INPUT);
pinMode(resetButton, INPUT);
ballReturn.attach(servPin);
ballDisp.begin(9600);
scoreDisp.begin(9600);
resetDisplays();
updateDisplays();
}void loop() {
while (balls > 0) {
// returnControl(close);
for(s = 0; s <= 7; s++){ // Check sensor array.
result = digitalRead(sensors~~); ~~~~ if (result == LOW) {~~
~~ if (s == 0) {~~
~~ n = 100;~~
~~ addpoints(n);~~
~~ if (s == 1) {~~
~~ n = 100;~~
~~ addpoints(n);~~
~~ if (s == 2) {~~
~~ n = 50;~~
~~ addpoints(n);~~
~~ if (s == 3) {~~
~~ n = 40;~~
~~ addpoints(n);~~
~~ if (s == 4) {~~
~~ n = 30;~~
~~ addpoints(n);~~
~~ if (s == 5) {~~
~~ n = 20;~~
~~ addpoints(n);~~
~~ if (s == 6) {~~
~~ n = 10;~~
~~ addpoints(n);~~
~~ }~~~~ if (s == 7) {~~
~~ n = 0;~~
~~ addpoints(n);~~
~~ else {~~
~~ //donothing~~
~~// add line: a break attached to button to reset inc, without resetting arduino. ~~~~ startOver();~~
~~ }//end of while loop~~
~~ startOver();~~
} //end of primary loop
void addpoints(int n){
~~ score = score + n;~~
~~ balls = balls - 1;~~
~~ updateDisplays();~~
~~ Serial.print("Your score is: ");~~
~~ Serial.println(score);~~
~~ Serial.print("Balls Remaining: ");~~
~~ Serial.println(balls);~~
~~ delay(sensDelay);~~
void reset(){
~~ returnControl(open);~~
~~ score = 0;~~
~~ balls = 9;~~
~~ delay(1500);~~
~~ returnControl(close);~~
void startOver(){
~~ int resetState = digitalRead(resetButton);~~
~~ if (resetState == HIGH){~~
~~ reset();~~
~~ delay(resetDelay);~~
void returnControl(int x){
~~ ballReturn.write(x);~~
void updateDisplays(){
~~ resetDisplays();~~
~~ sprintf(ballTemp, "%4d", balls);~~
~~ sprintf(scoreTemp, "%04d", score);~~
~~ ballDisp.print(ballTemp);~~
~~ scoreDisp.print(score);~~
void resetDisplays(){
~~ ballDisp.write('v');~~
~~ scoreDisp.write('v');~~
[/quote]
