Might even be able to skip the line level shifter with it.
Your looking at what 200-250ma when on and transmitting WiFi?
Are you getting less than 1 hr sunlight a day?
My apologies for interrupting the OP's thread.
I have held off on adding water level monitoring functionality to my aquariums simply because it seemed all the components available to do it the way I wanted would not hold up well in a humid environment. I didn't know those sensors even existed! Thank you for posting the link!
Slumpert:
I would try to use a more purpose oriented sensor such as....
yes i am using same sensor its just that i didn't found it in fritzing
no no its available all day time, i am updating water level every one hour
no benefit of updating it more than that...
yes , i will try to make it more less as possible
but first i need to finish transistor and resistor part first , also have to order solar panel
2n2222 Transistor will be okay ?
A0 and battery is connected to measures battery voltage
Battery output is 3.7V-4.2V
A0 pin on D1 mini can handle max 3.3v
So 180K 1/4 watt will be good enough ?
RST and D0 is connected for deep sleep functionality
So 220-560 ohm 1/4 watt resistor is good or BAT43 diode ?
Transistor(NPN) and D2 is connected to control power supply of ultrasonic sensor
1k resistor is good or 10k 1/4watt ?
