Help Solve: can't open device "\\.\COM3": Access is denied
Hey folks,
First time Ardino Nano user here. I am trying to use this to operate an IronMan mask using LED and servo motors. I have been following a Youtube tutorial (3 years old at this point) got to the point of uploading only to be hit with:
avrdude: ser_open(): can't open device "\.\COM3": Access is denied.
I have tried following multiple solutions but I am simply lost if anyone can come to my rescue a complete noob I'd really appreciate it
DESCRIPTION
  The purpose of this code is to automate the servos and LED eyes for the Iron Man helmet
  Motivation and inspiration comes from the early work by "XL97" of The RPF Community
DEVELOPED BY
  Dropwire
  Cranshark
  Taff
// Version.  Don't change unless authorized by Cranshark
#define VERSION "3.1.0.2"
#if defined __AVR_ATtiny85__ || defined __SAM3U4E__ || defined __SAM3X8E__ || defined __SAM3X8H__ || defined ARDUINO_SAMD_ZERO || defined __SAMD21G18A__ || defined __SAMD21J18A__ || ARDUINO_AVR_NANO_EVERY
#error Code not compatible with this board type.
#endif
#include "config.h"
// Referenced libraries
// For installation instructions see https://github.com/netlabtoolkit/VarSpeedServo
#include "lib/VarSpeedServo/VarSpeedServo.cpp"
// For installation instructions see: https://github.com/mathertel/OneButton
#include "lib/OneButton/src/OneButton.cpp"
#ifdef SOUND
#ifndef MP3_TYPE
#error MP3_TYPE not defined.  MP3_TYPE is required.
#endif
#ifndef SND_EFFECT_TYPE
#error SND_EFFECT_TYPE not defined.  SND_EFFECT_TYPE is required.
#endif
#if (MP3_TYPE == DFPLAYER)
// See: https://wiki.dfrobot.com/DFPlayer_Mini_SKU_DFR0299#target_6
// Important!!! On the SD card copy the mp3 files into an mp3 directory
// Download and install the DFRobotDFPlayerMini library
#include "lib/DFRobotDFPlayerMini/DFRobotDFPlayerMini.cpp"
void printDetail(uint8_t type, int value);  // header method for implementation below; affects C++ compilers
#endif
#if (MP3_TYPE == JQ6500)
// For installation instructions see: https://github.com/sleemanj/JQ6500_Serial
#include "lib/JQ6500_Serial/src/JQ6500_Serial.cpp"
#endif
#include <SoftwareSerial.h>
#endif
// Declare servo objects
VarSpeedServo servo1;  // create servo object to control servo 1
VarSpeedServo servo2;  // create servo object to control servo 2
#ifdef WALSH85
VarSpeedServo servo3;  // create servo object to control servo 3 (Walsh85 chin Control)
#endif
#ifdef MISSILE
VarSpeedServo servo4;  // create servo object to control servo 3
VarSpeedServo servo5;  // create servo object to control servo 4
// Define object for the missile button
OneButton missileButton = OneButton(MISSILE_BUTTON_PIN, true, true);
// State of the missile bay 1 = open, 0 = closed
#define MISSILE_BAY_CLOSED 0
#define MISSILE_BAY_OPEN 1
int missileBayCurMode = MISSILE_BAY_OPEN;  // Keep track if the missile bay is open or closed
#endif
#ifndef MISSILE
boolean auxLedState = false;  // Keeps track of the state of the LED on = true, off = false
#endif
#ifdef SOUND
// Declare variables for sound control
#define SND_CLOSE 1      // sound track for helmet closing sound
#define SND_OPEN 3       // sound track for helmet opening sound
#define SND_REPULSOR 4   // sound track for repulsor sound effect
#define SND_JARVIS 2     // sound track for JARVIS sound
#define SND_FRIDAY 5     // sound track for FRIDAY sound
#define SND_NO_ACCESS 6  // sound track for "not authorized to access" sound
SoftwareSerial serialObj(RX_PIN, TX_PIN);  // Create object for serial communications
DFRobotDFPlayerMini mp3Obj;  // Create object for DFPlayer Mini
#endif
JQ6500_Serial mp3Obj(serialObj);  // Create object for JQ6500 module
#endif
#endif
// Define object for primary button to handle
// multiple button press features:
// 1. Single Tap
// 2. Double Tap
// 3. Long Press
OneButton primaryButton = OneButton(BUTTON_PIN, true, true);
// State of the faceplate 1 = open, 0 = closed
#define FACEPLATE_CLOSED 0
#define FACEPLATE_OPEN 1
int facePlateCurMode = FACEPLATE_OPEN;  // Keep track if the faceplate is open or closed
// State of the LED eyes 1 = on, 2 = off
#define LED_EYES_OFF 0
#define LED_EYES_ON 1
// State of the LED eyes for dimming/brightening 1 = brighten, 2 = dim
#define LED_EYES_DIM_MODE 0
#define LED_EYES_BRIGHTEN_MODE 1
int ledEyesCurMode = LED_EYES_DIM_MODE;  // Keep track if we're dimming or brightening
int ledEyesCurPwm = 0;                   // Tracking the level of the LED eyes for dim/brighten feature
const int ledEyesIncrement = 15;         // Define the increments to brighten or dim the LED eyes
 * Helper Method
 * Simulate a delay in processing without disabling the processor completely
 * @param[out] period - the amount of time in milliseconds to delay
 * See: https://randomnerdtutorials.com/why-you-shouldnt-always-use-the-arduino-delay-function/
void simDelay(long period) {
  long delayMillis = millis() + period;
  while (millis() <= delayMillis) {
    int x = 0;  // dummy variable, does nothing
 * Simulate the eyes slowly blinking until fully lit
void movieblink() {
  Serial.println(F("Start Movie Blink.."));
  // pause for effect...
  simDelay(300);
  int lowValue = 21;
  int delayInterval[] = { 210, 126, 84 };
  int delayVal = 0;
  // First blink on
  for (int i = 0; i <= lowValue; i++) {
    setLedEyes(i);
    setAuxLed();
    delayVal = delayInterval[0] / lowValue;
    simDelay(delayVal);
  // Turn off
  setLedEyes(0);
  setAuxLed();
  simDelay(delayInterval[0]);
  // Second blink on
    setLedEyes(i);
    setAuxLed();
    delayVal = delayInterval[1] / lowValue;
    simDelay(delayVal);
  // Turn off
  setLedEyes(0);
  setAuxLed();
  simDelay(delayInterval[1]);
  // Third blink on
  setLedEyes(lowValue);
  setAuxLed();
  simDelay(delayInterval[2]);
  // Turn off
  setLedEyes(0);
  setAuxLed();
  // All on
  setLedEyes(255);
  auxLedOn();
#if defined(SOUND) && (MP3_TYPE == JQ6500)
#if (SND_EFFECT_TYPE == JARVIS)
  playSoundEffect(SND_JARVIS);
  simDelay(1000);
  mp3Obj.sleep();
#else
  playSoundEffect(SND_FRIDAY);
#endif
#endif
 * Simulate LED eyes slowly brightening until fully lit
void fadeEyesOn() {
  ledEyesCurMode = LED_EYES_BRIGHTEN_MODE;
  // loop until fully lit
  while (ledEyesCurPwm < 255) {
    setLedEyes(ledEyesCurPwm);
    simDelay(200);
    ledEyesBrighten();
#ifdef SOUND
 * Initialization method for DFPlayer Mini board
void init_player() {
  serialObj.begin(9600);
  //simDelay(1000); Adjusting Timing Sequence
  if (!serialObj.available()) {
    Serial.println(F("Serial object not available."));
  Serial.println(F("Initializing DFPlayer ... (May take 3~5 seconds)"));
  bool dfInit = mp3Obj.begin(serialObj, false, true);
  simDelay(1000);
  if (!dfInit) {
    Serial.println(F("Unable to begin:"));
    Serial.println(F("1.Please recheck the connection!"));
    Serial.println(F("2.Please insert the SD card!"));
    simDelay(400);  // originally 1000ms
  Serial.println(F("DFPlayer Mini online."));
  mp3Obj.setTimeOut(500);  //Set serial communictaion time out 500ms
  Serial.println(F("Setting volume"));
  mp3Obj.volume(VOLUME);
  simDelay(100);  // DFRobot Timing 9-9-2022
  mp3Obj.EQ(DFPLAYER_EQ_NORMAL);
  mp3Obj.outputDevice(DFPLAYER_DEVICE_SD);
 * Method to play the sound effect for a specified feature
void playSoundEffect(int soundEffect) {
  Serial.print(F("Playing sound effect: "));
  Serial.print(soundEffect);
  Serial.print(F("\tVolume: "));
  Serial.println(mp3Obj.readVolume());
  mp3Obj.play(soundEffect);
  printDetail(mp3Obj.readType(), mp3Obj.read());  //Print the detail message from DFPlayer to handle different errors and states.
#endif
 * Initialization method for MP3 player module
  Serial.println(F("Initializing JQ6500..."));
  mp3Obj.reset();
  mp3Obj.setSource(MP3_SRC_BUILTIN);
  mp3Obj.setVolume(VOLUME);
  mp3Obj.setLoopMode(MP3_LOOP_NONE);
  simDelay(500);
  mp3Obj.playFileByIndexNumber(soundEffect);
void delayWhilePlaying() {
  while (mp3Obj.getStatus() == MP3_STATUS_PLAYING) {
    int x = 0;
#endif
#endif
 * Method to open face plate
void facePlateOpen() {
  Serial.println(F("Servo Up!"));
  // Re-attach the servos to their pins
  servo1.attach(SERVO1_PIN, PWM_LOW, PWM_HIGH);
  servo2.attach(SERVO2_PIN, PWM_LOW, PWM_HIGH);
#ifdef WALSH85
  servo3.attach(SERVO3_PIN, PWM_LOW, PWM_HIGH);
#endif
  // Send data to the servos for movement
  servo1.write(SERVO1_OPEN_POS, SERVO_OPEN_SPEED);
  servo2.write(SERVO2_OPEN_POS, SERVO_OPEN_SPEED);
#ifdef WALSH85
  simDelay(500);
  servo3.write(SERVO3_OPEN_POS, CHIN_OPEN_SPEED);
//simDelay(1000); // wait doesn't wait long enough for servos to fully complete...
#endif
  simDelay(2000);  // wait doesn't wait long enough for servos to fully complete...
// Detach so motors don't "idle"
#if (SERVO1_DISABLE_AFTER_OPEN)
  servo1.detach();
#endif
  servo2.detach();
#endif
#ifdef WALSH85
  servo3.detach();
#endif
  * Method to close face plate
void facePlateClose() {
  Serial.println(F("Servo Down"));
#ifdef WALSH85
#endif
#ifdef WALSH85
  servo3.write(SERVO3_CLOSE_POS, CHIN_CLOSE_SPEED);
  simDelay(500);  // Delay to allow chin to fully close before Faceplate closes
#endif
  servo1.write(SERVO1_CLOSE_POS, SERVO_CLOSE_SPEED);
  servo2.write(SERVO2_CLOSE_POS, SERVO_CLOSE_SPEED);
  servo1.detach();
  servo2.detach();
#ifdef WALSH85
  servo3.detach();
#endif
  facePlateCurMode = FACEPLATE_CLOSED;
#ifdef MISSILE
 * Method to open the missile bay
void missileBayOpen() {
  Serial.println(F("Missile bay opening..."));
  servo4.attach(SERVO4_PIN, PWM_LOW, PWM_HIGH);
  servo5.attach(SERVO5_PIN, PWM_LOW, PWM_HIGH);
  servo4.write(SERVO4_OPEN_POS, MISSILE_BAY_OPEN_SPEED);
  simDelay(MISSILE_BAY_DELAY);
  servo5.write(SERVO5_OPEN_POS, MISSILE_OPEN_SPEED);
  servo4.detach();
  servo5.detach();
 * Method to close the missile bay
void missileBayClose() {
  Serial.println(F("Missile bay closing..."));
  servo5.write(SERVO5_CLOSE_POS, MISSILE_CLOSE_SPEED);
  simDelay(1000);
  servo4.write(SERVO4_CLOSE_POS, MISSILE_BAY_CLOSE_SPEED);
  simDelay(1000);
  servo4.detach();
  servo5.detach();
  missileBayCurMode = MISSILE_BAY_CLOSED;
#endif
 * Set the brightness of the LED eyes
 * @param[out] pwmValue - the PWM value (0-255) for the LED brightness
void setLedEyes(int pwmValue) {
  analogWrite(RIGHT_EYE_PIN, pwmValue);
  analogWrite(LEFT_EYE_PIN, pwmValue);
  ledEyesCurPwm = pwmValue;
 * Method to turn on LED eyes
void ledEyesOn() {
  Serial.println(F("Turning LED eyes on..."));
  setLedEyes(255);
 * Method to turn off LED eyes
void ledEyesOff() {
  Serial.println(F("Turning LED eyes off..."));
  setLedEyes(0);
 * Method to turn LED eyes on/off
void ledEyesOnOff() {
  // LED eyes stay off when faceplate is open
  if (facePlateCurMode == FACEPLATE_CLOSED) {
    if (ledEyesCurPwm > 0) {
      ledEyesOff();
      ledEyesOn();
void ledEyesDim() {
  Serial.println(F("Dimming LED eyes..."));
  ledEyesCurPwm = ledEyesCurPwm - ledEyesIncrement;  // Decrease the brightness
  // Make sure we don't go over the limit
  if (ledEyesCurPwm <= 0) {
    ledEyesCurPwm = 0;
void ledEyesBrighten() {
  Serial.println(F("Brightening LED eyes..."));
  ledEyesCurPwm = ledEyesCurPwm + ledEyesIncrement;  // Increase the brightness
  if (ledEyesCurPwm >= 255) {
    ledEyesCurPwm = 255;
 * Method to dim or brighten both LED eyes
void ledEyesFade() {
  if (ledEyesCurPwm == 255) {
  } else if (ledEyesCurPwm == 0) {
  if (ledEyesCurMode == LED_EYES_BRIGHTEN_MODE) {
    ledEyesBrighten();
    ledEyesDim();
  simDelay(200);
 * Sets the Aux LED
void setAuxLed() {
#ifndef MISSILE
  if (AUX_LED_ENABLED) {
    if (auxLedState == false) {
      auxLedOn();
      auxLedOff();
    auxLedOff();
#endif
 * Turn the Aux LED on
void auxLedOn() {
#ifndef MISSILE
  digitalWrite(AUX_LED_PIN, HIGH);
  auxLedState = true;
#endif
 * Turn the Aux LED off
void auxLedOff() {
#ifndef MISSILE
  digitalWrite(AUX_LED_PIN, LOW);
#endif
 * Method to run sequence of sppecial effects when system first starts or sets up
void startupFx() {
  //facePlateClose();
#ifdef MISSILE
  missileBayClose();  // Start out with the missile bay in the closed position
#endif
#ifdef SOUND
  playSoundEffect(SND_CLOSE);
  simDelay(500);  // Timing for Helmet Close Sound and delay to servo closing
#endif
  facePlateClose();
  switch (SETUP_FX) {
    case EYES_NONE:
      ledEyesOn();
      auxLedOn();
    case EYES_MOVIE_BLINK:
      movieblink();
    case EYES_FADE_ON:
      fadeEyesOn();
      auxLedOn();
#if defined(SOUND) && (MP3_TYPE == DFPLAYER)
  simDelay(500);  // Originally 2000ms
#else
#endif
#endif
 * Method to execute special effects when the faceplate opens
void facePlateOpenFx() {
  // TODO: See if we need delays in between fx
#ifdef SOUND
  playSoundEffect(SND_OPEN);
#endif
  ledEyesOff();
  facePlateOpen();
 * Method to execute special effects when the faceplate closes
void facePlateCloseFx() {
#ifdef SOUND
  simDelay(1200);  //Timing for Helmet Close Sound and delay to servo closing
#endif
#endif
  facePlateClose();
  switch (EYES_FX) {
    case EYES_NONE:
      ledEyesOn();
      auxLedOn();
      movieblink();
    case EYES_FADE_ON:
      fadeEyesOn();
      auxLedOn();
 * Handle faceplate special effects
void facePlateFx() {
  if (facePlateCurMode == FACEPLATE_OPEN) {
    facePlateCloseFx();
    facePlateOpenFx();
#ifdef MISSILE
void missileOpenFx() {
  missileBayOpen();
void missileCloseFx() {
  missileBayClose();
void missileFx() {
  if (missileBayCurMode == MISSILE_BAY_OPEN) {
    missileCloseFx();
    missileOpenFx();
#endif
 * Event handler for when the primary button is tapped once
void handlePrimaryButtonSingleTap() {
  facePlateFx();
 * Event handler for when the primary button is double tapped
void handlePrimaryButtonDoubleTap() {
  ledEyesOnOff();
 * Event handler for when the primary button is pressed and held
void handlePrimaryButtonLongPress() {
  ledEyesFade();  // Dim or brighten the LED eyes
#ifdef MISSILE
void handleMissileButtonSingleTap() {
  missileFx();
#endif
 * Event handler for when the primary button is pressed multiple times
void handlePrimaryButtonMultiPress() {
  switch (primaryButton.getNumberClicks()) {
    case 4:
#ifdef SOUND
      playSoundEffect(6);
#endif
    default:
 * Initializes the primary button for multi-functions
void initPrimaryButton() {
  primaryButton.attachClick(handlePrimaryButtonSingleTap);
  primaryButton.attachDoubleClick(handlePrimaryButtonDoubleTap);
  primaryButton.attachDuringLongPress(handlePrimaryButtonLongPress);
  primaryButton.attachMultiClick(handlePrimaryButtonMultiPress);
#ifdef MISSILE
 * Initializes the missile button for multi-functions
void initMissileButton() {
  missileButton.attachClick(handleMissileButtonSingleTap);
#endif
 * Monitor for when the primary button is pushed
void monitorPrimaryButton() {
  primaryButton.tick();
#ifdef MISSILE
 * Monitor for when the missile button is pushed
void monitorMissileButton() {
  missileButton.tick();
#endif
 * Initialization method called by the Arduino library when the board boots up
  // Set up serial port
  simDelay(2000);  // Give the serial service time to initialize
  Serial.print(F("Initializing Iron Man Servo version: "));
  Serial.println(VERSION);
#ifdef SOUND
  init_player();  // initializes the sound player
#endif
  startupFx();  // Run the initial features
  initPrimaryButton();  // initialize the primary button
#ifdef MISSILE
  initMissileButton();  // initialize the missile button
#else
  pinMode(AUX_LED_PIN, OUTPUT);  // set output for AUX LED
#endif
 * Main program exeucution
 * This method will run perpetually on the board
  monitorPrimaryButton();  // Since all features currently are tied to the one button...
#ifdef MISSILE
  monitorMissileButton();  // Monitor when the missile button is pushed...
#endif
  // Room for future features ;)
 * Method to output any issues with the DFPlayer
void printDetail(uint8_t type, int value) {
  switch (type) {
    case TimeOut:
      Serial.println(F("Time Out!"));
    case WrongStack:
      Serial.println(F("Stack Wrong!"));
    case DFPlayerCardInserted:
      Serial.println(F("Card Inserted!"));
    case DFPlayerCardRemoved:
      Serial.println(F("Card Removed!"));
    case DFPlayerCardOnline:
      Serial.println(F("Card Online!"));
    case DFPlayerPlayFinished:
      Serial.print(F("Number:"));
      Serial.print(value);
      Serial.println(F(" Play Finished!"));
    case DFPlayerError:
      Serial.print(F("DFPlayerError:"));
      switch (value) {
        case Busy:
          Serial.println(F("Card not found"));
        case Sleeping:
          Serial.println(F("Sleeping"));
        case SerialWrongStack:
          Serial.println(F("Get Wrong Stack"));
        case CheckSumNotMatch:
          Serial.println(F("Check Sum Not Match"));
        case FileIndexOut:
          Serial.println(F("File Index Out of Bound"));
        case FileMismatch:
          Serial.println(F("Cannot Find File"));
        case Advertise:
          Serial.println(F("In Advertise"));
        default:
    default:
#endif
Welcome to the forum
This is usually a sign that something else is using the COM port
Thanks for the quick response, I have seen this being raise a lot online but I can figure out what is using it/If i can rest it/or if I can change the Com port
Any ideas or feedback would be great
Before considering changing the COM port, close everything on the PC except one instance of the IDE, pug on the Arduino and confirm that a COM port is created and that you have that COM port selected in the IDE. Now try uploading a simple sketch such as Blinkl
Which version of the IDE?
As far as I know there is still a bug in IDE 2.x regarding this (it is specific to the FTDI serial-to-usb converter as used on an original Nano). Close the serial plotter and next the serial monitor.
You can find which process / application uses Windows process explorer (you'll need to download and install it).
Next you can follow the instructions in Exit error status 1 on Arduino uno - #15 by ptillisch; there are some more details in Exit error status 1 on Arduino uno - #18 by sterretje.
Thanks I'll have a play around
Hey Thanks. Uhh it would be the latest verion, I downloaded it today I think its IDE 2.3.4
I've closed the plotter and monitor and then it get stuck on Uploading. it's Idel for hours with no progression bar nor indication of it actually uploadinf
Take not too of the post by @sterretje
There are some bugs in IDE 2.3.4 that prevent uploading code if the Serial monitor or Serial plotter are open or have been open
Oh Just saw the additional instrcutions, I'll check them out, thank you
Right okay, Noted. Appreciate it
