Help sourcing a component.
I purchased a 7 Pin panel mounting DIN socket from Farnell (Item No. 1193070), but they appear to have no matching plugs. Their 7 Pin DIN plugs have all their pins in an arc around the edge whereas the socket has 6 pins around the edge (at 60o) and one in the centre.
Does anyone know where I can get a 7 pin DIN plug to mate with the above socket?
With solder (not crimp or screw) contacts, if possible.
Ehmm
If i look for that part, i get a page that also has a link of related products: This is one of those
The SV70 is complementary to the KFV70.
Tip: Open the datasheet link.
The pictures shown by Farnell, are just meant for indication.
The datasheet shows you what to look for and has detailed information.
Aha! The mysterious 7-pin DIN surfaces again.
See:
Hope that helps.
@MAS3
Thanks. I couldn't see it for looking!
