[Help] Sparkfun ITG-3200 gyro
Ello there,
I’m trying to get a gyro to work, but the example code from sparkfun’s website throws a load of errors at me when I click verify or upload in the arduino IDE. I’ve checked the “Read this…” sections in the subforum, but trying it doesn’t solve the problem.
The code is from 2010, and I assume it’s from before Arduino 1.0. I’ve searched for post 1.0 code for the ITG-3200, but to no avail. Help me arduino forums, you’re my only hope :frowning:
To be frank, I just need the x & y rotation values. And I would be more than content with some pointers in the right direction. I’m not new to programming, but I am to Arduino.
Sparkfun ITG-3200 webpage: https://www.sparkfun.com/products/9801
Quick start guide: https://www.sparkfun.com/tutorials/265
Example code:
3/16/11
Basic Example Sketch for the ITG-3200 (http://www.sparkfun.com/products/9801)
SparkFun Electronics 2011
Ryan Owens
This code is public domain buy you buy me a beer if you use this and we meet someday (Beerware license).
To use this example code, attach:
Arduino  :  ITG-3200 Breakout
3.3V  :  VDD
3.3V  :  VIO
GND   :  GND
SDA   :  A4
SCL   :  A5
Load the sketch and open the serial window at 9600 bps. Arduino will output the raw X,Y and Z axis data being read from the gyroscope.
//The Wire library is used for I2C communication
#include <Wire.h>
//This is a list of registers in the ITG-3200. Registers are parameters that determine how the sensor will behave, or they can hold data that represent the
//sensors current status.
//To learn more about the registers on the ITG-3200, download and read the datasheet.
char WHO_AM_I = 0x00;
char SMPLRT_DIV= 0x15;
char DLPF_FS = 0x16;
char GYRO_XOUT_H = 0x1D;
char GYRO_XOUT_L = 0x1E;
char GYRO_YOUT_H = 0x1F;
char GYRO_YOUT_L = 0x20;
char GYRO_ZOUT_H = 0x21;
char GYRO_ZOUT_L = 0x22;
//This is a list of settings that can be loaded into the registers.
//DLPF, Full Scale Register Bits
//FS_SEL must be set to 3 for proper operation
//Set DLPF_CFG to 3 for 1kHz Fint and 42 Hz Low Pass Filter
char DLPF_CFG_0 = (1<<0);
char DLPF_CFG_1 = (1<<1);
char DLPF_CFG_2 = (1<<2);
char DLPF_FS_SEL_0 = (1<<3);
char DLPF_FS_SEL_1 = (1<<4);
//I2C devices each have an address. The address is defined in the datasheet for the device. The ITG-3200 breakout board can have different address depending on how
//the jumper on top of the board is configured. By default, the jumper is connected to the VDD pin. When the jumper is connected to the VDD pin the I2C address
//is 0x69.
char itgAddress = 0x69;
//In the setup section of the sketch the serial port will be configured, the i2c communication will be initialized, and the itg-3200 will be configured.
  //Create a serial connection using a 9600bps baud rate.
  //Initialize the I2C communication. This will set the Arduino up as the 'Master' device.
  Wire.begin();
  //Read the WHO_AM_I register and print the result
  char id=0;
  id = itgRead(itgAddress, 0x00);
  Serial.print("ID: ");
  Serial.println(id, HEX);
  //Configure the gyroscope
  //Set the gyroscope scale for the outputs to +/-2000 degrees per second
  itgWrite(itgAddress, DLPF_FS, (DLPF_FS_SEL_0|DLPF_FS_SEL_1|DLPF_CFG_0));
  //Set the sample rate to 100 hz
  itgWrite(itgAddress, SMPLRT_DIV, 9);
//The loop section of the sketch will read the X,Y and Z output rates from the gyroscope and output them in the Serial Terminal
  //Create variables to hold the output rates.
  int xRate, yRate, zRate;
  //Read the x,y and z output rates from the gyroscope.
  xRate = readX();
  yRate = readY();
  zRate = readZ();
  //Print the output rates to the terminal, seperated by a TAB character.
  Serial.print(xDegrees);
  Serial.print('\t');
  Serial.print(yDegrees);
  Serial.print('\t');
  Serial.println(zDegrees);
  //Wait 10ms before reading the values again. (Remember, the output rate was set to 100hz and 1reading per 10ms = 100hz.)
  delay(10);
//This function will write a value to a register on the itg-3200.
//Parameters:
//  char address: The I2C address of the sensor. For the ITG-3200 breakout the address is 0x69.
//  char registerAddress: The address of the register on the sensor that should be written to.
//  char data: The value to be written to the specified register.
void itgWrite(char address, char registerAddress, char data)
  //Initiate a communication sequence with the desired i2c device
  Wire.beginTransmission(address);
  //Tell the I2C address which register we are writing to
  Wire.send(registerAddress);
  //Send the value to write to the specified register
  Wire.send(data);
  //End the communication sequence
  Wire.endTransmission();
//This function will read the data from a specified register on the ITG-3200 and return the value.
//Parameters:
//  char registerAddress: The address of the register on the sensor that should be read
//Return:
//  unsigned char: The value currently residing in the specified register
unsigned char itgRead(char address, char registerAddress)
  //This variable will hold the contents read from the i2c device.
  unsigned char data=0;
  //Send the register address to be read.
  //Send the Register Address
  //End the communication sequence.
  //Ask the I2C device for data
  Wire.requestFrom(address, 1);
  //Wait for a response from the I2C device
  if(Wire.available()){
    //Save the data sent from the I2C device
    data = Wire.receive();
  //Return the data read during the operation
  return data;
//This function is used to read the X-Axis rate of the gyroscope. The function returns the ADC value from the Gyroscope
//NOTE: This value is NOT in degrees per second.
//Usage: int xRate = readX();
int readX(void)
  int data=0;
  data = itgRead(itgAddress, GYRO_XOUT_H)<<8;
  data |= itgRead(itgAddress, GYRO_XOUT_L);
  return data;
//This function is used to read the Y-Axis rate of the gyroscope. The function returns the ADC value from the Gyroscope
//Usage: int yRate = readY();
int readY(void)
  int data=0;
  data = itgRead(itgAddress, GYRO_YOUT_H)<<8;
  data |= itgRead(itgAddress, GYRO_YOUT_L);
  return data;
//This function is used to read the Z-Axis rate of the gyroscope. The function returns the ADC value from the Gyroscope
//Usage: int zRate = readZ();
int readZ(void)
  int data=0;
  data = itgRead(itgAddress, GYRO_ZOUT_H)<<8;
  data |= itgRead(itgAddress, GYRO_ZOUT_L);
  return data;
But not at us?
Compiles using IDE 1.0 (untested)
3/16/11
Ryan Owens
3.3V  :  VDD
3.3V  :  VIO
GND   :  GND
SDA   :  A4
SCL   :  A5
#include <Wire.h>
//is 0x69.
  Wire.begin();
  char id=0;
  xRate = readX();
  yRate = readY();
  zRate = readZ();
  Serial.print(xRate);
  Serial.print('\t');
  Serial.print(yRate);
  Serial.print('\t');
  Serial.println(zRate);
  delay(10);
//Parameters:
  Wire.write(registerAddress);
  Wire.write(data);
//Parameters:
//Return:
    data = Wire.read();
  return data;
int readX(void)
  int data=0;
  return data;
int readY(void)
  int data=0;
  return data;
int readZ(void)
  int data=0;
  return data;
but the example code from sparkfun's website throws a load of errors at me when I click verify or upload in the arduino IDE.
I know its embarrassing, but, you really need to show us your errors. I tried to compile your code, but I get:
sketch_jun04a.ino: In function 'void loop()': sketch_jun04a:82: error: 'readY' was not declared in this scope sketch_jun04a:83: error: 'readZ' was not declared in this scope sketch_jun04a:86: error: 'xDegrees' was not declared in this scope sketch_jun04a:88: error: 'yDegrees' was not declared in this scope sketch_jun04a:90: error: 'zDegrees' was not declared in this scope
Now, these have NOTHING to do with version incompatibility or anything like that. They are plain and simple errors.
I also get messages like:
sketch_jun04a.ino: In function 'void itgWrite(char, char, char)': sketch_jun04a:106: error: 'class TwoWire' has no member named 'send'
As of Arduino 1.0, the Wire.send() function was renamed to Wire.write() for consistency with other libraries.
But those should be easy (for you) to fix.
Even excluding the Wire updates, that's pretty crumby example code
PaulS:
Ah! That's exactly what I get. Good to know it's not just me. I'll try and fix the code then.
