Help!-Spectrum analyzer signal output to pin13
Total noob.
I cannot seem to get this to work. I am trying to get Pin 13 to turn on and off based on spectrum values so I can activate a relay
I left the serial.print code in there with the intent that I would use that to find the each band level and make adjustments. Suppose I need to get there first!
ie. Pin ON <100
Pin Off >100
int analogPin = 0; // read from multiplexer using analog input 0
int strobePin = 4; // strobe is attached to digital pin 4
int resetPin = 5; // reset is attached to digital pin 5
int spectrumValue[7]; // to hold a2d values
int digitalpin1 = 13;
pinMode(analogPin, INPUT);
pinMode(strobePin, OUTPUT);
pinMode(resetPin, OUTPUT);
analogReference(DEFAULT);
//pinMode(digitalpin1, LOW);
digitalWrite(resetPin, LOW);
digitalWrite(strobePin, HIGH);
//digitalWrite(digitalpin1, HIGH);
digitalWrite(resetPin, HIGH);
for (int i = 0; i < 7; i++) //i is equal to 0, if i is less than 7(bands from analog pin0) repeat loop until it equals 7.
digitalWrite(strobePin, LOW);
delayMicroseconds(30); // to allow the output to settle
spectrumValue = analogRead(analogPin);
// comment out/remove the serial stuff to go faster
// - its just here for show
if (spectrumValue < 10)
Serial.print(" ");
Serial.print(spectrumValue*);*
//digitalWrite(13, HIGH);
else if (spectrumValue < 100 )
Serial.print(" ");
else if (spectrumValue > 100 )
digitalWrite(digitalpin1, LOW);
Serial.print(" ");
You need
  pinMode (digitalpin1, OUTPUT) ;
in setup.
Ty Mark-
Well that got things going. I am reading the pin out voltage which is fluctuating from 1.3v to 4.5. (based on spectrumValue). I was hoping for an off/off response.
else if (spectrumValue > 110 )
  • Serial.print(" “);*
    _ Serial.print(spectrumValue*);_
    _
    digitalWrite(digitalpin1, LOW);_
    _
    }_
    _ {
    Serial.print(” ");
    Serial.print(spectrumValue);
    digitalWrite(digitalpin1, HIGH);*_
5V should return 1023 and 1.3V should return 266 and you're checking around 100-110....
