boolean clipping = 0;
byte newData = 0;
byte prevData = 0;
unsigned int time = 0;//keeps time and sends vales to store in timer[] occasionally
int timer[10];//storage for timing of events
int slope[10];//storage for slope of events
unsigned int totalTimer;//used to calculate period
unsigned int period;//storage for period of wave
byte index = 0;//current storage index
float frequency;//storage for frequency calculations
int maxSlope = 0;//used to calculate max slope as trigger point
int newSlope;//storage for incoming slope data
//variables for decided whether you have a match
byte noMatch = 0;//counts how many non-matches you've received to reset variables if it's been too long byte slopeTol = 3;//slope tolerance- adjust this if you need
int timerTol = 10;//timer tolerance- adjust this if you need
//variables for amp detection
unsigned int ampTimer = 0;
byte maxAmp = 0;
byte checkMaxAmp;
byte ampThreshold = 30;//raise if you have a very noisy signal
#include <Stepper.h>
Stepper stepper(STEPS, 8, 9, 10, 11);
int freq="desired Frequency"
void setup(){
pinMode(13,OUTPUT);//led indicator pin
pinMode(12,OUTPUT);//output pin
stepper.setSpeed(5);
cli();//diable interrupts
//set up continuous sampling of analog pin 0 at 38.5kHz
//clear ADCSRA and ADCSRB registers
ADCSRA = 0;
ADCSRB = 0;
ADMUX |= (1 << REFS0); //set reference voltage
ADMUX |= (1 << ADLAR); //left align the ADC value- so we can read highest 8 bits from ADCH register only
ADCSRA |= (1 << ADPS2) | (1 << ADPS0); //set ADC clock with 32 prescaler- 16mHz/32=500kHz
ADCSRA |= (1 << ADATE); //enabble auto trigger
ADCSRA |= (1 << ADIE); //enable interrupts when measurement complete
ADCSRA |= (1 << ADEN); //enable ADC
ADCSRA |= (1 << ADSC); //start ADC measurements
sei();//enable interrupts
ISR(ADC_vect) {//when new ADC value ready
PORTB &= B11101111;//set pin 12 low
prevData = newData;//store previous value
newData = ADCH;//get value from A0
if (prevData < 127 && newData >=127){//if increasing and crossing midpoint
newSlope = newData - prevData;//calculate slope
if (abs(newSlope-maxSlope)<slopeTol){//if slopes are ==
//record new data and reset time
slope[index] = newSlope;
timer[index] = time;
time = 0;
if (index == 0){//new max slope just reset
PORTB |= B00010000;//set pin 12 high
noMatch = 0;
index++;//increment index
else if (abs(timer[0]-timer[index])<timerTol && abs(slope[0]-newSlope)<slopeTol){//if timer duration and slopes match
//sum timer values
totalTimer = 0;
for (byte i=0;i<index;i++){
totalTimer+=timer*; *
period = totalTimer;//set period
*//reset new zero index values to compare with *
timer[0] = timer[index];
slope[0] = slope[index];
index = 1;//set index to 1
*PORTB |= B00010000;//set pin 12 high *
*noMatch = 0; *
*else{//crossing midpoint but not match *
*index++;//increment index if (index > 9){ *
*reset(); *
*else if (newSlope>maxSlope){//if new slope is much larger than max slope *
maxSlope = newSlope;
time = 0;//reset clock
*noMatch = 0; *
*index = 0;//reset index *
*else{//slope not steep enough *
*noMatch++;//increment no match counter *
*if (noMatch>9){ *
*reset(); *
*if (newData == 0 || newData == 1023){//if clipping *
*clipping = 1;//currently clipping *
*Serial.println("clipping"); *
*time++;//increment timer at rate of 38.5kHz *
*ampTimer++;//increment amplitude timer *
*if (abs(127-ADCH)>maxAmp){ *
*maxAmp = abs(127-ADCH); *
*if (ampTimer==1000){ *
*ampTimer = 0; *
*checkMaxAmp = maxAmp; *
*maxAmp = 0; *
*void reset(){//clean out some variables *
*noMatch = 0;//reset match couner *
*maxSlope = 0;//reset slope *
*void checkClipping(){//manage clipping indication *
*if (clipping){//if currently clipping *
*clipping = 0; *
*void loop(){ *
checkClipping();
*if (checkMaxAmp>ampThreshold){ *
*int frequency = 38462/float(period);//calculate frequency timer rate/period *
if (freq - 10 > frequency)
*for ( int i=0 ; i<100 ; i=i+1){ *
*digitalWrite(motorPin1, LOW); *
*digitalWrite(motorPin2, LOW); *
*digitalWrite(motorPin3, HIGH); *
*digitalWrite(motorPin4, HIGH); *
*delay(3); *
*digitalWrite(motorPin1, HIGH); *
*digitalWrite(motorPin3, LOW); *
*delay(3); *
*digitalWrite(motorPin2, HIGH); *
*digitalWrite(motorPin4, LOW); *
*delay(3); *
*delay(3); *
*delay(1000); *
*if (freq - 5 > frequency) *
*for ( int i=0 ; i<50 ; i=i+1){ *
*delay(3); *
*delay(3); *
*delay(3); *
*delay(3); *
*delay(6000); *
*if (freq + 10 < frequency) { *
*delay(3); *
*delay(3); *
*delay(3); *
*delay(3); *
*delay(1000); *
if (freq + 5 < frequency) {
*delay(3); *
*delay(3); *
*delay(3); *
*delay(3); *
*delay(6000); *
*delay(100); *
