Help : There is sounds whenever i upload my coding into my LCD
Whenever I tried uploading my coding into my Arduino, there will always be sounds playing, I have tried removing the sounds using "Serial.Write(232);, but it does not seem to work. Is there any other ways to remove the sounds?
//#include <SoftwareSerial.h>
#define TxPin 1
const int buttonPin = 10;
int buttonState;
int pin8 = 8;
int pin9 = 9;
int pin11 = 11;
int pin12 = 12;
int pin13 = 13;
boolean toggle = false;
int inByte = 0;
int flag=0;
int num0, num1, num2, num3, numTOTAL;
int inputPin0 = A0;
int inputPin1 = A1;
int inputPin2 = A2;
int inputPin3 = A3;
int average0 = 0;
int readings[40]; //Size of my array
int Counter = 1;
//SoftwareSerial mySerial = SoftwareSerial(255, TxPin);
void backlightOn()
{ //turns on the backlight
Serial.write(17); //turn backlight on
  //mySerial.write(18); //turn backlight off
  pinMode(pin8, OUTPUT);
  pinMode(pin9, OUTPUT);
  pinMode(pin11, OUTPUT);
  pinMode(pin12, OUTPUT);
  pinMode(pin13, OUTPUT);
 pinMode(TxPin, OUTPUT);
 digitalWrite(TxPin, HIGH);
 delay(100); //wait 3 seconds
  Serial.write(12);
Serial.println("The weight(KG):"); // printed out
  Serial.write(13);
  backlightOn();
 Serial.write(232);
  buttonState = digitalRead(buttonPin);
  if(buttonState == LOW)
    flag = 0;
  if((buttonState == HIGH) && (flag == 0))
    inByte++;
    if(inByte == 33)
      inByte = 0;
    ABC();
    flag = 1;
  inputPin0 = constrain(inputPin0, 1, 1023);
  inputPin1 = constrain(inputPin1, 1, 1023);
  inputPin2 = constrain(inputPin2, 1, 1023);
  inputPin3 = constrain(inputPin3, 1, 1023);
  if (Counter <= 20)
    num0 = analogRead(inputPin0);
    num1 = analogRead(inputPin1);
    num2 = analogRead(inputPin2);
    num3 = analogRead(inputPin3);
    readings[Counter]=(num0+num1+num2+num3)/4;
    numTOTAL = 0;
    for (int i=1; i <= 20; i++) {
      numTOTAL = numTOTAL + readings[i];
  //  num0 = readings0[1]+readings0[2]+readings0[3]+readings0[4]+readings0[5];
    average0 = (numTOTAL)/20;
    Counter++;
    if (Counter >= 21)
        Counter = 1;
    //move the cursor to a particular point that needs to be updated
    //update when necessary (5% no update)
   //if the analog value has less than 5% changes, no change
    //if (average0 < 1)
    //  digitalWrite(average0, );
    // else {
    // digitalWrite();
    //print the analog value
    //Serial. printIn(analogValue);
  delay(100); //delay
//Serial.write(12);
  Serial.write(148);
  Serial.println(average0);
void ABC() {
  switch (inByte)
  case 1:
    digitalWrite(8, LOW);
    digitalWrite(9, LOW);
    digitalWrite(11, LOW);
    digitalWrite(12, LOW);
    digitalWrite(13, LOW);
    Serial.print("0");
    Serial.print("0");
    Serial.print("0");
    Serial.print("0");
    Serial.println("0");
    toggle = !toggle;
  case 2:
    digitalWrite(13, HIGH);
    Serial.print("0");
    Serial.print("0");
    Serial.print("0");
    Serial.print("0");
    Serial.println("1");
    toggle = !toggle;
  case 3:
    digitalWrite(12, HIGH);
    Serial.print("0");
    Serial.print("0");
    Serial.print("0");
    Serial.print("1");
    toggle = !toggle;
  case 4:
    Serial.print("0");
    Serial.print("0");
    Serial.print("0");
    Serial.print("1");
    toggle = !toggle;
  case 5:
    digitalWrite(11, HIGH);
    Serial.print("0");
    Serial.print("0");
    Serial.print("1");
    Serial.print("0");
    toggle = !toggle;
  case 6:
    Serial.print("0");
    Serial.print("0");
    Serial.print("1");
    Serial.print("0");
    toggle = !toggle;
  case 7:
    Serial.print("0");
    Serial.print("0");
    Serial.print("1");
    Serial.print("1");
    toggle = !toggle;
  case 8:
    Serial.print("0");
    Serial.print("0");
    Serial.print("1");
    Serial.print("1");
    toggle = !toggle;
  case 9:
    digitalWrite(9, HIGH);
    Serial.print("0");
    Serial.print("1");
    Serial.print("0");
    Serial.print("0");
    toggle = !toggle;
  case 10:
    Serial.print("0");
    Serial.print("1");
    Serial.print("0");
    Serial.print("0");
    toggle = !toggle;
  case 11:
    Serial.print("0");
    Serial.print("1");
    Serial.print("0");
    Serial.print("1");
    toggle = !toggle;
You may need an exorcist! :astonished:
{OK, from where do the sounds come, and what sounds are they?}
