Hello guys, Newbie here...
I would like some advices for a wifi remote controlled project
I've been spoofing around trying to figure out what would be the best way to achieve this,
knowing that space and form factor would be an obstacle. I apologize for my english I'm from France actually.
So I hand drew a little sketch so you guys could advice me what would be better easy and more precise.
Transmetter:
_ 1 Arduino ???nano???
_ 2 Oled 12c display (is it possible???)
_ 5 Rotary Encoders
_ 3 Press Buttons
_ 2 Leds
_ 1 Light Sensor
_ 1 Wifi Transceiver
Receiver:
_ 1 6 digit led display or oled
_ 1/2 group of 2 or 3 step or servo motors (1/2/5)
_ 2/2 group of 2 or 3 step or servo motors (4/3/6)
_ 1 group of 2 step or servo motors (7/9)
_ 1 servo motor ( 8 )
_ 3 Potentiometers Vr 1 to 3
Led 1 should blink when ever Either Rotary encoder 1 to 3 is used
Led 2 should blink then stay on when step or servo motor 7,8 and 9 are locked in position given by Rotary Encoder 4 and 5
Long press on Press Button 1 On/Off or Sleep (maybe use a digital pin to switch power for oleds and wifi)
Press Button 2 for Oled 1 Menu access, using Rotary Encoder 1 to navigate
Press Button 3 for Oled 2 Menu access, using Rotary Encoder 1 to navigate
Rotary Encoder 1 will give same command to step or servo motors 1 and 4
Rotary Encoder 2 will give same command to step or servo motors 2 and 3
Rotary Encoder 3 (option) will give same command to step or servo motors 5 and 6 (option)
Rotary Encoder 4 will give same command to step or servo motors 7 (CW) and 9 (CCW)
Vr 1 and 2 should be used as limit feedbacks for step or servo motors 7 and 9
Vr 3 should be used as limit feedbacks for step motor 8
Oled 1 on remote should be used to display infos about Rotary Encoders 1 to 3
Oled 2 on remote should be used to display infos about Rotary Encoders 4 to 5 and the light sensor
The 6 digit led or Oled display will show infos about step or servo motors 7, 8 and 9...
My first question is, can the remote and the receiver be built around a arduino nano ?
What would be more precise for 1/2 to 1° angle rotation step motor or servo?
What would be more precise for 1/2 to 1 mm displacement ?
I know I will have to learn a lot probably build some libraries. But I am so motivated and willing to learn.
So if I could get some advices and direction to start it would be price less.
Thanking you guys in advance for your patience and Time...
"There are no stupid questions, but there are lots Dumb answers..."
