The delay function should not be used when you are waiting for something else to happen. IE,
i cant get reset commande from the ir remote ; i get it only if the delay finish
Because it results in this happening.
So delay(10601000) is going to block you from doing anything for 10 minutes. This is 10 minutes of wasted time when the Arduino could be doing something else while its waiting for the 10 minutes to elapse.
You want to use a non blocking method like the one used in the Arduino example "Blink Without Delay". In this example, it shows you how to do something without waiting for something else to be finished. This is the Arduinos way of multitasking on a single thread processor.
A single 7 segment display? Where is that in your code? Or are you setting the display with pin 2 - 8?
I cleaned up your code a little bit.
#include <IRremote.h>
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
byte numbers[] = {
B0010000, B1011011, B0001100, B0001001, B1000011 }; // insert the rest of the display values here
long time = millis();
byte idx = 0;
for(byte i = 2; i < 9; i++)
pinMode(i, OUTPUT);
irrecv.enableIRIn(); // Start the receiver
if (irrecv.decode(&results))
Serial.println(results.value );
if(results.value==2706322374)
decompteur(4);
irrecv.resume(); // Receive the next value
else if(results.value==1231570528)
decompteur(2);
void decompteur(byte n)
if( millis() - time >= 60*1000)
if(idx < n)
for(byte num = 0; num < 7; num++)
digitalWrite(num+2, bitRead(numbers[n - idx], num) );
idx++;
idx = 0;
time = millis();
void resetCounter() // call this function to reset the counter back to zero if you need to.
idx = 0;
You will need to add the rest of the numbers 0 - 9 and do some math to see what values you need to show based on the counter.
There should be pre-built 7 segment displays that have a library you can use to get them to work. This might be easier for you then wiring everything up and hoping for the best. But that's up to you.
As for you displays, (depending what you do) you need to look at the counter and see if it is greater or less than 10. This will tell your code what to display on each 7 segment disp. The first display will show 0 - 9 and the second will only show 0 and 1.
if i want to create a big 7 segment using 5 led/segment
int M,Min, S, Sec;
boolean Reset = false, Stop = false, Paused = false;
volatile boolean timeFlag = false;
StartTimer(0,10);
// if minutes is set to NULL, it will be give a default value of 0, otherwise minutes will be set to input value
// seconds is basically the same but its default value is 59
if( !CountDownTimer() ) // check if the timer has reached 0
//ResetTimer(); // if it has, reset the timer. *OPTIONAL*
if(TimeHasChanged() ) // this prevents the time from being constantly shown.
Serial.print(ShowMinutes());
Serial.print(":");
Serial.println(ShowSeconds()); // This DOES NOT format the time to 0:0x when seconds is less than 10.
// if you need to format the time to standard format, use the sprintf() function.
StopTimerAt(0,2); // With this, you can stop the timer at any minute or second
boolean CountDownTimer()
timeFlag = false;
if(!Stop && !Paused) // if not Stopped or Paused, run the timer
if(millis() - time > 1000) // check the time difference and see if 1 second has elapsed
time = millis(); // 1 second HAS elapsed, so reset the time variable
S > 0? S-- : (M-- , S = 59); // Check to see if S can be decremented and is still above 0.
// If S goes below 0, reset it back to 59 and decrement M by
timeFlag = true;
if(M == 0 && S == 0) // check to see if both M and S are 0
Stop = true; // If so, stop the timer
return !Stop; // return the state of the timer
void ResetTimer()
StartTimer(Min, Sec);
Stop = false;
void StopTimer()
Stop = true;
void StopTimerAt(int minutes, int seconds)
if(minutes == ShowMinutes() && seconds == ShowSeconds())
Stop = true;
void PauseTimer()
Paused = true;
void ResumeTimer() // You can resume the timer if you ever stop it.
Paused = false;
void StartTimer(int minutes, int seconds)
Min = minutes; // set to global vars
Sec = seconds; // ------------------
(minutes == NULL) ? M = 0 : (M = minutes - 1);
(seconds == NULL) ? S = 60: (S = seconds);
Stop = false;
int ShowMinutes()
return M;
int ShowSeconds()
return S;
boolean TimeHasChanged()
return timeFlag;
boolean TimeCheck(int minutes, int seconds) // output is true if timer equals requested time
return (minutes == ShowMinutes() && seconds == ShowSeconds());
Ok, so I gave you a working count down timer with some good options, now all you need to do is get a number from the IR controller and use the values from ShowMinutes() and ShowSeconds() to put on your 7 segment display(s).
What progress have you made with your code so far?
