Help to find 3way solenoid!!
Hi, I need somebody help me to find 3way solenoid. It will be control by accelerate sensor. I cannot find any work with arduino :frowning:
Thanks so much guys, 8)
What are we controlling "3 ways"? Air? Oil? Water? Are we controlling with Analog? Or is it just an "All Ports Blocked in Center' and then energizing the "A" side or "B" side? And run from an Arduino (albeit indirectly)?
Need to know those answers please.
I think yiu're correct.
A, B , or NEITHER.
rmetzner49:
. Sr the unclear. I plant to use accelerometer to control 3way pneumatic valve. So if the accelerometer detecs motion move up/down it will unlock 1 valve and lock the other. If there is no motion,it will lock all valve so the cylinder cannot move. It will run from arduino. Thanks so much!
THIS:
MEANS THIS:
I think you're correct.
CASE-1: A
CASE-2: B
CASE-3:, NEITHER.
