Help to find info of an LCD
Hello
I got an LCD that I can't source info
  • On the back it is write Data Vision Phico D-0 94V-0 9930. This number seem to be a generic model.
  • It has a 20 pins connector . The LCD on the module is 7.5 cm X 5.5 cm
I wanted to install an I2C module on it but the module has 16 pins and the LCD 20.
Any info appreciated.
Martin
I took some photo if it could help to find Info.
How can I interface the LCD with an I2C module? The screen has 20 pins and the I2C module 16.
Martin
Not the best photos,
Its an DG-12864-12. You can find the pinout here: http://www.datavision.com.tw/en/lcm_02_1.php?P_Id=32
The I2C-LCD adapter for character LCDs use the 4-bit mode of the controller. The controller on this display does not have it.
Also this dsplay needs a negative voltage for the contrast.
Rintin,
Wow! thank you very much for this info.
I was about to give-up. Will see if I can use it.
Martin
This is a display with a T6963 controller. If you really want to use this display, then make it work in 8-bit parallel mode first:
  1. Provide the -5 V external power with the var-pot
  2. Find a suitable library (e.g. u8g2) and do all the wiring
If this works, you could start with the i2c adapter. But: There will be no Arduino lib and also the number of adapters is very limited (google reveals only this: https://www.coptonix.com/_en/html/i2c_glcd_adapter.html)
I personally would say, it is not worth the effort. Look out for a ST7565 based LCD module. It includes the negative voltage generator, includes an electronic var pot and comes with a SPI interface. Maybe an ST7920 is also an option.
Oliver
olikraus:
Oliver
That's what I have conclude. Not worth to work on this. Better spend few dollars to get another LCD
Thanks to all who helped me with it.
Martin
Hello,the lcd you have and the DG12864-12 is different you need to go to the philco document and ID your correct board also the -5vdc supply is not difficult to build from a junkbox. I do this for fun and the challenge is getting these to work.
