post the comlete sketch with which you tested the button toggle functionality
This code-version has additional debug-macros
The code uses the macro dbgc
which works this way
only in case the value of the variable has changed print the value a SINGLE time
then do not print anymore until the value changes again.
This will make visible what is really happening in your code.
printing with each iteration of loop() is too fast to follow it.
// SMC3.ini is basic Motor PID driver designed for motion simulators with upto 3 motors (written for UNO R3)
// --Modified by Blame73 for Cytron MD30C, May 2020
// --Modified directions and brakes that were inverted on half side of the range
// --(motion was faster near the center and slower towards limits)
// Set to MODE1 for use with a typical H-Bride that requires PWM and 1 or 2 direction inputs
// Set to MODE2 for a 43A "Chinese" IBT-2 H-Bridge from e-bay or equiv
// Set to MODE2 for Cytron MD30C too
#define MODE2
// Uncomment the following line to reverse the direction of Motor 1.
//#define REVERSE_MOTOR1
// Uncomment ONE of the following lines to enable analogue input AN5 as a scaler for the motion values.
// #define ENABLE_POT_SCALING
// #define ENABLE_NON_LINEAR_POT_SCALING
// Uncomment the following line to enable the second software serial port.
// NOTE: This is currently not working - leave commented out until fixed!!!
// #define SECOND_SERIAL
// COMMAND SET:
// MACRO-START * MACRO-START * MACRO-START * MACRO-START * MACRO-START * MACRO-START *
// a detailed explanation how these macros work is given in this tutorial
// https://forum.arduino.cc/t/comfortable-serial-debug-output-short-to-write-fixed-text-name-and-content-of-any-variable-code-example/888298
#define dbg(myFixedText, variableName) \
Serial.print( F(#myFixedText " " #variableName"=") ); \
Serial.println(variableName);
#define dbgi(myFixedText, variableName,timeInterval) \
static unsigned long intervalStartTime; \
if ( millis() - intervalStartTime >= timeInterval ){ \
intervalStartTime = millis(); \
Serial.println(variableName); \
#define dbgc(myFixedText, variableName) \
static long lastState; \
if ( lastState != variableName ){ \
Serial.print( F(#myFixedText " " #variableName" changed from ") ); \
Serial.print(lastState); \
Serial.print( F(" to ") ); \
lastState = variableName; \
#define dbgcf(myFixedText, variableName) \
static float lastState; \
// MACRO-END * MACRO-END * MACRO-END * MACRO-END * MACRO-END * MACRO-END * MACRO-END *
// [] Drive all motors to defined stop positions and hold there
// [Axx],[Bxx],[Cxx] Send position updates for Motor 1,2,3 where xx is the binary position limitted to range 0-1024
// [Dxx],[Exx],[Fxx] Send the Kp parameter for motor 1,2,3 where xx is the Kp value multiplied by 100
// [Gxx],[Hxx],[Ixx] Send the Ki parameter for motor 1,2,3 where xx is the Ki value multiplied by 100
// [Jxx],[Kxx],[Lxx] Send the Kd parameter for motor 1,2,3 where xx is the Kd value multiplied by 100
// [Mxx],[Nxx],[Oxx] Send the Ks parameter for motor 1,2,3 where xx is the Ks value
// [Pxy],[Qxy],[Rxy] Send the PWMmin and PWMmax values x is the PWMmin and y is PWMmax each being in range 0-255
// [Sxy],[Txy],[Uxy] Send the Motor Min/Max Limits (x) and Input Min/Max Limits (y) (Note same value used for Min and Max)
// [Vxy],[Wxy],[Xxy] Send the Feedback dead zone (x) and the PWM reverse duty (y) for each motor
// [rdx] Read a value from the controller where x is the code for the parameter to read
// [ena] Enable all motors
// [sav] Save parameters to non-volatile memory
// [ver] Send the SMC3 software version
// Arduino UNO Pinouts Used
// 9 - Motor 1 PWM
// 10 - Motor 2 PWM
// 11 - Motor 3 PWM
// 2 - Motor 1 H-Bridge ENA
// 3 - Motor 1 H-Bridge ENB
// 4 - Motor 2 H-Bridge ENA
// 5 - Motor 2 H-Bridge ENB
// 6 - Motor 3 H-Bridge ENA
// 7 - Motor 3 H-Bridge ENB
// A0 - Motor 1 Feedback
// A1 - Motor 2 Feedback
// A2 - Motor 3 Feedback
// A5 - Motion scaler pot input
// BOF preprocessor bug prevention - leave me at the top of the arduino-code
#if 1
__asm volatile ("nop");
#endif
#include <EEPROM.h>
#include <SoftwareSerial.h>
// defines for setting and clearing register bits
#ifndef cbi
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#endif
#ifndef sbi
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
#endif
#define COM0 0 // hardware Serial Port
#define COM1 1 // Software Serial Port
#define START_BYTE '[' // Start Byte for serial commands
#define END_BYTE ']' // End Byte for serial commands
#define PROCESS_PERIOD_uS 250 // 244 -> 4096 per second approx
#define TIMER_UPPER_LIMIT 4294966000 // Used to check for timer wraparound
#define TIMER_LOWER_LIMIT 1000 // Used to check for timer wraparound
unsigned long TimesUp = 0; // Counter used to see if it's time to calculate next PID update
int Feedback1 = 512;
int Feedback2 = 512;
int Feedback3 = 512;
int Target1 = 512;
int Target2 = 512;
int Target3 = 512;
int PotInput = 512;
unsigned int RxByte[2] = {0}; // Current byte received from each of the two comm ports
int BufferEnd[2] = { -1}; // Rx Buffer end index for each of the two comm ports
unsigned int RxBuffer[5][2] = {0}; // 5 byte Rx Command Buffer for each of the two comm ports
unsigned long LoopCount = 0; // unsigned 32bit, 0 to 4,294,967,295 to count times round loop
unsigned long LastCount = 0; // loop counter the last time it was read so can calc delta
byte errorcount = 0; // serial receive error detected by invalid packet start/end bytes
unsigned int CommsTimeout = 0; // used to reduce motor power if there has been no comms for a while
byte PowerScale = 7; // used to divide(shift) PID result changes when in low power
// +-|PWR |--------------| USB |-----+
// | +----+ +------+ o|
// | o|
// | o|AREF
// | o|GND
// NC|o o|13 TTL (software) Serial
// IOREF|o +----+ o|12 TTL (software) Serial
// RESET|o | | o|11~ PWM Motor 3
// 3.3V|o | | o|10~ PWM Motor 2
// 5V|o | | Arduino o|9~ PWM Motor 1
// GND|o | | UNO o|8
// GND|o | | |
// VIN|o | | o|7 Motor 3 ENB
// | | | o|6~ Motor 3 ENA
// Motor 1 Pot A0|o | | o|5~ Motor 2 ENB
// Motor 2 Pot A1|o | | o|4 Motor 2 ENA
// Motor 3 Pot A2|o | | o|3~ Motor 1 ENB
// A3|o | | o|2 Motor 1 ENA
// A4|o | | o|1
// Motion Scaler A5|o +-/\-+ o|0
int OutputPort = PORTD; // read the current port D bit mask
const int ENApin1 = 2; // ENA output pin for Motor H-Bridge 1 (ie PortD bit position)
const int ENApin2 = 4; // ENA output pin for Motor H-Bridge 2 (ie PortD bit position)
const int ENApin3 = 6; // ENA output pin for Motor H-Bridge 3 (ie PortD bit position)
const int PWMpin1 = 9; // PWM output pin for Motor 1
const int PWMpin2 = 10; // PWM output pin for Motor 2
const int PWMpin3 = 11; // PWM output pin for Motor 3
const int FeedbackPin1 = A0; // Motor 1 feedback pin
const int FeedbackPin2 = A1; // Motor 2 feedback pin
const int FeedbackPin3 = A2; // Motor 3 feedback pin
const int PotInputPin = A5; // User adjustable POT used to scale the motion (if enabled)
int DeadZone1 = 0; // feedback deadzone
int DeadZone2 = 0; // feedback deadzone
int DeadZone3 = 0; // feedback deadzone
int CenterOffset1 = 0; // Adjust center offset of feedback position
int CenterOffset2 = 0; // Adjust center offset of feedback position
int CenterOffset3 = 0; // Adjust center offset of feedback position
int CutoffLimitMax1 = 1000; // The position beyond which the motors are disabled
int CutoffLimitMax2 = 1000; // The position beyond which the motors are disabled
int CutoffLimitMax3 = 1000; // The position beyond which the motors are disabled
int CutoffLimitMin1 = 23; // The position beyond which the motors are disabled
int CutoffLimitMin2 = 23; // The position beyond which the motors are disabled
int CutoffLimitMin3 = 23; // The position beyond which the motors are disabled
int InputClipMax1 = 923; // The input position beyond which the target input is clipped
int InputClipMax2 = 923; // The input position beyond which the target input is clipped
int InputClipMax3 = 923; // The input position beyond which the target input is clipped
int InputClipMin1 = 100; // The input position beyond which the target input is clipped
int InputClipMin2 = 100; // The input position beyond which the target input is clipped
int InputClipMin3 = 100; // The input position beyond which the target input is clipped
int LiftFactor1 = 0; // was 10 - Increase PWM when driving motor in direction it has to work harder
int LiftFactor2 = 0; // was 10 - Increase PWM when driving motor in direction it has to work harder
int PIDProcessDivider = 1; // divider for the PID process timer
int PIDProcessCounter = 0;
int SerialFeedbackCounter = 0;
int SerialFeedbackEnabled = 0;
int SerialFeedbackPort = 0;
int Ks1 = 1;
long Kp1_x100 = 100; //initial value
long Ki1_x100 = 40;
long Kd1_x100 = 40;
int Ks2 = 1;
long Kp2_x100 = 420;
long Ki2_x100 = 40;
long Kd2_x100 = 40;
int Ks3 = 1;
int Kp3_x100 = 420;
int Ki3_x100 = 40;
int Kd3_x100 = 40;
int PWMout1 = 0;
int PWMout2 = 0;
int PWMout3 = 0;
int Disable1 = 1; //Motor stop flag
int Disable2 = 1; //Motor stop flag
int Disable3 = 1; //Motor stop flag
int PWMoffset1 = 50;
int PWMoffset2 = 50;
int PWMoffset3 = 50;
int PWMmax1 = 100;
int PWMmax2 = 100;
int PWMmax3 = 100;
int PWMrev1 = 200;
int PWMrev2 = 200;
int PWMrev3 = 200;
unsigned int Timer1FreqkHz = 25; // PWM freq used for Motor 1 and 2
unsigned int Timer2FreqkHz = 31; // PWM freq used for Motor 3
int brakebutton = 5;
int brakerelay = 3;
int brakeLED = 7;
int buttonstate = false;
#ifdef SECOND_SERIAL
SoftwareSerial mySerial(12, 13); // RX, TX
#endif
// Setup the PWM pin frequencies
void setPwmFrequency(int pin, int divisor)
byte mode;
if (pin == 5 || pin == 6 || pin == 9 || pin == 10)
switch (divisor)
case 1: mode = 0x01; break;
case 8: mode = 0x02; break;
case 64: mode = 0x03; break;
case 256: mode = 0x04; break;
case 1024: mode = 0x05; break;
default: return;
if (pin == 5 || pin == 6)
TCCR0B = TCCR0B & 0b11111000 | mode;
TCCR1B = TCCR1B & 0b11111000 | mode;
if (pin == 3 || pin == 11)
switch (divisor)
case 32: mode = 0x03; break;
case 64: mode = 0x04; break;
case 128: mode = 0x05; break;
case 256: mode = 0x06; break;
case 1024: mode = 0x7; break;
default: return;
TCCR2B = TCCR2B & 0b11111000 | mode;
void InitialisePWMTimer1(unsigned int Freq) // Used for pins 9 and 10
uint8_t wgm = 8; //setting the waveform generation mode to 8 - PWM Phase and Freq Correct
TCCR1A = (TCCR1A & B11111100) | (wgm & B00000011);
TCCR1B = (TCCR1B & B11100111) | ((wgm & B00001100) << 1);
TCCR1B = (TCCR1B & B11111000) | 0x01; // Set the prescaler to minimum (ie divide by 1)
unsigned int CountTOP;
CountTOP = (F_CPU / 2) / Freq; // F_CPU is the oscillator frequency - Freq is the wanted PWM freq
// Examples of CountTOP:
// 400 = 20000Hz -> 8MHz / Freq = CountTOP
// 320 = 25000Hz
// 266 = 30075Hz
ICR1 = CountTOP; // Set the TOP of the count for the PWM
void InitialisePWMTimer2(unsigned int Freq)
int Timer2DivideMode;
if (Freq >= 15000)
Timer2DivideMode = 0x01; // Anything above 15000 set divide by 1 which gives 31250Hz PWM freq
Timer2DivideMode = 0x02; // Anything below 15000 set divide by 8 (mode 2) which gives 3906Hz PWM freq
TCCR2B = TCCR2B & 0b11111000 | Timer2DivideMode;
void MyPWMWrite(uint8_t pin, uint8_t val)
#define OCR1A_MEM 0x88
#define OCR1B_MEM 0x8A
pinMode(pin, OUTPUT);
//casting "val" to be larger so that the final value (which is the partially
//the result of multiplying two potentially high value int16s) will not truncate
uint32_t tmp = val;
if (val == 0)
digitalWrite(pin, LOW);
else if (val == 255)
digitalWrite(pin, HIGH);
uint16_t regLoc16 = 0;
uint16_t top;
switch (pin)
case 9:
sbi(TCCR1A, COM1A1);
regLoc16 = OCR1A_MEM;
top = ICR1; //Timer1_GetTop();
case 10:
sbi(TCCR1A, COM1B1);
regLoc16 = OCR1B_MEM;
tmp = (tmp * top) / 255;
_SFR_MEM16(regLoc16) = tmp; //(tmp*top)/255;
void DisableMotor1();
void DisableMotor2();
void DisableMotor3();
// Arduino setup subroutine called at startup/reset
//Read all stored Parameters from EEPROM
ReadEEProm();
Serial.begin(500000); //115200
// set the data rate for the SoftwareSerial port
mySerial.begin(115200);
#endif
OutputPort = PORTD;
pinMode(ENApin1, OUTPUT);
pinMode(ENApin2, OUTPUT);
pinMode(ENApin3, OUTPUT);
pinMode(PWMpin1, OUTPUT);
pinMode(PWMpin2, OUTPUT);
pinMode(PWMpin3, OUTPUT);
MyPWMWrite(PWMpin1, 0); //analogWrite(PWMpin1, 0);
MyPWMWrite(PWMpin2, 0); //analogWrite(PWMpin2, 0);
analogWrite(PWMpin3, 0);
DisableMotor1();
DisableMotor2();
DisableMotor3();
// Note that the base frequency for pins 3, 9, 10, and 11 is 31250 Hz
//setPwmFrequency(PWMpin1, 1); // Divider can be 1, 8, 64, 256
//setPwmFrequency(PWMpin2, 1); // Divider can be 1, 8, 64, 256
//setPwmFrequency(PWMpin3, 1); // Divider can be 1, 8, 64, 256
InitialisePWMTimer1(Timer1FreqkHz * 1000); // PWM Freq for Motor 1 and 2 can be set quite precisely - pass the desired freq and nearest selected
InitialisePWMTimer2(Timer2FreqkHz * 1000); // Motor 3 PWM Divider can only be 1, 8, 64, 256 giving Freqs 31250,3906, 488 and 122 Hz
//CLKPR = 0x80; // These two lines halve the processor clock
//CLKPR = 0x01;
// set analogue prescale to 16
sbi(ADCSRA, ADPS2);
cbi(ADCSRA, ADPS1);
cbi(ADCSRA, ADPS0);
pinMode(brakerelay, OUTPUT);
pinMode(brakebutton, INPUT_PULLUP);
pinMode(brakeLED, OUTPUT);
void WriteEEPRomWord(int address, int intvalue)
int low, high;
high = intvalue / 256;
low = intvalue - (256 * high);
EEPROM.write(address, high);
EEPROM.write(address + 1, low);
int ReadEEPRomWord(int address)
int low, high, returnvalue;
high = EEPROM.read(address);
low = EEPROM.read(address + 1);
returnvalue = (high * 256) + low;
return returnvalue;
// Write all configurable parameters to EEPROM
void WriteEEProm()
EEPROM.write(0, 114);
EEPROM.write(1, CutoffLimitMin1);
EEPROM.write(2, InputClipMin1);
EEPROM.write(5, DeadZone1);
EEPROM.write(6, CutoffLimitMin2);
EEPROM.write(7, InputClipMin2);
EEPROM.write(10, DeadZone2);
WriteEEPRomWord(11, Kp1_x100); // **** Even though these variables are long the actual values stored are only 0 to 1000 so OK ****
WriteEEPRomWord(13, Ki1_x100);
WriteEEPRomWord(15, Kd1_x100);
WriteEEPRomWord(17, Kp2_x100);
WriteEEPRomWord(19, Ki2_x100);
WriteEEPRomWord(21, Kd2_x100);
EEPROM.write(23, PWMoffset1);
EEPROM.write(24, PWMoffset2);
EEPROM.write(25, PWMmax1);
EEPROM.write(26, PWMmax2);
EEPROM.write(27, PWMrev1);
EEPROM.write(28, PWMrev2);
EEPROM.write(29, PWMrev3);
EEPROM.write(31, CutoffLimitMin3);
EEPROM.write(32, InputClipMin3);
EEPROM.write(35, DeadZone3);
WriteEEPRomWord(36, Kp3_x100);
WriteEEPRomWord(38, Ki3_x100);
WriteEEPRomWord(40, Kd3_x100);
EEPROM.write(42, PWMoffset3);
EEPROM.write(43, PWMmax3);
WriteEEPRomWord(44, Ks1);
WriteEEPRomWord(46, Ks2);
WriteEEPRomWord(48, Ks3);
EEPROM.write(50, constrain(PIDProcessDivider, 1, 10));
EEPROM.write(51, Timer1FreqkHz);
EEPROM.write(52, Timer2FreqkHz);
// Read all configurable parameters from the EEPROM.
void ReadEEProm()
int evalue = EEPROM.read(0);
if (evalue != 114) //EEProm was not set before, set default values
WriteEEProm();
return;
CutoffLimitMin1 = EEPROM.read(1);
InputClipMin1 = EEPROM.read(2);
CutoffLimitMax1 = 1023 - CutoffLimitMin1;
InputClipMax1 = 1023 - InputClipMin1;
DeadZone1 = EEPROM.read(5);
CutoffLimitMin2 = EEPROM.read(6);
InputClipMin2 = EEPROM.read(7);
CutoffLimitMax2 = 1023 - CutoffLimitMin2;
InputClipMax2 = 1023 - InputClipMin2;
DeadZone2 = EEPROM.read(10);
Kp1_x100 = ReadEEPRomWord(11);
Ki1_x100 = ReadEEPRomWord(13);
Kd1_x100 = ReadEEPRomWord(15);
Kp2_x100 = ReadEEPRomWord(17);
Ki2_x100 = ReadEEPRomWord(19);
Kd2_x100 = ReadEEPRomWord(21);
PWMoffset1 = EEPROM.read(23);
PWMoffset2 = EEPROM.read(24);
PWMmax1 = EEPROM.read(25);
PWMmax2 = EEPROM.read(26);
PWMrev1 = EEPROM.read(27);
PWMrev2 = EEPROM.read(28);
PWMrev3 = EEPROM.read(29);
CutoffLimitMin3 = EEPROM.read(31);
InputClipMin3 = EEPROM.read(32);
CutoffLimitMax3 = 1023 - CutoffLimitMin3;
InputClipMax3 = 1023 - InputClipMin3;
DeadZone3 = EEPROM.read(35);
Kp3_x100 = ReadEEPRomWord(36);
Ki3_x100 = ReadEEPRomWord(38);
Kd3_x100 = ReadEEPRomWord(40);
PWMoffset3 = EEPROM.read(42);
PWMmax3 = EEPROM.read(43);
Ks1 = ReadEEPRomWord(44);
Ks2 = ReadEEPRomWord(46);
Ks3 = ReadEEPRomWord(48);
PIDProcessDivider = EEPROM.read(50);
PIDProcessDivider = constrain(PIDProcessDivider, 1, 10);
Timer1FreqkHz = EEPROM.read(51);
Timer2FreqkHz = EEPROM.read(52);
// Send two bytes via serial in response to a request for information
void SendTwoValues(int id, int v1, int v2, int ComPort)
if (ComPort == 0)
Serial.write(START_BYTE);
Serial.write(id);
Serial.write(v1);
Serial.write(v2);
Serial.write(END_BYTE);
mySerial.write(START_BYTE);
mySerial.write(id);
mySerial.write(v1);
mySerial.write(v2);
mySerial.write(END_BYTE);
#endif
// Send a single word value via serial in response to a request for information
void SendValue(int id, int value, int ComPort)
int low, high;
high = value / 256;
low = value - (high * 256);
if (ComPort == 0)
Serial.write(id);
Serial.write(high);
Serial.write(low);
mySerial.write(id);
mySerial.write(high);
mySerial.write(low);
#endif
// Calculate how many PID calculations have been performed since last requested
int DeltaLoopCount()
unsigned long Delta;
if ( (LastCount == 0) || ((LoopCount - LastCount) > 32000) )
Delta = 0;
LastCount = LoopCount;
Delta = LoopCount - LastCount;
return (int)Delta;
// Process the incoming serial commands from the specified comm port
void ParseCommand(int ComPort)
CommsTimeout = 0; // reset the comms timeout counter to indicate we are getting packets
switch (RxBuffer[0][ComPort])
case 'A':
Target1 = (RxBuffer[1][ComPort] * 256) + RxBuffer[2][ComPort];
#ifdef REVERSE_MOTOR1
Target1 = 1023 - Target1;
#endif
#ifdef ENABLE_POT_SCALING
if (PotInput < 25)
Target1 = 512; // Center Motor1
else if (PotInput < 1000)
Target1 = int(float(Target1 - 512) * (0.0 + float(PotInput) * 0.001)) + 512;
#endif
#ifdef ENABLE_NON_LINEAR_POT_SCALING
if (PotInput < 25)
else if (PotInput < 512)
Target1 = (Target1 - 512) << 1;
if (Target1 < 0)
Target1 = int((-Target1 - float((double(Target1) * double(Target1))) * 0.000488) * float(PotInput * 0.001953));
Target1 = (-Target1 >> 1) + 512;
Target1 = int((Target1 - float((double(Target1) * double(Target1))) * 0.000488) * float(PotInput * 0.001953));
Target1 = (Target1 >> 1) + 512;
if (Target1 < 0)
Target1 = int(-Target1 - float((double(Target1) * double(Target1) * double(1024 - PotInput))) * 0.000000953674);
Target1 = int(Target1 - float((double(Target1) * double(Target1) * double(1024 - PotInput))) * 0.000000953674);
#endif
if (Target1 > InputClipMax1) {
Target1 = InputClipMax1;
else if (Target1 < InputClipMin1) {
Target1 = InputClipMin1;
case 'B':
Target2 = (RxBuffer[1][ComPort] * 256) + RxBuffer[2][ComPort];
if (PotInput < 25)
Target2 = 512; // Center Motor1
Target2 = int(float(Target2 - 512) * (0.0 + float(PotInput) * 0.001)) + 512;
#endif
if (PotInput < 25)
Target2 = (Target2 - 512) << 1;
if (Target2 < 0)
Target2 = int((-Target2 - float((double(Target2) * double(Target2))) * 0.000488) * float(PotInput * 0.001953));
Target2 = (-Target2 >> 1) + 512;
Target2 = int((Target2 - float((double(Target2) * double(Target2))) * 0.000488) * float(PotInput * 0.001953));
Target2 = (Target2 >> 1) + 512;
if (Target2 < 0)
Target2 = int(-Target2 - float((double(Target2) * double(Target2) * double(1024 - PotInput))) * 0.000000953674);
Target2 = int(Target2 - float((double(Target2) * double(Target2) * double(1024 - PotInput))) * 0.000000953674);
#endif
if (Target2 > InputClipMax2) {
Target2 = InputClipMax2;
else if (Target2 < InputClipMin2) {
Target2 = InputClipMin2;
case 'C':
Target3 = (RxBuffer[1][ComPort] * 256) + RxBuffer[2][ComPort];
if (Target3 > InputClipMax3) {
Target3 = InputClipMax3;
else if (Target3 < InputClipMin3) {
Target3 = InputClipMin3;
case 'r':
if (RxBuffer[1][ComPort] == 'd') // rd - Read a value from the ArduinoPID - next byte identifies value to read
switch (RxBuffer[2][ComPort])
case 'A':
SendTwoValues('A', (1023 - Feedback1) / 4, (1023 - Target1) / 4, ComPort);
#else
SendTwoValues('A', Feedback1 / 4, Target1 / 4, ComPort);
#endif
case 'B':
SendTwoValues('B', Feedback2 / 4, Target2 / 4, ComPort);
case 'C':
SendTwoValues('C', Feedback3 / 4, Target3 / 4, ComPort);
case 'a':
SendTwoValues('a', PIDProcessDivider * 16 + Disable1 + (Disable2 * 2) + (Disable3 * 4), constrain(PWMout1, 0, 255), ComPort);
case 'b':
SendTwoValues('b', PIDProcessDivider * 16 + Disable1 + (Disable2 * 2) + (Disable3 * 4), constrain(PWMout2, 0, 255), ComPort);
case 'c':
SendTwoValues('c', PIDProcessDivider * 16 + Disable1 + (Disable2 * 2) + (Disable3 * 4), constrain(PWMout3, 0, 255), ComPort);
case 'D':
SendValue('D', Kp1_x100, ComPort);
case 'E':
SendValue('E', Kp2_x100, ComPort);
case 'F':
SendValue('F', Kp3_x100, ComPort);
case 'G':
SendValue('G', Ki1_x100, ComPort);
case 'H':
SendValue('H', Ki2_x100, ComPort);
case 'I':
SendValue('I', Ki3_x100, ComPort);
case 'J':
SendValue('J', Kd1_x100, ComPort);
case 'K':
SendValue('K', Kd2_x100, ComPort);
case 'L':
SendValue('L', Kd3_x100, ComPort);
case 'M':
SendValue('M', Ks1, ComPort);
case 'N':
SendValue('N', Ks2, ComPort);
case 'O':
SendValue('O', Ks3, ComPort);
case 'P':
SendTwoValues('P', PWMoffset1, PWMmax1, ComPort);
case 'Q':
SendTwoValues('Q', PWMoffset2, PWMmax2, ComPort);
case 'R':
SendTwoValues('R', PWMoffset3, PWMmax3, ComPort);
case 'S':
SendTwoValues('S', CutoffLimitMin1, InputClipMin1, ComPort);
case 'T':
SendTwoValues('T', CutoffLimitMin2, InputClipMin2, ComPort);
case 'U':
SendTwoValues('U', CutoffLimitMin3, InputClipMin3, ComPort);
case 'V':
SendTwoValues('V', DeadZone1, PWMrev1, ComPort);
case 'W':
SendTwoValues('W', DeadZone2, PWMrev2, ComPort);
case 'X':
SendTwoValues('X', DeadZone3, PWMrev3, ComPort);
case 'Y':
SendTwoValues('Y', PIDProcessDivider * 16 + Disable1 + (Disable2 * 2) + (Disable3 * 4), 0, ComPort); // Second byte not yet used
case 'Z':
SendValue('Z', DeltaLoopCount(), ComPort);
// SendValue('Z',errorcount,ComPort); // *** TEMP CODE FOR ETESTING
case '~':
SendTwoValues('~', Timer1FreqkHz, Timer2FreqkHz, ComPort); // PWM Frequencies to set
case '?':
// default:
case 'D':
Kp1_x100 = (RxBuffer[1][ComPort] * 256) + RxBuffer[2][ComPort];
case 'E':
Kp2_x100 = (RxBuffer[1][ComPort] * 256) + RxBuffer[2][ComPort];
case 'F':
Kp3_x100 = (RxBuffer[1][ComPort] * 256) + RxBuffer[2][ComPort];
case 'G':
Ki1_x100 = (RxBuffer[1][ComPort] * 256) + RxBuffer[2][ComPort];
case 'H':
Ki2_x100 = (RxBuffer[1][ComPort] * 256) + RxBuffer[2][ComPort];
case 'I':
Ki3_x100 = (RxBuffer[1][ComPort] * 256) + RxBuffer[2][ComPort];
case 'J':
Kd1_x100 = (RxBuffer[1][ComPort] * 256) + RxBuffer[2][ComPort];
case 'K':
Kd2_x100 = (RxBuffer[1][ComPort] * 256) + RxBuffer[2][ComPort];
case 'L':
Kd3_x100 = (RxBuffer[1][ComPort] * 256) + RxBuffer[2][ComPort];
case 'M':
Ks1 = (RxBuffer[1][ComPort] * 256) + RxBuffer[2][ComPort];
case 'N':
Ks2 = (RxBuffer[1][ComPort] * 256) + RxBuffer[2][ComPort];
case 'O':
Ks3 = (RxBuffer[1][ComPort] * 256) + RxBuffer[2][ComPort];
case 'P':
PWMoffset1 = RxBuffer[1][ComPort];
PWMmax1 = RxBuffer[2][ComPort];
case 'Q':
PWMoffset2 = RxBuffer[1][ComPort];
PWMmax2 = RxBuffer[2][ComPort];
case 'R':
PWMoffset3 = RxBuffer[1][ComPort];
PWMmax3 = RxBuffer[2][ComPort];
case 'S':
CutoffLimitMin1 = RxBuffer[1][ComPort];
InputClipMin1 = RxBuffer[2][ComPort];
case 'T':
CutoffLimitMin2 = RxBuffer[1][ComPort];
InputClipMin2 = RxBuffer[2][ComPort];
case 'U':
CutoffLimitMin3 = RxBuffer[1][ComPort];
InputClipMin3 = RxBuffer[2][ComPort];
case 'V':
DeadZone1 = RxBuffer[1][ComPort];
PWMrev1 = RxBuffer[2][ComPort];
case 'W':
DeadZone2 = RxBuffer[1][ComPort];
PWMrev2 = RxBuffer[2][ComPort];
case 'X':
DeadZone3 = RxBuffer[1][ComPort];
PWMrev3 = RxBuffer[2][ComPort];
case 'Z':
PIDProcessDivider = constrain(RxBuffer[1][ComPort], 1, 10);
// ???=RxBuffer[2][ComPort]; // second byte not yet used
case '~':
Timer1FreqkHz = RxBuffer[1][ComPort];
Timer2FreqkHz = RxBuffer[2][ComPort];
case 'm':
if (RxBuffer[1][ComPort] == 'o' && RxBuffer[2][ComPort] == '1') // Monitor motor 1 (auto sends position and feedback data to host
SerialFeedbackEnabled = (ComPort << 4) | 1; // Motor 1
if (RxBuffer[1][ComPort] == 'o' && RxBuffer[2][ComPort] == '2') // Monitor motor 2 (auto sends position and feedback data to host
SerialFeedbackEnabled = (ComPort << 4) | 2; // Motor 2
if (RxBuffer[1][ComPort] == 'o' && RxBuffer[2][ComPort] == '3') // Monitor motor 3 (auto sends position and feedback data to host
SerialFeedbackEnabled = (ComPort << 4) | 3; // Motor 3
if (RxBuffer[1][ComPort] == 'o' && RxBuffer[2][ComPort] == '0') // Switch off auto monitoring data feedback
case 's':
if (RxBuffer[1][ComPort] == 'a' && RxBuffer[2][ComPort] == 'v') // Save all settings to EEPROM
WriteEEProm();
case 'v':
if (RxBuffer[1][ComPort] == 'e' && RxBuffer[2][ComPort] == 'r') // Send back the SMC3 software version
SendValue('v', 100, ComPort); // Software Version - divide by 100 to get version - ie 101= ver1.01
case 'e':
if (RxBuffer[1][ComPort] == 'n' && RxBuffer[2][ComPort] == 'a') // Enable all motors
Disable1 = 0;
Disable2 = 0;
Disable3 = 0;
#ifdef MODE2 // 43A "Chinese" H-Bridge
// Reset any overtemp shutdowns and enable the H-Bridges - toggle pins low then leave high
PORTD = OutputPort;
PORTD = OutputPort;
#endif
else if (RxBuffer[1][ComPort] == 'n' && RxBuffer[2][ComPort] == '1') // Enable motor 1
Disable1 = 0;
PORTD = OutputPort;
PORTD = OutputPort;
#endif
else if (RxBuffer[1][ComPort] == 'n' && RxBuffer[2][ComPort] == '2') // Enable motor 2
Disable2 = 0;
PORTD = OutputPort;
PORTD = OutputPort;
#endif
else if (RxBuffer[1][ComPort] == 'n' && RxBuffer[2][ComPort] == '3') // Enable motor 3
Disable3 = 0;
PORTD = OutputPort;
#endif
case '?':
// default:
// Check the incoming serial data to see if a command has been received
void CheckSerial0()
while (Serial.available())
if (BufferEnd[COM0] == -1)
RxByte[COM0] = Serial.read();
if (RxByte[COM0] != START_BYTE) {
BufferEnd[COM0] = -1;
errorcount++;
BufferEnd[COM0] = 0;
RxBuffer[BufferEnd[COM0]][COM0] = RxByte[COM0];
BufferEnd[COM0]++;
if (BufferEnd[COM0] > 3)
if (RxBuffer[3][COM0] == END_BYTE)
ParseCommand(COM0);
errorcount++;
void CheckSerial1()
while (mySerial.available())
if (BufferEnd[COM1] == -1)
RxByte[COM1] = mySerial.read();
if (RxByte[COM1] != START_BYTE) {
BufferEnd[COM1] = -1;
BufferEnd[COM1] = 0;
RxBuffer[BufferEnd[COM1]][COM1] = RxByte[COM1];
BufferEnd[COM1]++;
if (BufferEnd[COM1] > 3)
if (RxBuffer[3][COM1] == END_BYTE)
ParseCommand(COM1);
errorcount++;
#endif
#ifdef MODE1 // This mode outputs a PWM and two motor Direction pins
// Set the Motor output pins to drive the motor in required direction and speed
void SetOutputsMotor1()
if ((Feedback1 > InputClipMax1) && (PWMrev1 != 0))
PWMout1 = PWMrev1;
OutputPort &= ~(1 << ENApin1); // Unset Motor1 In 1
OutputPort |= 1 << ENBpin1; // Set Motor1 In 2
MyPWMWrite(PWMpin1, PWMrev1);
else if ((Feedback1 < InputClipMin1) && (PWMrev1 != 0))
PWMout1 = PWMrev1;
OutputPort |= 1 << ENApin1; // Set Motor1 In 1
OutputPort &= ~(1 << ENBpin1); // Unset Motor1 In 2
else if ((Target1 > (Feedback1 + DeadZone1)) || (Target1 < (Feedback1 - DeadZone1)))
if (PWMout1 >= 0)
// Drive Motor Forward
PWMout1 += PWMoffset1;
if (PWMout1 > (PWMmax1 + LiftFactor1)) {
PWMout1 = PWMmax1 + LiftFactor1;
// Drive Motor Backwards
PWMout1 = abs(PWMout1);
if (PWMout1 > PWMmax1) {
PWMout1 = PWMmax1;
MyPWMWrite(PWMpin1, PWMout1);
// Brake Motor
PWMout1 = PWMoffset1;
PORTD = OutputPort;
void SetOutputsMotor2()
if ((Feedback2 > InputClipMax2) && (PWMrev2 != 0))
PWMout2 = PWMrev2;
OutputPort &= ~(1 << ENApin2); // Unset Motor1 In 1
OutputPort |= 1 << ENBpin2; // Set Motor1 In 2
MyPWMWrite(PWMpin2, PWMrev2);
else if ((Feedback2 < InputClipMin2) && (PWMrev2 != 0))
PWMout2 = PWMrev2;
OutputPort |= 1 << ENApin2; // Set Motor1 In 1
OutputPort &= ~(1 << ENBpin2); // Unset Motor1 In 2
else if (Target2 > (Feedback2 + DeadZone2) || Target2 < (Feedback2 - DeadZone2))
if (PWMout2 >= 0)
PWMout2 += PWMoffset2;
if (PWMout2 > PWMmax2 + LiftFactor2) {
PWMout2 = PWMmax2 + LiftFactor2;
OutputPort |= 1 << ENApin2; // Set Motor2 In 1
OutputPort &= ~(1 << ENBpin2); // Unset Motor2 In 2
PWMout2 = abs(PWMout2);
if (PWMout2 > PWMmax2) {
PWMout2 = PWMmax2;
OutputPort &= ~(1 << ENApin2); // Unset Motor2 In 1
OutputPort |= 1 << ENBpin2; // Set Motor2 In 2
MyPWMWrite(PWMpin2, PWMout2);
// Brake Motor
PWMout2 = PWMoffset2;
PORTD = OutputPort;
void SetOutputsMotor3()
if ((Feedback3 > InputClipMax3) && (PWMrev3 != 0))
PWMout3 = PWMrev3;
OutputPort &= ~(1 << ENApin3); // Unset Motor1 In 1
OutputPort |= 1 << ENBpin3; // Set Motor1 In 2
analogWrite(PWMpin3, PWMrev3);
else if ((Feedback3 < InputClipMin3) && (PWMrev3 != 0))
PWMout3 = PWMrev3;
OutputPort |= 1 << ENApin3; // Set Motor1 In 1
OutputPort &= ~(1 << ENBpin3); // Unset Motor1 In 2
else if (Target3 > (Feedback3 + DeadZone3) || Target3 < (Feedback3 - DeadZone3))
if (PWMout3 >= 0)
PWMout3 += PWMoffset3;
if (PWMout3 > PWMmax3) {
PWMout3 = PWMmax3;
OutputPort |= 1 << ENApin3; // Set Motor3 In 1
OutputPort &= ~(1 << ENBpin3); // Unset Motor3 In 2
PWMout3 = abs(PWMout3);
PWMout3 = PWMmax3;
OutputPort &= ~(1 << ENApin3); // Unset Motor3 In 1
OutputPort |= 1 << ENBpin3; // Set Motor3 In 2
analogWrite(PWMpin3, PWMout3);
// Brake Motor
PWMout3 = PWMoffset3;
PORTD = OutputPort;
#endif
#ifdef MODE2 // This mode outputs a H-Bridge Enable, One Dir Pin and a +/-PWM
void SetOutputsMotor1() // MODE2
PWMout1 = PWMrev1;
MyPWMWrite(PWMpin1, 255 - PWMrev1);
//WAS ==> MyPWMWrite(PWMpin1, PWMrev1); ------------- MOD By Blame73 for Cytron MD30C
PWMout1 = PWMrev1;
if (PWMout1 >= 0)
MyPWMWrite(PWMpin1, PWMout1); // Motor driven when PWM=0 (unset)
//WAS ==> MyPWMWrite(PWMpin1, 255-PWMout1); // Motor driven when PWM=0 (unset) ------------- MOD By Blame73 for Cytron MD30C
PWMout1 = PWMmax1;
MyPWMWrite(PWMpin1, PWMout1); // Motor driven when PWM=1 (set)
// Brake Motor
PORTD = OutputPort;
void SetOutputsMotor2() // MODE2
PWMout2 = PWMrev2;
MyPWMWrite(PWMpin2, 255 - PWMrev2);
//WAS ==> MyPWMWrite(PWMpin2, PWMrev2); ------------- MOD By Blame73 for Cytron MD30C
PWMout2 = PWMrev2;
else if ((Target2 > (Feedback2 + DeadZone2)) || (Target2 < (Feedback2 - DeadZone2)))
if (PWMout2 >= 0)
//WAS ==> MyPWMWrite(PWMpin2, 255-PWMout2); // Motor driven when PWM=0 (unset) ------------- MOD By Blame73 for Cytron MD30C
PWMout2 = PWMmax2;
// Brake Motor
PORTD = OutputPort;
void SetOutputsMotor3() // MODE2
PWMout3 = PWMrev3;
analogWrite(PWMpin3, 255 - PWMrev3);
//WAS ==> analogWrite(PWMpin3, PWMout3); ------------- MOD By Blame73 for Cytron MD30C
PWMout3 = PWMrev3;
else if ((Target3 > (Feedback3 + DeadZone3)) || (Target3 < (Feedback3 - DeadZone3)))
if (PWMout3 >= 0)
PWMout3 = PWMmax3;
//WAS ==> analogWrite(PWMpin3, 255-PWMout3); ------------- MOD By Blame73 for Cytron MD30C
PWMout3 = PWMmax3;
// Brake Motor
PORTD = OutputPort;
#endif
// Calculate the motor PID output
// Based on http://brettbeauregard.com/blog/2011/04/improving-the-beginners-pid-introduction/
// Re-written to eliminate the use of float calculations to significantly increase calculation speed.
int CalcMotor1PID(int TargetPosition, int CurrentPosition)
static int Error = 0;
static long pTerm_x100 = 0;
static long dTerm_x100 = 0;
static long iTerm_x100 = 0;
static int CumError = 0;
static int LastPosition = 0;
static int DeltaPosition = 0;
static int KdFilterCount = 0;
Error = TargetPosition - CurrentPosition;
if (abs(Error) <= DeadZone1)
CumError = 0;
CumError += Error;
CumError = constrain(CumError, -1024, 1024);
pTerm_x100 = Kp1_x100 * (long)Error; // Error can only be between +/-1023 and Kp1_100 is constrained to 0-1000 so can work with type long
iTerm_x100 = (Ki1_x100 * (long)CumError); // was >>6
KdFilterCount++;
if (KdFilterCount >= Ks1) // Apply a level of filtering to Kd parameter to help reduce motor noise
DeltaPosition = (CurrentPosition - LastPosition);
LastPosition = CurrentPosition;
dTerm_x100 = (Kd1_x100 * (long)DeltaPosition); // was <<5
KdFilterCount = 0;
return constrain((pTerm_x100 + iTerm_x100 - dTerm_x100) >> PowerScale , -255, 255); // the /128 (PowerScale) is an approximation to bring x100 terms back to units. Accurate/consistent enough for this function.
int CalcMotor2PID(int TargetPosition, int CurrentPosition)
if (abs(Error) <= DeadZone2)
CumError = 0;
CumError += Error;
CumError = constrain(CumError, -1024, 1024); // Maybe Try 512 as the limits??????
pTerm_x100 = Kp2_x100 * (long)Error; // Error can only be between +/-1023 and Kp1_100 is constrained to 0-1000 so can work with type long
iTerm_x100 = (Ki2_x100 * (long)CumError);
KdFilterCount++;
if (KdFilterCount >= Ks2) // Apply a level of filtering to Kd parameter to help reduce motor noise
dTerm_x100 = (Kd2_x100 * (long)DeltaPosition);
KdFilterCount = 0;
return constrain((pTerm_x100 + iTerm_x100 - dTerm_x100) >> PowerScale , -255, 255); // the /128 is an approximation to bring x100 terms back to units. Accurate/consistent enough for this function.
int CalcMotor3PID(int TargetPosition, int CurrentPosition)
if (abs(Error) <= DeadZone3)
CumError = 0;
CumError += Error;
pTerm_x100 = Kp3_x100 * (long)Error; // Error can only be between +/-1023 and Kp1_100 is constrained to 0-1000 so can work with type long
iTerm_x100 = (Ki3_x100 * (long)CumError) >> 6;
KdFilterCount++;
if (KdFilterCount >= Ks3) // Apply a level of filtering to Kd parameter to help reduce motor noise
dTerm_x100 = (Kd3_x100 * (long)DeltaPosition) << 5;
KdFilterCount = 0;
// Disable the Motors - ie put the brakes on
// Used when motor feedback is outside allowed range to minimise damage
Disable1 = 1;
PORTD = OutputPort;
Disable2 = 1;
PORTD = OutputPort;
Disable3 = 1;
PORTD = OutputPort;
void TogglePin()
static int PinOut = 0;
PinOut = 1 - PinOut;
digitalWrite(8, PinOut);
// Main Arduino Program Loop
//Serial.println(buttonstate);
if (digitalRead(brakebutton) == true) {
buttonstate = !buttonstate;
dbgc("ToL", buttonstate);
digitalWrite(brakerelay, buttonstate);
digitalWrite(brakeLED, buttonstate);
while (digitalRead(brakebutton) == true);
delay(50);
dbgc("01", digitalRead(brakebutton));
Disable1 = 0;
Disable2 = 0;
Disable3 = 0;
PORTD = OutputPort;
PORTD = OutputPort;
#endif
// Some temporary debug stuff
// Serial.write('S');
// Serial.write(TCCR1A);
// Serial.write(TCCR1B);
// Serial.write(OCR1AL);
// Serial.write(OCR1AH);
// Initialise the PID ready timer
TimesUp = micros();
// Main Program loop
dbgc("03", buttonstate);
while (buttonstate == 1)
dbgc("04", buttonstate);
delay(50);
dbgc("05", buttonstate);
// Wait until its time and then update PID calcs for first motor
while ((micros() - TimesUp) < PROCESS_PERIOD_uS) {
TimesUp += PROCESS_PERIOD_uS;
TogglePin(); // Used for testing to monitor PID timing on Oscilloscope
PIDProcessCounter++;
if (PIDProcessCounter >= PIDProcessDivider)
// Check and Update Motor 1 drive
Feedback1 = analogRead(FeedbackPin1);
//Feedback1 -= 512; // added for a narrower range (pot on the shaft) by Blame73
//Feedback1 *= 2;
//Feedback1 += 512;
if ((Feedback1 > CutoffLimitMax1) || (Feedback1 < CutoffLimitMin1)) {
DisableMotor1();
PWMout1 = CalcMotor1PID(Target1, Feedback1);
if (Disable1 == 0)
SetOutputsMotor1();
PWMout1 = 0;
// Check and Update Motor 2 drive
Feedback2 = analogRead(FeedbackPin2);
//Feedback2 -= 512; // added for a narrower range (pot on the shaft) by Blame73
//Feedback2 *= 2;
//Feedback2 += 512;
if ((Feedback2 > CutoffLimitMax2) || (Feedback2 < CutoffLimitMin2)) {
DisableMotor2();
PWMout2 = CalcMotor2PID(Target2, Feedback2);
if (Disable2 == 0)
SetOutputsMotor2();
PWMout2 = 0;
// Check and Update Motor 3 drive
Feedback3 = analogRead(FeedbackPin3);
//Feedback3 -= 512; // added for a narrower range (pot on the shaft) by Blame73
//Feedback3 *= 2;
//Feedback3 += 512;
if ((Feedback3 > CutoffLimitMax3) || (Feedback3 < CutoffLimitMin3)) {
DisableMotor3();
PWMout3 = CalcMotor3PID(Target3, Feedback3);
if (Disable3 == 0)
SetOutputsMotor3();
PWMout3 = 0;
LoopCount++;
// Check if there is any received serial data and process (Hardware UART)
CheckSerial0();
// Check if there is any received serial data and process (Software Serial)
CheckSerial1();
SerialFeedbackCounter++;
if (SerialFeedbackCounter >= 80) // every 20ms send back position, pwm and motor status updates if enabled
SerialFeedbackPort = (SerialFeedbackEnabled >> 4) & 0x01;
if ((SerialFeedbackEnabled & 0x03) == 1) // Monitor Motor 1
SendTwoValues('A', (1023 - Feedback1) / 4, (1023 - Target1) / 4, SerialFeedbackPort);
#else
SendTwoValues('A', Feedback1 / 4, Target1 / 4, SerialFeedbackPort);
#endif
SendTwoValues('a', PIDProcessDivider * 16 + Disable1 + (Disable2 * 2) + (Disable3 * 4), constrain(PWMout1, 0, 255), SerialFeedbackPort);
else if ((SerialFeedbackEnabled & 0x03) == 2) // Monitor Motor 2
SendTwoValues('B', Feedback2 / 4, Target2 / 4, SerialFeedbackPort);
SendTwoValues('b', PIDProcessDivider * 16 + Disable1 + (Disable2 * 2) + (Disable3 * 4), constrain(PWMout2, 0, 255), SerialFeedbackPort);
else if ((SerialFeedbackEnabled & 0x03) == 3) // Monitor Motor 3
SendTwoValues('C', Feedback3 / 4, Target3 / 4, SerialFeedbackPort);
SendTwoValues('c', PIDProcessDivider * 16 + Disable1 + (Disable2 * 2) + (Disable3 * 4), constrain(PWMout3, 0, 255), SerialFeedbackPort);
PotInput = PotInput * 0.9;
PotInput = PotInput + (0.1 * analogRead(PotInputPin)); // Also read the User Pot Input every 20ms
#endif
#endif
CommsTimeout++;
if (CommsTimeout >= 60000) // 15 second timeout ie 60000 * PROCESS_PERIOD_uS
CommsTimeout = 60000; // So the counter doesn't overflow
PowerScale = 9;
PowerScale = 7; // Number of bits to shift PID result (ie divide by 128 - approximate for /100)
best regards Stefan
