Help to modify a library!
Hi there!
I am working in a small project where I need to use a motor shield and a USB Host Shield. But they both use almost the same pins. So I have been reading the library and I realized that I can change some of these pins, but there's one pin that I really need to change (pin 11), but it's a PWM pin and it works with timers as I was reading... And I don't unserstand very good that... If you can help me with this, please reply and we can exchange ideas about how to do it.. Thaks!
Here is the main part of the code I need to change..
#elif defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
    // on arduino mega, pin 11 is now PB5 (OC1A)
    TCCR1A |= _BV(COM1A1) | _BV(WGM10); // fast PWM, turn on oc1a
    TCCR1B = (freq & 0x7) | _BV(WGM12);
    OCR1A = 0;
#elif defined(__PIC32MX__)
Here is the complete function where I need to do the change...
inline void initPWM1(uint8_t freq) {
#if defined(__AVR_ATmega8__) || \
    defined(__AVR_ATmega48__) || \
    defined(__AVR_ATmega88__) || \
    defined(__AVR_ATmega168__) || \
    defined(__AVR_ATmega328P__)
    // use PWM from timer2A on PB3 (Arduino pin #11)
    TCCR2A |= _BV(COM2A1) | _BV(WGM20) | _BV(WGM21); // fast PWM, turn on oc2a
    TCCR2B = freq & 0x7;
    OCR2A = 0;
    OCR1A = 0;
    #if defined(PIC32_USE_PIN9_FOR_M1_PWM)
        // Make sure that pin 11 is an input, since we have tied together 9 and 11
        pinMode(9, OUTPUT);
        pinMode(11, INPUT);
        if (!MC.TimerInitalized)
        {   // Set up Timer2 for 80MHz counting fro 0 to 256
            T2CON = 0x8000 | ((freq & 0x07) << 4); // ON=1, FRZ=0, SIDL=0, TGATE=0, TCKPS=<freq>, T32=0, TCS=0; // ON=1, FRZ=0, SIDL=0, TGATE=0, TCKPS=0, T32=0, TCS=0
            TMR2 = 0x0000;
            PR2 = 0x0100;
            MC.TimerInitalized = true;
         // Setup OC4 (pin 9) in PWM mode, with Timer2 as timebase
        OC4CON = 0x8006;    // OC32 = 0, OCTSEL=0, OCM=6
        OC4RS = 0x0000;
        OC4R = 0x0000;
    #elif defined(PIC32_USE_PIN10_FOR_M1_PWM)
        pinMode(10, OUTPUT);
        pinMode(11, INPUT);
            TMR2 = 0x0000;
            PR2 = 0x0100;
         // Setup OC5 (pin 10) in PWM mode, with Timer2 as timebase
        OC5CON = 0x8006;    // OC32 = 0, OCTSEL=0, OCM=6
        OC5RS = 0x0000;
        OC5R = 0x0000;
    #else
        // If we are not using PWM for pin 11, then just do digital
        digitalWrite(11, LOW);
    #endif
#else
   #error "This chip is not supported!"
#endif
    #if !defined(PIC32_USE_PIN9_FOR_M1_PWM) && !defined(PIC32_USE_PIN10_FOR_M1_PWM)
        pinMode(11, OUTPUT);
    #endif
I don't understand how a hardware clash can be cured by a software change?
Also what on earth does "they both use almost the same pins" mean?
Which shields?
Which libraries?
If I change the library I won't put the motor shield over the Arduino anymore, I'll connect it with wires only.
As I told before, I am using a motor Shield Driver and an USB Host Shield, not USB_Host_Shield_2.0. The main problem is understand the timers code is the code block I post before, If I can change the timer in use, I'll be able to change the PWM pin to connect the motor shield.
Is it more clear now?
