Help to modify a pin in a library
Hi all,
I use a arduino IR library to receive and send IR codes.
The pin used by the IR emitting led is written directly in the library, it's Arduino pin 3.
Everything worked well, untill I forgot the resistor for the IR led. Since that mistake, this Arduino pin doesn't sink or source any current.
I have to change the pin directly in the library to choose another one, but I don't know how to do this.
That's the concerned code of the library :
/* Sends an IR mark for the specified number of microseconds. */
void IRsend::mark(int time) {
    // The mark output is modulated at the PWM frequency.
  TCCR2A |= _BV(COM2B1); // Enable pin 3 PWM output
  delayMicroseconds(time);
/* Leave pin off for time (given in microseconds) */
void IRsend::space(int time) {
  // Sends an IR space for the specified number of microseconds.
  // A space is no output, so the PWM output is disabled.
  TCCR2A &= ~(_BV(COM2B1)); // Disable pin 3 PWM output
void IRsend::enableIROut(int khz) {
  // Enables IR output.  The khz value controls the modulation frequency in kilohertz.
  // The IR output will be on pin 3 (OC2B).
  // This routine is designed for 36-40KHz; if you use it for other values, it's up to you
  // to make sure it gives reasonable results.  (Watch out for overflow / underflow / rounding.)
  // TIMER2 is used in phase-correct PWM mode, with OCR2A controlling the frequency and OCR2B
  // controlling the duty cycle.
  // There is no prescaling, so the output frequency is 16MHz / (2 * OCR2A)
  // To turn the output on and off, we leave the PWM running, but connect and disconnect the output pin.
  // A few hours staring at the ATmega documentation and this will all make sense.
  // See my Secrets of Arduino PWM at http://arcfn.com/2009/07/secrets-of-arduino-pwm.html for details.
  // Disable the Timer2 Interrupt (which is used for receiving IR)
  TIMSK2 &= ~_BV(TOIE2); //Timer2 Overflow Interrupt
  pinMode(3, OUTPUT);
  digitalWrite(3, LOW); // When not sending PWM, we want it low
  // COM2A = 00: disconnect OC2A
  // COM2B = 00: disconnect OC2B; to send signal set to 10: OC2B non-inverted
  // WGM2 = 101: phase-correct PWM with OCRA as top
  // CS2 = 000: no prescaling
  TCCR2A = _BV(WGM20);
  TCCR2B = _BV(WGM22) | _BV(CS20);
  // The top value for the timer.  The modulation frequency will be SYSCLOCK / 2 / OCR2A.
  OCR2A = SYSCLOCK / 2 / khz / 1000;
  OCR2B = OCR2A / 3; // 33% duty cycle
Thanks for your help
I'd start by looking for something that referenced the number "3" and a pin.
(though if I were writing a published library, I'd make it more obvious and easier to change in the first place)
Well that library has some example files and the below shows that the users sketch defines what input pin should be used when calling the IR receive function:
  • IRremote: IRrecvDemo - demonstrates receiving IR codes with IRrecv
  • An IR detector/demodulator must be connected to the input RECV_PIN.
  • Version 0.1 July, 2009
  • Copyright 2009 Ken Shirriff
  • http://arcfn.com
#include <IRremote.h>
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
irrecv.enableIRIn(); // Start the receiver
if (irrecv.decode(&results)) {
Serial.println(results.value, HEX);
irrecv.resume(); // Receive the next value
AWOL:
Indeed, I think I have to change theses lines (in red) :
pinMode(3, OUTPUT);
Of course, it isn't lines 3 and 4 which raises a problem, but lines 1 and 2. I don't know what does these lines mean.
retrolefty:
My problem concerns the emitting led, which is obviously on pin 3.
Help please...
