Hi
Can anyone help me with my program?
I Uses M2tklib. And have some things i'cant make.
In this code i like to make a screen that shows a countdown between picture take and to the new one is taken. Also a total count taken to now. And a button to come back to the main menu.
i think it is to go into then places with the comment in this.
void fn_start(m2_el_fnarg_p fnarg) {
// Here i like to have a loop to i puss the select button to end it.
Serial.println("Start");
Serial.print("Delay = ");
Serial.print(n_time_delay);
Serial.print(" - TimeUnit = ");
if (select_time_unit == 0) {
Serial.println("Minutter");
if (select_time_unit == 1) {
Serial.println("Timer");
for(uint8_t a = n_time_delay; a > 0; a--){
// Here i like to have a emty screen there shows a countdown to the picture is taken and how many pictures there is taken to now.
n_time_delay_show = a;
delay((1000*n_time_delay)*((select_time_unit*60)+1));
Serial.print("a = ");
Serial.println(a);
takePic();
// Loop end
Serial.println("Slut");
Full code, the full loop is not made yet.
CanonTimeTake.pde
Arduino Nano Canon time take.
Version 2
Build 1
Unit to control Canon 1200D picture take.
Uses:
Arduino Nano V3.
OLED from aliexpress with SPI interface, Software SPI
Rotery encoder with key.
Universal 8bit Graphics Library, https://github.com/olikraus/u8glib/
Mini Interative Interface Toolkit Library, https://code.google.com/p/m2tklib/
Key Rotater
Pin 1 - D2
Pin 2 - D3
Select D12
Cam
Focus D10
Trigger D11
Display
SCL D4
SDA D5
RST D7
O/C D6
#include "U8glib.h"
#include "M2tk.h"
#include "utility/m2ghu8g.h"
// setup u8g object, please remove comment from one of the following constructor calls
// IMPORTANT NOTE: The following list is incomplete. The complete list of supported
U8GLIB_SSD1306_128X64 u8g(4, 5, 8, 6, 7);
// SW SPI Com: SCK = 3, MOSI = 4, CS = 7, D/C = 5, RST = 6
// Nano OLED
// D4 SCL
// D5 SDA
// D8 brues ikke
// D6 D/C
// D7 RST
int ledFocus = 11;
int ledTrigger = 10;
uint32_t n_total_pic = 0;
uint8_t n_time_delay = 10;
uint8_t select_time_unit = 0;
void takePic() {
digitalWrite(ledFocus, HIGH);
digitalWrite(ledFocus, LOW);
delay(100);
digitalWrite(ledTrigger, HIGH);
digitalWrite(ledTrigger, LOW);
n_total_pic++;
const char *fn_idx_to_time_unit(uint8_t idx)
if( idx == 0) return "Minutter";
else return "Timer";
uint8_t n_time_delay_show = n_time_delay;
// And a button to press to stop the loop. And then go back to the mainmenu.
Serial.println(a);
takePic();
// Loop end
void fn_take(m2_el_fnarg_p fnarg) {
takePic();
// Forward declaration of the toplevel element
M2_EXTERN_ALIGN(top_menu);
M2_LABEL(el_l1, "f1", "Canon Timer");
M2_LABEL(el_u1, NULL, " V2.1!");
M2_LABEL(el_l2, "f1", " Tid :");
M2_U8NUM(el_u2, "c2", 0, 60, &n_time_delay);
M2_LABEL(el_l3, "f1", " Enhed :");
M2_COMBO(el_u3, NULL, &select_time_unit, 2, fn_idx_to_time_unit);
M2_BUTTON(el_fn_start, "f1x0y50", "[Start]", fn_start);
M2_BUTTON(el_fn_take, "f1b1x30y50", "[Take]", fn_take);
M2_LABEL(el_l5, "f1", "Count :");
M2_U32NUM(el_u5, "c4r1", &n_total_pic);
M2_LIST(list) = { &el_l1, &el_u1, &el_l2, &el_u2, &el_l3, &el_u3, &el_fn_start, &el_fn_take, &el_l5, &el_u5 };
M2_GRIDLIST(el_gridlist, "c2", list);
M2_ALIGN(top_menu, "-1|1W64H64", &el_gridlist);
// m2 object and constructor
// Note: Use the "m2_eh_4bd" handler, which fits better to the "m2_es_arduino_rotary_encoder"
M2tk m2(&top_menu, m2_es_arduino_rotary_encoder, m2_eh_4bd, m2_gh_u8g_bf);
// Arduino Setup & Loop
void setup(void) {
pinMode(ledFocus, OUTPUT);
pinMode(ledTrigger, OUTPUT);
// Connect u8glib with m2tklib
m2_SetU8g(u8g.getU8g(), m2_u8g_box_icon);
// Assign u8g font to index 0
m2.setFont(0, u8g_font_6x12r);
m2.setFont(1, u8g_font_7x13r);
// define button for the select message
m2.setPin(M2_KEY_SELECT, 12);
// The incremental rotary encoder is conected to these two pins
m2.setPin(M2_KEY_ROT_ENC_A, 3);
m2.setPin(M2_KEY_ROT_ENC_B, 2);
// check rotary encoder also inside the picture loop
m2.checkKey();
// process events and redraw menu if required
if ( m2.handleKey() != 0 ) {
u8g.firstPage();
do {
m2.checkKey();
// draw menu
m2.draw();
} while( u8g.nextPage() );
Hope sombody can help me, and sorry for my english.
