HELP to Need to add EEPROM.h to arduino uno
I thanks to ARDUINO
also thanks to github.com
i copy program (washing-machine/washing-machine.ino at master · jagpreetstamber/washing-machine · GitHub)
and modify working good need add EEPROM.h
Help
I’m hemanth am not a programmer i want to make washing machine program board for LG old front load washing machine this machine control board not available is service center all other parts working good so i don’t want waste my machine i done with all electrical and electronics components wiring done program is also done but i need 4 more option
mainly need
  1. After power loss resume the program (return the where is off and all user input) i done with power loss detection with A0 pin but i don’t know how start program .
2)I want Pause and Resume loop (timer )
3)need change minimum required
void printTopRowIfSelectButtonPressed(const char **text, int arraySize, int cursorPosition) {
if (selectButtonPressed) {
selectButtonPressed = false;
printTopRow(text, arraySize, cursorPosition);
void printBottomRowIfChangeButtonPressed(const char **text, int arraySize, int cursorPosition) {
if (upDownButtonPressed) {
upDownButtonPressed = false;
printBottomRow(text, arraySize, cursorPosition);
void printTopRow(const char **text, int arraySize, int cursorPosition) {
clearRow(0);
lcd.setCursor(0, 0);
printRow(text, arraySize);
void printBottomRow(const char **text, int arraySize, int cursorPosition) {
clearRow(1);
lcd.setCursor(0, 1);
void printRow(const char text, int arraySize) {
for (int i = 0; i < arraySize; i++) {
lcd.print(text
  • TO*
  • Like this (lcd.setCursor(0, 4);*
  • lcd.print(“UNPLUG PIN”);*
    4) when washing process is running need check water level is low need fill water and high need to drain
    Important
    Pleas help
    washing_machine_uno.ino (20 KB)
In general you will find advice on a particular part of Arduino by typing 'Arduino Reference' followed by the name of what you want to know about.
So try a Google search on;
Arduino Reference EEPROM
Lots of examples of how to use EEPROM to be found on the reference page ..............
Thanks for responding i regularly checking but i don't have any idea how to start main problem is stage 6 have more program and i want to save user input and current processes how to start please give one example user input and process save to eeprom pleas
