Help to program a "software button" to change modes for bluetooth/RC TX/RX (PWM only) obstacle avoiding robot using arduino UNO and ultrasonic sensor
Hi all
I am trying to program a software button on a yellow motor obstacle avoiding robot using arduino UNO and ultrasonic sensor using with bluetooth or RC Transceivers (PWM only)
I have successfully loaded and tested the original code for this project found here
And I have successfully loaded and tested the code for a bluetooth robot here
I have also been able to merge the to codes together as per the code below, but as expected the robot does the obstacle part of the code all of the time and when you press a button using the bluetooth app BitBlue it overrides what it is doing and does that command but then goes straight back to obstacle task.
What I want is if I press the letter 'C'(Select) is to stop the current mode (obstacle) then go to bluetooth mode(manual control mode) and then go back again if I press the little 'C'(Select) or 'S'(Start).
So what I am after for on this example is a software switch of sorts to tell the bot that if 'C' is pressed go to manual mode.
#include <Servo.h>
int motorLeftB = 8; // define pin6 as left back connect with IN1
int motorLeftA = 4; // define pin9 as left forward connect with IN2
int motorRightB = 7; // define pin10 as right back connect with IN3
int motorRightA = 2; // define pin11 as right back connect with IN4
int UEchoPin = A0; // define ultrasonic receive pin (Echo)
int UTriggerPin = A1; // define ultrasonic send pin(Trig)
int Fspeedd = 0; // forward distance
int Rspeedd = 0; // right distance
int Lspeedd = 0; // left distance
int directionn = 0; //
Servo myservo; // new myservo
int delay_time = 250; // set stable time
int Fgo = 8; // forward
int Rgo = 6; // turn right
int Lgo = 4; // turn left
int Bgo = 2; // back
char bt = 0;       //BT
  pinMode(motorLeftB, OUTPUT);
  pinMode(motorLeftA, OUTPUT);
  pinMode(motorRightB, OUTPUT);
  pinMode(motorRightA, OUTPUT);
  pinMode(UEchoPin, INPUT);
  pinMode(UTriggerPin, OUTPUT);
  myservo.attach(11); // define the servo pin(PWM)
void advance(int a) // forward
  digitalWrite(motorRightB, LOW);
  digitalWrite(motorRightA, HIGH);
  digitalWrite(motorLeftB, LOW);
  digitalWrite(motorLeftA, HIGH);
  delay(a * 15);
void turnR(int d) //turn right
  digitalWrite(motorLeftB, HIGH);
  digitalWrite(motorLeftA, LOW);
  delay(d * 50);
void turnL(int e) //turn left
  digitalWrite(motorRightB, HIGH);
  digitalWrite(motorRightA, LOW);
  delay(e * 50);
void stopp(int f) //stop
  delay(f * 100);
void back(int g) //back
  delay(g * 300);
void detection() //test the distance of different direction
  delay(200);
  ask_pin_F(); // read forward distance
  if (Fspeedd < 10) // if distance less then 10
    stopp(1);
    back(2);
  if (Fspeedd < 25) // if distance less then 10
    stopp(1);
    ask_pin_L();
    delay(delay_time);
    ask_pin_R();
    delay(delay_time);
    if (Lspeedd > Rspeedd) //if left distance more than right distance
      directionn = Rgo;
    if (Lspeedd <= Rspeedd) //if left distance not more than right
      //distance
      directionn = Lgo;
    //if left if (Lspeedd < 10 && Rspeedd < 10) distance and right
    //distance both less than 10
      directionn = Bgo;
    directionn = Fgo; // forward go
void ask_pin_F() // test forward distance
  myservo.write(90);
  digitalWrite(UTriggerPin, LOW);
  delayMicroseconds(2);
  digitalWrite(UTriggerPin, HIGH);
  delayMicroseconds(10);
  float Fdistance = pulseIn(UEchoPin, HIGH);
  Fdistance = Fdistance / 5.8 / 10;
  Serial.print("F distance:");
  Serial.println(Fdistance);
  Fspeedd = Fdistance;
void ask_pin_L() // test left distance
  myservo.write(150);
  delay(delay_time);
  float Ldistance = pulseIn(UEchoPin, HIGH);
  Ldistance = Ldistance / 5.8 / 10;
  Serial.print("L distance:");
  Serial.println(Ldistance);
  Lspeedd = Ldistance;
void ask_pin_R() // test right distance
  myservo.write(20);
  delay(delay_time);
  float Rdistance = pulseIn(UEchoPin, HIGH);
  Rdistance = Rdistance / 5.8 / 10;
  Serial.print("R distance:");
  Serial.println(Rdistance);
  Rspeedd = Rdistance;
  myservo.write(90);
  detection();
  if (directionn == 2)
    back(3);
    turnL(2);
    Serial.print(" Reverse ");
  if (directionn == 6)
    back(1);
    turnR(6);
    Serial.print(" Right ");
  if (directionn == 4)
    back(1);
    turnL(6);
    Serial.print(" Left ");
  if (directionn == 8)
    advance(1);
    Serial.print(" Advance ");
    Serial.print(" ");
    if (Serial.available() > 0)
      bt = Serial.read();
      //  digitalWrite(led, 1);
      /*_________________________________________________________________________________________________*/
      if (bt == 'F')       //move forwards
      else if (bt == 'B')       //move backwards
      else if (bt == 'X')     //stop!!
      else if (bt == 'R')    //right
      else if (bt == 'L')     //left
      else if (bt == 'I')    //forward right
      else if (bt == 'G')    //forward left
For the next example instead of bluetooth I need a RC PWM RC Transceiver to control the robot in manual mode
I have been following Dronebotworkshop and found this great resource for PWM but in his example he doesn't actually have code for PWM control only iBus control. Which is fine if you have one of those more expensive units. So the search went on and I found this resource PWMread_RCfailsafe I have done the calibration but and have the file ready to go in the folder so that when I open up the original file it creates a new tab that has PWMread_RCfailsafe with the project. But how do I
Create that software switch as such to put it in 'RC mode' and how do I call that mode? I have a turnigy 5CH TX/RX and want to use the 5CH switch for that mode switching (It has already been setup correctly to read the switch)
The Code
#include <Servo.h>
char bt = 0;       //BT
  delay(a * 15);
  delay(d * 50);
  delay(e * 50);
  delay(f * 100);
  delay(g * 300);
  delay(200);
    stopp(1);
    back(2);
    stopp(1);
    ask_pin_L();
    delay(delay_time);
    ask_pin_R();
    delay(delay_time);
      directionn = Rgo;
      //distance
      directionn = Lgo;
      directionn = Bgo;
  myservo.write(90);
  myservo.write(150);
  delay(delay_time);
  myservo.write(20);
  delay(delay_time);
  myservo.write(90);
  detection();
    back(3);
    turnL(2);
    back(1);
    turnR(6);
    back(1);
    turnL(6);
    advance(1);
    Serial.print(" ");
      bt = Serial.read();
And the RC Code
/*  Kelvin Nelson 24/07/2019
 *  Pulse Width Modulation (PWM) decoding of RC Receiver with failsafe
 *  This code contains easy to use functions to measure square wave signals on any arduiuno pro mini, nano or uno pins, excluding A6 and A7.
 *  The code is intended to be used with RC receivers, but could also be used in most other PWM measurement applications as a direct replacement for pulseIn(PIN, HIGH).
 *  (to date it hasn't been tested at a frequency greater than 1khz or on an arduino mega)
 *  An RC signal pulse can be converted from a pulse width duration (1000-2000uS) at each input pin into an -+100% (-+1.0) output for use in a sketch.
 *  The calibration for this conversion plus a failsafe setting can be set for each channel. (fail safe tolerances 10-330Hz and 500-2500uS).
 *  The raw data for each pin can also be extracted, i.e. time of pulse, pulse width, frame length, duty and frequency.
 *  Set-up is quick, the organisation of this file is as follows:
 *    - Overview of the code
 *    - List of functions
 *    - How to use, including example sketches
 *    - User defined variables -> specify input pins, transmitter calibration, and failsafe.
 *    - Global variables and functions
 *  OVERVIEW OF THE CODE:
 *  The code enables pin change interrupts on the selected pins by setting the appropriate registers.
 *  A voltage change on any of the selected pins will trigger one of three Interrupt Service Routines depending on which register the pin belongs to.
 *    - ISR(PCINT0_vect), ISR(PCINT1_vect) or ISR(PCINT2_vect)
 *  Within each ISR the code determines which pin has changed, and makes a note of the time before returning back to the main loop().
 *  The time intervals between pin changes are used to calculate pulse width and frame length.
 *  Flags are set by the ISR to indicate when new pulses are received.
 *  The Flags are then used to extract and process the data collected by each ISR.
 *  Although it's not exactly the same, this code follows similar principles to those explained in this video: https://youtu.be/bENjl1KQbvo
// LIST OF FUNCTIONS:
// OUTPUT TYPE    NAME OF FUNCTION           NOTES
// void           setup_pwmRead()            initialise the PWM measurement using pin change interrupts
// RC RECEIVER DECODING
// boolean        RC_avail()                 returns a HIGH when new RC data is available
// float          RC_decode(channel number)  decodes the selected RC channel into the range +-100%, and applies a failsafe.
// void           print_RCpwm()              Prints the RC channel raw data to serial port (used for calibration).
// GENERIC PWM MEASUREMENTS
// boolean        PWM_read(channel number)   returns a HIGH when a new pulse has been detected on a particular channel.
//                                           The function saves the pulse data to variables outside the interrupt routines
//                                           and must be called just before using the rest of PWM functions.
// unsigned long  PWM_time()                 returns the time at the start of pulse
// float          PWM()                      returns the pulse width
// float          PWM_period()               returns the time between pulses
// float          PWM_freq()                 calculates the frequency
// float          PWM_duty()                 calculates the duty
// NOTE: PWM_read(CH) and RC_decode(CH) use the same flags to detect when new data is available, meaning data could be lost if both are used on the same channel at the same time.
// SUGESTION: if you want to use PWM_read(CH) to find the frame rate of an RC channel call it before RC_decode(CH). The output from RC_decode(CH) will then default to the failsafe.
// HOW TO USE, including example sketches
// under the "USER DEFINED VARIABLES" title in the code below:
//    Step 1: enter the input pins into the array pwmPIN[] = {}.
//            - Any number of pins can be entered into pwmPIN[] (pins available 0 - 13 and A0 - A5)
//            - The pins do not need to be in numerical order, for example pwmPIN[] = {A0,5,6,10,8} for 5 channels, or pwmPIN[] = {A0,5} for 2 channels
//            - The first element in the array is the pin number for  "channel 1", and the second is the pin number for "channel 2"... etc.
//            - All pins connected to the RC receiver need to be at the start of the array. i.e. the first 2 channels could be RC inputs and the 3rd channel could be connected to another device like the echo pin of an ultrasonic sensor.
//    Step 2: if an RC receiver is connected to all of the inputs then set RC_inputs to 0, if not specify the number of channels connected to the receiver i.e. RC_inputs = 2;
//    Step 3: calibrate your transmitter by uploading a simple sketch with this .ino file included in the sketch folder, and print the raw PWM values to serial (alternatively copy and paste the functions needed into the sketch).
//            Using the info from the serial monitor manually update the values in arrays RC_min[], RC_mid[], RC_max[] to suit your transmitter (use full rates to get the best resolution).
//            an example sketch for printing the RC channel PWM data to serial.
              void setup()  {
                  setup_pwmRead();
                  if(RC_avail()) print_RCpwm();
//    Step 4: Choose a failsafe position for each channel, in the range -1.0 to +1.0, and enter it into the array RC_failsafe[] = {}
//            Note: if you would like the arduino to respond to the loss of transmitter signal you may need to disable the failsafe feature on your receiver (if it has one).
//            an example sketch to check the operation of the failsafe, and for printing the calibrated channels to serial:
              unsigned long now;                        // timing variables to update data at a regular interval
              unsigned long rc_update;
              const int channels = 6;                   // specify the number of receiver channels
              float RC_in[channels];                    // an array to store the calibrated input from receiver
              void setup()  {
                  setup_pwmRead();
              void loop()  {
                  now = millis();
                  if(RC_avail() || now - rc_update > 25){   // if RC data is available or 25ms has passed since last update (adjust to suit frame rate of receiver)
                    rc_update = now;
                    //print_RCpwm();                        // uncommment to print raw data from receiver to serial
                    for (int i = 0; i<channels; i++){       // run through each RC channel
                      int CH = i+1;
                      RC_in[i] = RC_decode(CH);             // decode receiver channel and apply failsafe
                      print_decimal2percentage(RC_in[i]);   // uncomment to print calibrated receiver input (+-100%) to serial
                    Serial.println();                       // uncomment when printing calibrated receiver input to serial.
// EXAMPLE USE OF GENERIC PWM FUNCTIONS:
 // Print the pulse width of channel 1 to the serial monitor.
 // This is equivelant to the using standard arduino pulseIn(pin, HIGH) function, but without blocking the code.
 if (PWM_read(1)){          // if a new pulse is detected on channel 1, print the pulse width to serial monitor.
   Serial.println(PWM());
 // Or
 // Print RC receiver frame length and frame rate
   Serial.print(PWM_period(),0);Serial.print("uS ");
   Serial.print(PWM_freq());Serial.println("Hz");
 *  USER DEFINED VARIABLES (MODIFY TO SUIT YOUR APPLICATION)
// PWM input pins, any of the following pins can be used: digital 0 - 13 or analog A0 - A5
const int pwmPIN[]={2,3,4,5,6,7}; // an array to identify the PWM input pins (the array can be any length)
                                  // first pin is channel 1, second is channel 2...etc
int RC_inputs = 0;                // The number of pins in pwmPIN that are connected to an RC receiver. Addition pins not connected to an RC receiver could be used for any other purpose i.e. detecting the echo pulse on an HC-SR04 ultrasonic distance sensor
                                  // When 0, it will automatically update to the number of pins specified in pwmPIN[] after calling setup_pwmRead().
// Calibration of each RC channel:
// The arrays below are used to calibrate each RC channel into the range -1 to +1 so that servo direction, mixing, rates, sub trims...etc can be applied in sketch depending on application.
// The arrays should be modified in order to calibrate the min, middle and max pulse durations to suit your transmitter (use max rates to get the best resolution).
// FYI: the function print_PWM() will print the raw pulse width data for all the RC channels to the serial port.
// if the RC_min[], RC_mid[], RC_max[] are empty or have missing data the calibration will default to min 1000us, mid 1500us and max 2000us.
//SANWA 6CH 40MHz with corona RP6D1
//                THR     RUD     PIT     BAL     SWITCH  SLIDER
int RC_min[6] = { 988,    1060,   976,    960,    1056,   1116};
int RC_mid[6] = { 1472,   1446,   1424,   1398,   1374,   1460};
int RC_max[6] = { 1800,   1816,   1796,   1764,   1876,   1796};
// fail safe positions
float RC_failsafe[] = {0.00, 0.00, 1, 0.00, -0.25, 0.00};
// enter a failsafe position (in the range of -+1) for each RC channel in case radio signal is lost
// if the array is the incorrect length for the number of RC channels, the failsafe will default to neutral i.e. 0.
// The failsafe tolerances are: 10-330Hz & 500-2500us
 *    GLOBAL PWM DECODE VARIABLES
const int num_ch = sizeof(pwmPIN)/sizeof(int);  // calculate the number of input pins (or channels)
volatile int PW[num_ch];                        // an array to store pulsewidth measurements
volatile boolean prev_pinState[num_ch];         // an array used to determine whether a pin has gone low-high or high-low
volatile unsigned long pciTime;                 // the time of the current pin change interrupt
volatile unsigned long pwmTimer[num_ch];        // an array to store the start time of each PWM pulse
volatile boolean pwmFlag[num_ch];               // flag whenever new data is available on each pin
volatile boolean RC_data_rdy;                   // flag when all RC receiver channels have received a new pulse
unsigned long pwmPeriod[num_ch];                 // period, mirco sec, between two pulses on each pin
byte pwmPIN_reg[num_ch];                        // each of the input pins expressed as a position on it's associated port register
byte pwmPIN_port[num_ch];                       // identify which port each input pin belongs to (0 = PORTB, 1 = PORTC, 2 = PORTD)
const int size_RC_min = sizeof(RC_min) / sizeof(int);           // measure the size of the calibration and failsafe arrays
const int size_RC_mid = sizeof(RC_mid) / sizeof(int);
const int size_RC_max = sizeof(RC_max) / sizeof(int);
const int size_RC_failsafe = sizeof(RC_failsafe) / sizeof(float);
// FUNCTION USED TO TURN ON THE INTERRUPTS ON THE RELEVANT PINS
// code from http://playground.arduino.cc/Main/PinChangeInterrupt
void pciSetup(byte pin){
    *digitalPinToPCMSK(pin) |= bit (digitalPinToPCMSKbit(pin));  // enable pin
    PCIFR  |= bit (digitalPinToPCICRbit(pin));                   // clear any outstanding interrupt
    PCICR  |= bit (digitalPinToPCICRbit(pin));                   // enable interrupt for the group
// FUNCTION USED TO FIND THE PIN POSITION ON EACH PORT REGISTER: helps the interrupt service routines, ISR, run faster
void pwmPIN_to_port(){
  for (int i = 0; i < num_ch; i++){
    // determine which port and therefore ISR (PCINT0_vect, PCINT1_vect or PCINT2_vect) each pwmPIN belongs to.
        pwmPIN_port[i] = 1;    // pin belongs to PCINT1_vect (PORT C)
    if (pwmPIN[i] >= 0 && pwmPIN[i] <= 7)                         pwmPIN_port[i] = 2;    // pin belongs to PCINT2_vect (PORT D)
    else if (pwmPIN[i] >= 8 && pwmPIN[i] <= 13)                   pwmPIN_port[i] = 0;    // pin belongs to PCINT0_vect (PORT B)
    // covert the pin number (i.e. pin 11 or pin A0) to the pin position in the port register. There is most likely a better way of doing this using a macro...
    // (Reading the pin state directly from the port registers speeds up the code in the ISR)
    if(pwmPIN[i] == 0 || pwmPIN[i] == A0 || pwmPIN[i] == 8)         pwmPIN_reg[i] = 0b00000001;
    else if(pwmPIN[i] == 1 || pwmPIN[i] == A1 || pwmPIN[i] == 9)    pwmPIN_reg[i] = 0b00000010;
    else if(pwmPIN[i] == 2 || pwmPIN[i] == A2 || pwmPIN[i] == 10)   pwmPIN_reg[i] = 0b00000100;
    else if(pwmPIN[i] == 3 || pwmPIN[i] == A3 || pwmPIN[i] == 11)   pwmPIN_reg[i] = 0b00001000;
    else if(pwmPIN[i] == 4 || pwmPIN[i] == A4 || pwmPIN[i] == 12)   pwmPIN_reg[i] = 0b00010000;
    else if(pwmPIN[i] == 5 || pwmPIN[i] == A5 || pwmPIN[i] == 13)   pwmPIN_reg[i] = 0b00100000;
    else if(pwmPIN[i] == 6)                                         pwmPIN_reg[i] = 0b01000000;
    else if(pwmPIN[i] == 7)                                         pwmPIN_reg[i] = 0b10000000;
// SETUP OF PIN CHANGE INTERRUPTS
void setup_pwmRead(){
  for(int i = 0; i < num_ch; i++){              // run through each input pin
    pciSetup(pwmPIN[i]);                        // enable pinchange interrupt for pin
  pwmPIN_to_port();                             // determines the port for each input pin
                                                // pwmPIN_to_port() also coverts the pin number in pwmPIN[] (i.e. pin 11 or pin A0) to the pin position in the port register (i.e. 0b00000001) for use in the ISR.
  if(RC_inputs == 0 || RC_inputs > num_ch) RC_inputs = num_ch;    // define the number of pins connected to an RC receiver.
// INTERRUPT SERVICE ROUTINES (ISR) USED TO READ PWM INPUT
// the PCINT0_vect (B port register) reacts to any changes on pins D8-13.
// the PCINT1_vect (C port register)          ""        ""         A0-A5.
// the PCINT2_vect (D port register)          ""        ""         D0-7.
// port registers are used to speed up if statements in ISR code:
// https://www.arduino.cc/en/Reference/PortManipulation http://tronixstuff.com/2011/10/22/tutorial-arduino-port-manipulation/
// http://harperjiangnew.blogspot.co.uk/2013/05/arduino-port-manipulation-on-mega-2560.html
// READ INTERRUPTS ON PINS D8-D13: ISR routine detects which pin has changed, and returns PWM pulse width, and pulse repetition period.
ISR(PCINT0_vect){                                                 // this function will run if a pin change is detected on portB
  pciTime = micros();                                             // Record the time of the PIN change in microseconds
  for (int i = 0; i < num_ch; i++){                               // run through each of the channels
    if (pwmPIN_port[i] == 0){                                     // if the current channel belongs to portB
      if(prev_pinState[i] == 0 && PINB & pwmPIN_reg[i]){          // and the pin state has changed from LOW to HIGH (start of pulse)
        prev_pinState[i] = 1;                                     // record pin state
        pwmPeriod[i] = pciTime - pwmTimer[i];                     // calculate the time period, micro sec, between the current and previous pulse
        pwmTimer[i] = pciTime;                                    // record the start time of the current pulse
      else if (prev_pinState[i] == 1 && !(PINB & pwmPIN_reg[i])){ // or the pin state has changed from HIGH to LOW (end of pulse)
        prev_pinState[i] = 0;                                     // record pin state
        PW[i] = pciTime - pwmTimer[i];                            // calculate the duration of the current pulse
        pwmFlag[i] = HIGH;                                        // flag that new data is available
        if(i+1 == RC_inputs) RC_data_rdy = HIGH;
// READ INTERRUPTS ON PINS A0-A5: ISR routine detects which pin has changed, and returns PWM pulse width, and pulse repetition period.
ISR(PCINT1_vect){                                                 // this function will run if a pin change is detected on portC
    if (pwmPIN_port[i] == 1){                                     // if the current channel belongs to portC
      if(prev_pinState[i] == 0 && PINC & pwmPIN_reg[i]){          // and the pin state has changed from LOW to HIGH (start of pulse)
      else if (prev_pinState[i] == 1 && !(PINC & pwmPIN_reg[i])){ // or the pin state has changed from HIGH to LOW (end of pulse)
// READ INTERRUPTS ON PINS D0-7: ISR routine detects which pin has changed, and returns PWM pulse width, and pulse repetition period.
ISR(PCINT2_vect){                                                 // this function will run if a pin change is detected on portD
    if (pwmPIN_port[i] == 2){                                     // if the current channel belongs to portD
      if(prev_pinState[i] == 0 && PIND & pwmPIN_reg[i]){          // and the pin state has changed from LOW to HIGH (start of pulse)
      else if (prev_pinState[i] == 1 && !(PIND & pwmPIN_reg[i])){ // or the pin state has changed from HIGH to LOW (end of pulse)
 *  RC OUTPUT FUNCTIONS
 boolean RC_avail(){
    boolean avail = RC_data_rdy;
    RC_data_rdy = LOW;                          // reset the flag
    return avail;
  float RC_decode(int CH){
  if(CH < 1 || CH > RC_inputs) return 0;     // if channel number is out of bounds return zero.
  int i = CH - 1;
  // determine the pulse width calibration for the RC channel. The default is 1000, 1500 and 2000us.
  int Min;
  if(CH <= size_RC_min) Min = RC_min[CH-1]; else Min = 1000;
  int Mid;
  if(CH <= size_RC_mid) Mid = RC_mid[CH-1]; else Mid = 1500;
  int Max;
  if(CH <= size_RC_max) Max = RC_max[CH-1]; else Max = 2000;
  float CH_output;
  if(FAILSAFE(CH) == HIGH){                         // If the RC channel is outside of failsafe tolerances (10-330hz and 500-2500uS)
      if(CH > size_RC_failsafe) CH_output = 0;      // and if no failsafe position has been defined, set output to neutral
      else CH_output = RC_failsafe[i];              // or if defined set the failsafe position
  else{                                             // If the RC signal is valid
    CH_output = calibrate(PW[i],Min,Mid,Max);       // calibrate the pulse width to the range -1 to 1.
  return CH_output;
  // The signal is mapped from a pulsewidth into the range of -1 to +1, using the user defined calibrate() function in this code.
  // 0 represents neutral or center stick on the transmitter
  // 1 is full displacement of a control input is one direction (i.e full left rudder)
  // -1 is full displacement of the control input in the other direction (i.e. full right rudder)
 *  Receiver Calibration
 // NEED TO SPEED UP
float calibrate(float Rx, int Min, int Mid, int Max){
   float calibrated;
   if (Rx >= Mid)
    calibrated = map(Rx, Mid, Max, 0, 1000);  // map from 0% to 100% in one direction
   else if (Rx == 0)
    calibrated = 0;                           // neutral
    calibrated = map(Rx, Min, Mid, -1000, 0); // map from 0% to -100% in the other direction
  return calibrated * 0.001;
// Basic Receiver FAIL SAFE
// check for 500-2500us and 10-330Hz (same limits as pololu)
boolean FAILSAFE(int CH){
   int i = CH-1;
   boolean failsafe_flag = LOW;
       if(pwmFlag[i] == 1)                             // if a new pulse has been measured.
            pwmFlag[i] = 0;                            // set flag to zero
            if(pwmPeriod[i] > 100000)                  // if time between pulses indicates a pulse rate of less than 10Hz
              failsafe_flag = HIGH;
            else if(pwmPeriod[i] < 3000)               // or if time between pulses indicates a pulse rate greater than 330Hz
            if(PW[i] < 500 || PW[i] > 2500)           // if pulswidth is outside of the range 500-2500ms
        else if (micros() - pwmTimer[i] > 100000)     // if there is no new pulswidth measurement within 100ms (10hz)
    return failsafe_flag;
 *  Quick print function of Rx channel input
void print_RCpwm(){                             // display the raw RC Channel PWM Inputs
  for (int i = 0; i < RC_inputs; i++){
    //Serial.print(" ch");Serial.print(i+1);
    Serial.print("  ");
    if(PW[i] < 1000) Serial.print(" ");
    Serial.print(PW[i]);
  Serial.println("");
void print_decimal2percentage(float dec){
  int pc = dec*100;
  // the number and text will take up 6 charactors i.e ___3%_ or -100%_
  if (pc >= 0) Serial.print(" ");
  if (abs(pc) < 100) Serial.print(" ");
  if (abs(pc) < 10) Serial.print(" ");
  Serial.print(" ");Serial.print(pc);Serial.print("% ");
 * GENERIC PWM FUNCTIONS
unsigned long pin_time;
float pin_pwm;
float pin_period;
boolean PWM_read(int CH){
  if(CH < 1 && CH > num_ch) return false;
  int i = CH-1;
  boolean avail = pwmFlag[i];
  if (avail == HIGH){
    pwmFlag[i] = LOW;
    noInterrupts();
    pin_time = pwmTimer[i];
    pin_pwm = PW[i];
    pin_period = pwmPeriod[i];
    interrupts();
  return avail;
unsigned long PWM_time(){return pin_time;}
float PWM_period(){return pin_period;}
float PWM(){return pin_pwm;}
float PWM_freq(){
  float freq;
  return freq = 1000000 / pin_period;  // frequency Hz
float PWM_duty(){
  float duty;
  duty = pin_pwm/pin_period;
  return duty;
Cheers
You should divide your code into more functional parts.
Your loop()-function contains all the details directly.
To have different modes of operation the best programming-technique is a state-machine.
A state-machine offers much much more flexibility than a huge and nested if-else-if-structure.
And once you have understood the basic principle you never want to go back to nested if-conditions.
state-machines reduce the number of required if-condition to the minimum because only that part of the code that is relevant for each mode of operation is executed.
The unrelevant rest of the code is skipped.
The basic principle is a compact multi-"if-condition" based on the switch-case-break-structure
 switch(operationMode) {
  case manualMode:
    driveManually();
  case automaticMode:
    TheCodeforObstacle_avoiding();
the two cases are mutually exclusive. This is the reason why the number of if-conditions is reduced.
As long as manualMode is set the code
below case automaticMode simply is not executed and vice versa
best regards Stefan
consider
added "obstacleMode" toggled with 'C' command
reduced redundancy using sub-functions
#undef MyHW
#ifdef MyHW
struct Servo {
    void attach (int pin)  { }
    void write  (int pos)  { }
const byte motorLeftB  = 10; // define pin6 as left back connect with IN1
const byte motorLeftA  = 11; // define pin9 as left forward connect with IN2
const byte motorRightB = 12; // define pin10 as right back connect with IN3
const byte motorRightA = 13; // define pin11 as right back connect with IN4
const byte ServoPin    = 11;
const byte UEchoPin    = A0; // define ultrasonic receive pin (Echo)
const byte UTriggerPin = A1; // define ultrasonic send pin (Trig)
#else
#include <Servo.h>
int ServoPin    = 11;
int UTriggerPin = A1; // define ultrasonic send pin (Trig)
#endif
char bt = 0;       //BT
bool obstacleMode = false;
void setup ()
    Serial.begin (9600);
    pinMode (motorLeftB, OUTPUT);
    pinMode (motorLeftA, OUTPUT);
    pinMode (motorRightB, OUTPUT);
    pinMode (motorRightA, OUTPUT);
    pinMode (UEchoPin, INPUT);
    pinMode (UTriggerPin, OUTPUT);
    myservo.attach (11); // define the servo pin(PWM)
void motor (
    byte rightB,
    byte rightA,
    byte leftB,
    byte leftA )
    digitalWrite (rightB, LOW);
    digitalWrite (rightA, HIGH);
    digitalWrite (leftB,  LOW);
    digitalWrite (leftA,  HIGH);
void advance (int a) // forward
    motor (LOW, HIGH, LOW, HIGH);
    delay (a * 15);
void turnR (int d) //turn right
    motor (LOW, HIGH, HIGH, LOW);
    delay (d * 15);
void turnL (int e) //turn left
    motor (HIGH, LOW, LOW, HIGH);
    delay (e * 15);
void stopp (int f) //stop
    motor (HIGH, HIGH, HIGH, HIGH);
    delay (f * 15);
void back (int g) //back
    motor (HIGH, LOW, HIGH, LOW);
    delay (g * 15);
void detection () //test the distance of different direction
    delay (200);
    ask_pin_F (); // read forward distance
        stopp (1);
        back (2);
        stopp (1);
        ask_pin_L ();
        delay (delay_time);
        ask_pin_R ();
        delay (delay_time);
            directionn = Rgo;
        //distance
            directionn = Lgo;
            directionn = Bgo;
float
getDistance (
    int  angle )
    myservo.write (angle);
    digitalWrite (UTriggerPin, LOW);
    delayMicroseconds (2);
    digitalWrite (UTriggerPin, HIGH);
    delayMicroseconds (10);
    return pulseIn (UEchoPin, HIGH) / 5.8 / 10;
void ask_pin_F () // test forward distance
    Fspeedd = getDistance (90);
    Serial.print ("F distance:");
    Serial.println (Fspeedd);
void ask_pin_L () // test left distance
    Lspeedd = getDistance (150);
    Serial.print ("L distance:");
    Serial.println (Lspeedd);
void ask_pin_R () // test right distance
    Rspeedd = getDistance (20);
    Serial.print ("R distance:");
    Serial.println (Rspeedd);
void loop ()
    if (obstacleMode) {
        myservo.write (90);
        detection ();
            back (3);
            turnL (2);
            Serial.print (" Reverse ");
            back (1);
            turnR (6);
            Serial.print (" Right ");
            back (1);
            turnL (6);
            Serial.print (" Left ");
            advance (1);
            Serial.print (" Advance ");
            Serial.print (" ");
        bt = Serial.read ();
        //  digitalWrite (led, 1);
        if (bt == 'C')
            obstacleMode = ! obstacleMode;
            motor (LOW, LOW, LOW, LOW);
            motor (HIGH, LOW, LOW, LOW);
            motor (LOW, LOW, HIGH, LOW);
Hi all
This is the solution we went with, if it can be done better please lets us know how and the code
Cheers
#include <Servo.h>
int motorLeftB = 8;   // define pin8 as left back connect with IN1
int motorLeftA = 4;   // define pin4 as left forward connect with IN2
int motorRightB = 7;  // define pin7 as right back connect with IN3
int motorRightA = 2;  // define pin2 as right back connect with IN4
int directionn = 0;   // intial direction
char bt = 0;          // BT
bool setstate = false;
void obstacleMode();
void Bluetooth();
void advance(int f) // forward
  delay(f * 15);
void turnR(int r) //turn right
  delay(r * 50);
void turnL(int l) //turn left
  delay(l * 50);
void stopp(int x) //stop
  delay(x * 100);
void back(int b) //back
  delay(b * 300);
  delay(200);
    stopp(1);
    back(2);
    stopp(1);
    ask_pin_L();
    delay(delay_time);
    ask_pin_R();
    delay(delay_time);
      directionn = Rgo;
      //distance
      directionn = Lgo;
      directionn = Bgo;
  myservo.write(90);
  myservo.write(150);
  delay(delay_time);
  myservo.write(20);
  delay(delay_time);
switch(setstate){
case 1:
Bluetooth();
Serial.print("in bluetooth mode");
case 0:
obstacleMode();
Serial.print("in Obstacle mode");
if (Serial.available() > 0){bt = Serial.read();
      if (bt == 'C')
  setstate = ! setstate;
Serial.print(setstate);
Serial.print(bt);
void obstacleMode()
  myservo.write(90);
  detection();
    back(3);
    turnL(2);
    Serial.print("Movement: Reverse ");
    back(1);
    turnR(6);
    Serial.print("Movement: Right ");
    back(1);
    turnL(6);
    Serial.print("Movement: Left ");
    advance(1);
    Serial.print("Movement: Advance ");
    Serial.print(" ");
void Bluetooth(){
/*if (Serial.available() > 0)
      bt = Serial.read();
    /*  else if (bt == 'C')    //Select need to implement this
      else if (bt == 's')    //Start
there are 50 digitalWrite statements used in sets of 4 to control wheel direction which could be replaced with sub-functions named: forward, back, left, right, stop to make it easier to understand what that group in the code is doing.
additional sub-functions could be written with delays but calling those basic sub-functions.
using sub-functions with meaningful names makes the code easier to read/debug. the sub-functions customize the programming language for your specific application
