Help to reduce recursive code
Hello all you wonderful Arduino'ers!
Once again I dusted off my Arduino to tinker on a new ever evolving project and whilst I have had some challenges in getting the project to where oit is now .. I am quite happy I have it working...
I am undersure how I might pass some data and work on the variables iwth varying types ..
At the moment, I define some ASCII characters in binary "bitmaps"
const uint8_t PROGMEM char_M[8] = {   // store in program memory to save RAM
  B11111111,  B11111110,  B00001100,  B00111000,  B00111000,  B00001100,  B11111110,  B11111111};
I then call a function to use this data and write it to some an LED strip:
void chrM() {
  for (byte x = 0; x < 8; ++x) {
    int i = 0;
    byte data = pgm_read_byte (&char_M[x]);   // fetch data from program memory
    for (byte y = 0; y < 8; ++y) {
      if (data & (1 << y)) {
        writeColour(i);
        i++;
        colors[i] = (rgb_color) {
          0, 0, 0
        i++;
      // repeat for 8 bits
    writeDisplay();
But here in lies the problem .. I have over 70 functions with just the variable changing meaning my program is becoming bloatware :frowning:
Could someone show or guide me to how I might do bitwise operations on the passed variable .. It's the & which is confusing me!
Essentially, I would like to use one function and change the &char_M[x] variable.
Thanks in advance
[/b] variable.
So, why don't you? What is the problem?
By the way, your problem has nothing to do with recursion.
you need something like this
void displayChar(byte data)
    int i = 0;
        writeColour(i);
        i++;
          0, 0, 0
        i++;
    writeDisplay();
That doesn't work, the outer loop is supposed to address 8 consecutive bytes from PRGOMEM
Put your character map in a two dimensional array.
Recursion is when a function calls itself. It's only for grown-ups.
...R
Robin2:
...R
To iterate is human, to recurse, divine.
AWOL:
LOL
...R
Sorry for my incorrect use of recursive :slight_smile:
And thanks for the advice...
I guess I just got a little confused trying to pass the whole part of the char array as a byte when I should pass a character array as a copy of the data in:
I'll try it again today
No wonder you are confused. Whole or part? Why would you (try to) pass a char array as a byte? Passing it as a char * makes sense. Passing it as a byte array makes (some) sense. Passing it as a char array makes sense. Passing it as a byte does not.
you mean a function like this ?:
void chrM(const uint8_t PROGMEM *data, byte dataLength ) {
Something like:
const uint8_t PROGMEM char_AZ[][8] = {
  { ... }, // letter A
  { ... }, // letter B
  { B11111111,  B11111110,  B00001100,  B00111000,  B00111000,  B00001100,  B11111110,  B11111111}, // letter M
  { ...}, //letter Y
  { ...} //letter Z
void chrAZ(char ch) {
  uint8 *thechar = char_AZ[ch - 'A'];
    int i = 0;
    byte data = pgm_read_byte (&thechar[x]);   // fetch data from program memory
        writeColour(i);
        i++;
          0, 0, 0
        i++;
    writeDisplay();
PaulMurrayCbr:
Something like:
  { ...}, //letter Y
  { ...} //letter Z
    int i = 0;
        writeColour(i);
        i++;
          0, 0, 0
        i++;
    writeDisplay();
Firstly, thank you everyone who has posted so far - this help is awesome and whilst I feel I am now in the deep end of my knowledge - the help is greatly appreciated.
I tried to implemet your example Paul but I am getting an error:
'unit8' was not declared in this scope.
So I thought it might be uint8_t but I dont think so as that gives another error. Maybe it's how I'm calling the function ..
chrAZ('A');
Suffice to say, when I started this project I was using integer arrays to define the 8x8 square of a character and I've managed to save RAM but defining them as binary. The challenges can be overcome as I have learned on this project but I do feel like my awareness of datatypes, passing variables and bitwise functions / pointers etc are letting me down...
Thanks all for the wonderful community help thus far!
Wow - thanks people - I think I might have it working using a bits from you all :smiley:
I will just iron out a few bugs and post back here shortly
WOW! Thank you all for some excellent help
I have managed to cut down on all of the explicitly defined functions and reduce them to this:
const uint8_t PROGMEM char_1[8] = {   // store in program memory to save RAM
  B00000000,  B10001100,  B10000110,  B11111111,  B11111111,  B10000000,  B10000000,  B00000000};
const uint8_t PROGMEM char_2[8] = {   // store in program memory to save RAM
  B00000000,  B11000010,  B11100011,  B11100001,  B10110011,  B10011011,  B10001110,  B00000000};
const uint8_t PROGMEM char_3[8] = {   // store in program memory to save RAM
  B00000000,  B01000010,  B10001001,  B10001001,  B10001001,  B11001011,  B01110110,  B00000000};
And with each variable as they were (they don't take up much space) I call the function with:
print_Char(char_A, 8);
Function:
void print_Char(const uint8_t PROGMEM *char_Print, byte dataLength ) {
    int i = 0;
    byte data = pgm_read_byte (&char_Print[x]);   // fetch data from program memory
        writeColour(i);
        i++;
          0, 0, 0
        i++;
    writeDisplay();
  for (int numSep = 0 ; numSep < maxSeperators ; numSep++) {
    seperator();
I call the function as follows:
The size of the code has gone from:
Sketch uses 13,910 bytes (45%) of program storage space.
Global variables use 114 bytes (5%) of dynamic memory
To:
Sketch uses 4,662 bytes (15%) of program storage space.
You don't use the dataLength parameter at all, so you should either use it or remove it.
arduinodlb:
some of the characters are wider than others so having the datalenth might work later... I prefer that I can change it later
