Hello there,
Can someone explain how to read the nRF24L01 scanner code (example) output and know the interference level in each channel.
What i receive is as below,
RF24/examples/scanner/
000000000000000011111111111111112222222222222222333333333333333344444444444444445555555555555555666666666666666677777777777777
0123456789abcdef0123456789abcdef0123456789abcdef0123456789abcdef0123456789abcdef0123456789abcdef0123456789abcdef0123456789abcd
000000000000000000000000111100000000110001020000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000010111000000000000000010001100000000000000000011110000000000000000000000000000000000000000000000000000000000000
000000111100000000000000000000010100111021121001000111210000000000000000000000000000000000000000000000000000000000000000000000
000000000000011110000000000000002000012210000210000000001111110000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000001000100002110000000110000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000022101111110000121000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000111000000100201020000010000000000000000000000000000000000000000000000000000000000000000000000000000000000
Thanks for you support.
If you gt 0000s then your device not get any data from outside.
If got any numbers then your device scanned successful.
If got 12345abcdef this is data is sending and receiving.
maheshdf:
The first two rows are the channel labels. The following rows are a count of how many times out of 100 that a carrier was detected on that channel (up to 15). So it's sort of a percentage that the channel was busy. Since the interference is down in the 1% to 2% range for all channels and none of the channels has sustained interference then any channel should be OK.
