Help to understand this LED fading code
I am making an aquarium LED light using an app called blynk. I have found a code which deals with the LED fading which has been used by others already. Before I use other peoples code I always try to understand fully the code and in this case also because I have to do some changes to adapt it for the Blynk app. I understand most of this code except for the part void settled(). The Author has declared a series of ints within the function and I cant for the life of me determine where they get their values from. I did a “find” exercise on each of the ints and they refer to themselves only! Is this possible and could somebody please explain to how this is working?
 Arduino LED controller for reef aquariums
// paramterized LED lighting control for reef aquariums
// use a DS1307 RTC to kick off lighting schedules
//   fade up on a given slope
//         delay a set amount
//         fade back down
//   such that the photoperiod lasts the correct amount of time
//  Circuit
// PWM pins described below connected to dimming circuits on drivers
// ledMaster pin below connected to a 120V AC relay to turn the LED drivers on and off (optional)
// grounds from drivers connected to arduino ground
// DS1307 RTC connected via I2C
// Pins to control LEDs. Change these if you're using different pins.
int blueLed = 9;     // LED PWM channel for blues
int whiteLed = 10;   // LED PWM channel for whites
// Set up RTC
#include "Wire.h"
#define DS1307_I2C_ADDRESS 0x68
// RTC variables
byte second, rtcMins, oldMins, rtcHrs, oldHrs, dayOfWeek, dayOfMonth, month, year;
// Other variables. These control the behavior of lighting. Change these to customize behavoir
int minCounter = 0;         // counter that resets at midnight. Don't change this.
int blueStartMins = 480;    // minute to start blues. Change this to the number of minutes past
                            //    midnight you want the blues to start.
int whiteStartMins = 480;   // minute to start whites. Same as above.
int bluePhotoPeriod = 510;  // photoperiod in minutes, blues. Change this to alter the total
                            //    photoperiod for blues.
int whitePhotoPeriod = 510; // photoperiod in minutes, whites. Same as above.
int fadeDuration = 60;      // duration of the fade on and off for sunrise and sunset. Change
                            //    this to alter how long the fade lasts.
int blueMax = 255;          // max intensity for blues. Change if you want to limit max intensity.
int whiteMax = 255;         // max intensity for whites. Same as above.
/****** LED Functions ******/
//function to set LED brightness according to time of day
//function has three equal phases - ramp up, hold, and ramp down
void setLed(int mins,    // current time in minutes
            int ledPin,  // pin for this channel of LEDs
            int start,   // start time for this channel of LEDs
            int period,  // photoperiod for this channel of LEDs
            int fade,    // fade duration for this channel of LEDs
            int ledMax   // max value for this channel
  if (mins > start && mins <= start + fade)  {                      //setLed(minCounter, whiteLed, whiteStartMins, whitePhotoPeriod, fadeDuration, whiteMax); WHAT IS THESE 2 STATEMENTS RELATED???
    analogWrite(ledPin, map(mins - start, 0, fade, 0, ledMax));
    if (mins > start + period && mins <= start + period - fade)  {
    analogWrite(ledPin, ledMax);
    if (mins > start + period - fade && mins <= start + period)  {
    analogWrite(ledPin, map(mins - start + period - fade, 0, fade, ledMax, 0));
/***** RTC Functions *******/
// Convert normal decimal numbers to binary coded decimal
byte decToBcd(byte val)
  return ( (val/10*16) + (val%10) );
// Convert binary coded decimal to normal decimal numbers
byte bcdToDec(byte val)
  return ( (val/16*10) + (val%16) );
// 1) Sets the date and time on the ds1307
// 2) Starts the clock
// 3) Sets hour mode to 24 hour clock
// Assumes you're passing in valid numbers.
void setDateDs1307(byte second,        // 0-59
                   byte minute,        // 0-59
                   byte hour,          // 1-23
                   byte dayOfWeek,     // 1-7
                   byte dayOfMonth,    // 1-28/29/30/31
                   byte month,         // 1-12
                   byte year)          // 0-99
   Wire.beginTransmission(DS1307_I2C_ADDRESS);
   Wire.send(0);
   Wire.send(decToBcd(second));
   Wire.send(decToBcd(minute));
   Wire.send(decToBcd(hour));
   Wire.send(decToBcd(dayOfWeek));
   Wire.send(decToBcd(dayOfMonth));
   Wire.send(decToBcd(month));
   Wire.send(decToBcd(year));
   Wire.endTransmission();
// Gets the date and time from the ds1307
void getDateDs1307(byte *second,
          byte *minute,
          byte *hour,
          byte *dayOfWeek,
          byte *dayOfMonth,
          byte *month,
          byte *year)
  Wire.send(0);
  Wire.requestFrom(DS1307_I2C_ADDRESS, 7);
  *second     = bcdToDec(Wire.receive() & 0x7f);
  *minute     = bcdToDec(Wire.receive());
  *hour       = bcdToDec(Wire.receive() & 0x3f);
  *dayOfWeek  = bcdToDec(Wire.receive());
  *dayOfMonth = bcdToDec(Wire.receive());
  *month      = bcdToDec(Wire.receive());
  *year       = bcdToDec(Wire.receive());
void setup()  {
// init I2C
  Wire.begin();
/***** Main Loop ***********/
void loop()  {
  // get time from RTC and put in hrs and mins variables
  getDateDs1307(&second, &rtcMins, &rtcHrs, &dayOfWeek, &dayOfMonth, &month, &year);
  minCounter = rtcHrs * 60 + rtcMins;
  // determine if it is day or night, and act accordingly
  if ((minCounter > blueStartMins || minCounter > whiteStartMins)
           && (minCounter < blueStartMins + bluePhotoPeriod || minCounter < whiteStartMins + whitePhotoPeriod))  {   //day
    // set LED states
    setLed(minCounter, blueLed, blueStartMins, bluePhotoPeriod, fadeDuration, blueMax);
  else  {   //night
    analogWrite(blueLed, 0);
    analogWrite(whiteLed, 0);
  // Get ready for next iteration of loop
The variables are part of the function definition
The values are passed to the function when it is called as in
You may be confused because the function parameters are interspersed with comments whereas they would more often be written like this
void setLed(int mins, int ledPin, int start, int period, int fade, int ledMax)
Ok. Thanks. One more question...why would the author not use the ints already declared? Why make a set of new ones?
Doing it this way allows the same function to be used for multiple different combinations of variables
Take these two calls to the function as an example
They are not new variables, just private names for what the call to the function passes to it.
In time you will see how this avoids very messy situations but for now your code isn't big enough to make it really obvious.
Global vars are okay for small projects but less and less so as the code grows. At some point learning to write C++ classes becomes another step in organizing variables and code, I'm not sure because I was well past that point when I got C++ the first time.
Got it. Thanks
Just with C code it is possible to do a lot of neat things in 100 lines of code or less, often much less. Globals are okay for that.
Inside of functions you can declare local variables the dies when the function exits. Those live on the stack while globals and function static variables live on the heap. All those passed to function values/addresses also live on the stack and die when the function ends. If the stack and heap meet, that will almost always crash the machine.
If you have a function that only gets called in one place, the compiler will likely inline the code and save the overhead of a function call (putting values on the stack then calling the function/subroutine).
